3D Design
Andreas.R
Giddey to all,
I tried to scratch build the coal winches, but as they are very tiny peaces (3 mm height) and 20 x, I did not succeed.
So I decided to 3D print them. I worked many hours with TINKERCAD and learned to use it.
Then I uploaded the 3D file at SHAPEWAYS and ordered the model.
Starting the next lesson: the printability! Loose shells, thin walls and the scale.
The design of the coal winch is relatively simple there are only 8 shells, so I got it after 6 tries.
Here are the pic´s of this design:
and the real thing:
here is the next step for the build, 3D printed boat davits and the 2 boat cranes:
take look at the red arrow ! This is the previous scratch build part and should be exchanged with 3D Part boat crane
The boat davits - challenge was/is they should be movable! Design relatively simple: spacer.png
and the real challenge - the 2 boat cranes!
I have to make 2 different designs to get it placed at my model.
As designed with tinkercad:
A very komplex design, 4 movable parts, 2 different designs and more than 60  shells!
When shapeways noted issues, I had to disconnect up to 20 shells, -change the design, realign and connect the shells again.
When uploaded I often discovered missing shells, and start all over again.
Here what I ordered at shapeways:
I am waiting now for the printed parts, I am very curious!
regards
Andreas
Edited by Andreas.R
new pictures
2 Coal Winches
the boat crane with attached PE (railing, ladder, and platform supports)
the 2 davits at the aft superstructure
