Hello,
here is the German destroyer Z14, I used several kits for:  resin superstructure  from Iron Shipwrights 1934a destroyer, Zvezdas Z17 hull, armament from trumpeter kits,
White Ensign PE sets. It took 5 years to build it!
Thank You for looking
Andreas
Here in Germany you can find a sort of glass called Kathedral, it is used for doors to reduce visibility,
and it has a wavy pattern.
You cut it to the needed size, spray the bottom with a blueish green, glue the model on with  white glue (when dried it should turn transparent)
Thats all.
Regards
Andreas
Edited by Andreas.R
new text
5 hours ago, Andreas.R said:
it is a kind of glass (called kathedral) , the bottom sprayed with a blueish green.
Thats all.
wow! That is a good tip. 👍
It looks terrific!
