John Masters Posted March 19, 2020 Author Share Posted March 19, 2020 1 hour ago, moaning dolphin said: shame about that orange though. Why? Link to comment Share on other sites More sharing options...
John Masters Posted March 19, 2020 Author Share Posted March 19, 2020 1 hour ago, AdrianMF said: I'm looking forward to seeing how you tackle the rigging. Easy-peasy. Holes are drilled, .004 monofilament. CA. Hemostats. Link to comment Share on other sites More sharing options...
AdrianMF Posted March 19, 2020 Share Posted March 19, 2020 31 minutes ago, John D.C. Masters said: Easy-peasy. Holes are drilled, .004 monofilament. I kinda wish I'd done that on mine instead of trying out blind elastic. Still, one has to try new things I guess. Happy Rigging! Adrian Link to comment Share on other sites More sharing options...
John Masters Posted March 19, 2020 Author Share Posted March 19, 2020 6 minutes ago, AdrianMF said: Happy Rigging! Thanks! Link to comment Share on other sites More sharing options...
John Masters Posted March 19, 2020 Author Share Posted March 19, 2020 On the rigging jig. It acts as a separate set of hands. Very important. The rigging on this aircraft is quite simple. No double flying wires...two 'V' sections on each side. The tail rigging is stretched sprue. I almost always use sprue for this. I can use small pieces and control it easily. I glue in the two ends to the fuselage with CA, feed the two pieces through the 2 holes in the top wing next to the struts and then suspend the hemos as weight to stretch the line. Then I add CA glue in the single hole. Wait 5 minutes just to make sure, and snip and trim what remains. Use a new hobby blade to trim the excess line. You see? This is very easy. I find that monofilament works better than EZ Line in many circumstances. EZ Line reacts very quickly with CA glue and can curl up on the end. You don't have that with monofilament. As stated...the rear of the aircraft gets sprue. Sometimes I might use EZ Line here. Sometimes. I will let all of this set for a bit, apply the final decals, touch up where I might need it. If the decals don't cover the rigging holes, I will use tiny amounts of putty to seal them, then overpaint. Then the wheels, prop, stabilizer struts. Finished. Tomorrow I will start the day of social distancing with a clean bench! --John 5 Link to comment Share on other sites More sharing options...
John Masters Posted March 20, 2020 Author Share Posted March 20, 2020 The new images are in the gallery! 1 Link to comment Share on other sites More sharing options...
zebra Posted March 20, 2020 Share Posted March 20, 2020 Just saw this in the gallery - lovely little model, congratulations! Link to comment Share on other sites More sharing options...
John Masters Posted March 20, 2020 Author Share Posted March 20, 2020 1 hour ago, zebra said: lovely little model Thanks Zebra. Link to comment Share on other sites More sharing options...
moaning dolphin Posted March 20, 2020 Share Posted March 20, 2020 20 hours ago, John D.C. Masters said: Why? I was referring to the original Orange that had to be wiped off 😉 Link to comment Share on other sites More sharing options...
John Masters Posted March 20, 2020 Author Share Posted March 20, 2020 10 minutes ago, moaning dolphin said: the original Orange Aha! Yes...I have had problems with it in the past. I might just chuck it since I won't use it. 1 Link to comment Share on other sites More sharing options...
