SoftScience Posted May 7, 2020 Share Posted May 7, 2020 If I may ask, what do you use to thin your acrylics for spraying? I see you used vallejo for at least the undersides. I can never get Vallejo to look that smooth, and it clogs the crap out of my brush. This is even when I use their proprietary thinner. Link to comment Share on other sites More sharing options...
Cookenbacher Posted May 8, 2020 Author Share Posted May 8, 2020 On 5/7/2020 at 8:04 AM, SoftScience said: If I may ask, what do you use to thin your acrylics for spraying? I see you used vallejo for at least the undersides. I can never get Vallejo to look that smooth, and it clogs the crap out of my brush. This is even when I use their proprietary thinner. For all water based acrylics (Vallejo, Lifecolor, Modelmaster Acryl, etc) I use a mixture of Future ~25%, distilled water ~70%, and flow improver ~5% - percentages not at all scientific. I think the Future helps it self level and make it a little tougher, although water based acrylics are delicate no matter what. Tip dry is always a problem, but thinning helps. I've found that certain airbrushes actually deal with water based acrylics better than others: the Eclipse is the best Iwata for them, the Gunze Creos Procon series of airbrushes are amazing with them (used the 770 with a 0.18 mm needle for the top coats on this Dauntless - very little clogging - unbelievable), for any other Iwata, H&S or Badger I think a 0.4 needle is as small as you can easily go. I don't like to use alcohol with water based acrylics as sometimes it seems to have adverse effects. Hope this helps! Edit: I just saw in the thread that I used the Procon PS-289 with a 0.3 mm needle for the top coat on this on - sorry! I have used the 770 with Vallejo though with no problems: 3 1 Link to comment Share on other sites More sharing options...
mirageiv Posted May 8, 2020 Share Posted May 8, 2020 Beautiful work Cookie (again)! I think painting the insignia was well worth it, top work! David 1 Link to comment Share on other sites More sharing options...
