17 hours ago, bar side said:
Cheers @Biggu I have been digging further on c130.net and found even better stuff.  Like this on XV200
http://www.c-130.net/aircraft-database/C-130/airframe-profile/7147/
EXCELLENT, I'm REALLY glad this did bore fruit, as they say and is of some use....... I'm following this build excitedly....
7 hours ago, fatalbert said:
Flaps are often left down by the mechs,lots of lubrication to be done up there plus fuel leaks to trace and rectify 🙂. Good luck scratch building them down,its a very busy area.
The resin bits look like this
so would be lots of plasticard triangles to fill in
Oh, thought you fancied building an H, that's what I suggested the intake bits. The upgraded engibes and those scimitar-like screw blades on the J me don't likey, and we didn't have the J in our service either.
This is TC-69, the one I'm building in low-vis scheme.
Check 'em flaps position in the last piccy. Incidentally; the Attack Sqd. resin flaps are massive... I can take pictures for you if so you needed.
Yeh, I can...
Unc2
Yeh, I can...
Unc2
That’s going to look good Unc.  Think I am now getting my head around the versions.  Think I will be going for a K C1 between 84 and 88.  Seems like light grey underside at the start& wrap around by the end.  Scheme will be defined by photo evidence of the prototype at a given date.
Flaps - they would look good done, but wouldn’t normally be open.  Easy option - don’t do them.  Otherwise do them & reason is at an air show or maintanence.  Decisions, decisions.
Anyway did some planning around the internal lighting a while back.  Someone said the main cabin light came from instrument glow.  So I thought why not fit the lights behind the consoles & let the glow shine through?
So three bulbs.  Can’t have the light being totally random & I draw the line at individual fibre optic cables to each gauge.  And the light cannot shine out through the aircraft body!  So the big consoles on either side need backs and lots of silver foil to block the light escaping
Actually that isnt too bad,i can see the life raft liners and the redundant emergeny radio container,although that is only on one side.the basic structure is there,i would want to add the fuel dump line and a suggestion of aileron control rod and wiring looms in 1/48 scale.
Yeh, I can...
Hey, Uncle,
Is that the 'chine' mentioned in several topic discussions that I see below the lower windows as a straight line?
Mike
Hi Mike,
Indeed, that's the one. I swear I've been looking all over the forums for a piccy of a modeller that I recall who've addressed and fixed that issue on his 1/72 build, but I wasn't able to find it yet.
It wouldn't be that hard to fix it in 1/48, I guess.
Yeh, me does...
Unc2
So by applying silver foil to the back of the panels I restrict the light to blocks
And a dry fit of the cockpit parts
The kit has two seats to the rear behind the three main seats, but I have also seen only one back there
And with some backs made for those panels - don’t want light bleeding out of the back of them - the three lights will sit here
Not a bright light but hopefully enough for the panel glow look.
Now when playing with the cockpit it was obvious that the area below the main cockpit and ahead of the bulkhead was somewhat limited on detail.  There is a doorway through the bulkhead and a ‘plank’ sticks through from the cargo bay.  A small ladder leads up to the flight deck and that is about it.  So I thought I would build a few plasticard bits - floor & walls etc - to improve it a bit
The large chunk of cardboard is the back of the instrument panel - purely there to block light from shining out of the airframe.  The ladder goes in front something like this
I painted the whole lot white to undercoat the instruments.  Then blanked them off with tape & sprayed on some light grey
Again rough old card back to the instruments.
Also painted up the front wheel well white & gave them a wash over.
Plan now is to wash over the panels & clean back the dials.  See how it comes out soon.
Painted over the white panel faces and then scraped them back.  Looks something like this
So in search of that instrument panel glow, how does this look?
And with the primed but not yet painted seats & bits
And roughly how much you will see when it it sealed up
Now I did consider the idea of a lifting & lowering ramp.  Not easy as it is in two parts & one would need to go up while the other dame down..  I think it would need to move about 4cm down on the lower ramp.
Would look good with a light inside & maybe a lit up landy
So the idea would be a ram / linear actuator to either replace or work with the model rams
but the best I can come up with would be a tube in a tube with a string inside pulled by an actuator hidden away above the wing spar compartment.  But I am sure the string would break once buried inside.  A servo really wouldn’t give the range of movement needed.  I did wonder about rc plane actuators etc but didn’t get any further
If you are worried about string breaking, perhaps consider something like this (no connection with the seller). My dad used something similar for all the rigging lines for his model yachts (Marbleheads, 10-Raters etc) and it had to put up with salt water and chafing (words that no red-blooded male likes to hear). Used to last forever - I can't remember it ever needing replacement, though it has to be said that my old man was a meticulous fresh water rinser.
The other thing that occurred to me was that a spring or a bit of elastic in the system would get around the need for limit switches. As long as your motor got the ramp near enough closed, the elastic bit could worry about making sure it was shut convincingly tight.
Kirk
PS/ Can't wait to see the contra-rotating prop prototype on the next model on the production line. :D
Incidentally, in Herc terminology, only the front part is the ramp. The bit that goes up at the rear is the door.
Good work!
Good work!
Yes, a door would be a more suitable term!  Went inside a US Herc back in the early 80s at Mildenhall.  Starlifter and Galaxy too.  In those days they let you walk through them - literally in the case of the Galaxy
There are three (from memory) dome lights in the Flight Deck which are usually on (at least in the RAAF Hercs) when the aircraft is on the ground with engines off. Once you get to start, the domes are too bright and distracting and they're turned off, leaving the panel and instrument lighting alone. Most are white (there was a bit of red from memory) but NVG-modified aircraft had all green panel and instrument lights.
Edited by Bell209
Servos have come down in price greatly over the last twenty years. Micro servos might be worth a seccond look.
Yep, but really wanted something like this but smaller
or it has to be a pull string up to a linear actuator like this
but needs to have at least a 4cm throw, so larger than the above
Decided the seats are great frames but the UK Hercs seemed to have seat padding on the front
So a bit of modification
And a bit of paint & tape belts.  The belts will get painted but won’t be that visible inside the cockpit
Plus a couple of instruments added to the top of the panel.  All just balanced together so far
Like just about everything else! I detailed my C-130E Flight Deck and all you can see is the portable oxygen bottles next to the chin windows!
Very true.  Not going to go overboard.  I scratch built a Dominie & built seats inside etc.  Can’t really see any of it now!
Fitted the glazing in the nose ready for painting the inside.  I have also glued together the cockpit assembly with lights installed.
The roof and other panels have been picked out since.
Test assembly of the nose to try the lights looked like this.
not a lot of panel glow but some none the less.  I didn’t want a bright light shining out of the windows & fitting the seats damps it down even more.  Not too bad in total dark
Considering there will be 4 external taxi lights, port & starboard wing tip lights, cargo bay lights and anti collision beacons, I think it will do.  Picked up a string of 50 leds for £2.99 o day, so well stocked
Calling the cockpit area about done so moving on to the cargo bay.  I understand this was an area that the RAF K model differed from the standard US variant.  I found this pic on line.  Any idea if this is an RAF cargo bay or not?
creative-interior-image-of-c130-military
No, it's not.
Sorry, that's not very helpful, but wrong floor, wrong overhead bins.
In our wisdom we insisted on using a 20 year old floor system, which was thus 60+ years old when we finished with the Klassic.
33 minutes ago, isaneng said:
No, it's not.
That’s fine - just need to find some good reference photos to see how it should look
