Robert Stuart Posted February 21, 2020 Author Share Posted February 21, 2020 That base, given a little twitching, a night to dry, and shot on a raking light (from my phone) Still looks a bit porridgy there? I had a chance to give it a squirt of paint, mostly phtalo blue over burnt sienna, with a light dash of iron yellow ... ... and photographed in natural daylight. Still stuff to do with this base before I can focus on the kit, but ... 4 Link to comment Share on other sites More sharing options...
Robert Stuart Posted February 22, 2020 Author Share Posted February 22, 2020 This is (mostly) phtalo blue over burn sienna followed by a dusting of phtalo green and titanium white mix Taken with flash There is some over spray to bring back, but that base is getting close ... 9 Link to comment Share on other sites More sharing options...
PlaStix Posted February 25, 2020 Share Posted February 25, 2020 Impressive progress Robert and I love the colours you have used for the sea! Kind regards, Stix 1 Link to comment Share on other sites More sharing options...
Robert Stuart Posted February 25, 2020 Author Share Posted February 25, 2020 2 hours ago, PlaStix said: Impressive progress Robert and I love the colours you have used for the sea! Thanks Stix. I used a base of burnt sienna for the surface, and white for the sides with a mix of phthalo blue, phtalo green, white, and iron yellow. All Golden paints - artists' quality paint, if expensive. Moving on, I've started glueing and painting the ship ... Still lots still to do here before ... 7 Link to comment Share on other sites More sharing options...
Robert Stuart Posted February 27, 2020 Author Share Posted February 27, 2020 I've splattered yet more paint onto the base, and. on the ship ... I'm using a hairy stick to paint the decks dark grey, and added a bit of filler around the waterline. There was a threat of snow this morning - if it happened, it never settled, though we must have had something, 'cay=use th ground was wet. Nothing out of the usual, and nowhere near as bad as others had it last week. This afternoon is bright, sunny and dry, so I took advantage. The decks are simply placed here, as are all of the deck houses. I've ordered a few bits an pieces to repace the armaments on Zetland. Right now, they should be somewhere between Melborne and London ... 5 1 Link to comment Share on other sites More sharing options...
Robert Stuart Posted February 27, 2020 Author Share Posted February 27, 2020 Wondering if that deck isn't a bit dark? Link to comment Share on other sites More sharing options...
PeterB Posted February 27, 2020 Share Posted February 27, 2020 Difficult to tell in the pic - probably close to Home Fleet Grey by the look of it but could perhaps be a little bluer looking at Jamies website - his WWII non slip grey is pretty dark but seems to have a blue tinge. I am no expert though. Pete 1 Link to comment Share on other sites More sharing options...
Robert Stuart Posted February 27, 2020 Author Share Posted February 27, 2020 1 hour ago, PeterB said: Difficult to tell in the pic - probably close to Home Fleet Grey by the look of it but could perhaps be a little bluer looking at Jamies website - his WWII non slip grey is pretty dark but seems to have a blue tinge. I am no expert though. Thanks Pete Looking at Jamies site, yes, my deck could be both lighter and bluer. (Is bluer a word?) 1 Link to comment Share on other sites More sharing options...
Robert Stuart Posted March 5, 2020 Author Share Posted March 5, 2020 I mentioned I'd ordered some bits and pieces? They arrived last week. The only bits I plan to use are a replacement pom-pom from FlyHawk. IBG's pom-pom isn't bad, FlyHawk's pom-pom is finer. The two pom-pom models, IBG's primed white, with out-of-focus grey base, next to FlyHawk's version. Back on the base - or, to be place on the base later - I've been working on some of the waves. Essentially acrylic medium applied to clear plastic film. When the acrylic dries I plan to peel it off the film and 'glue' it to the sea base. I changed some of the modelling there, and added more acrylic medium. (The brown envelope is for clarity. The photo above isn't easy to read.) 9 Link to comment Share on other sites More sharing options...
Robert Stuart Posted March 9, 2020 Author Share Posted March 9, 2020 Well, that worked. Looked quite good when I glued it onto the base. Until I tried to paint white foam, and went OTT. So I picked off the foam area, and found I could peel off the whole layer (no photos sorry). There is some progress on the ship, I've started gluing on the deck houses. 9 Link to comment Share on other sites More sharing options...
PlaStix Posted March 10, 2020 Share Posted March 10, 2020 Good to see there's been more progress Robert and the bits you ordered have arrived. Kind regards, Stix 1 Link to comment Share on other sites More sharing options...
Robert Stuart Posted March 21, 2020 Author Share Posted March 21, 2020 With the expectation that I'll spend a bit of time at home, I ordered two more versions of the IBG Hunt class - Badsworth and Middleton. The decals, PE and Sprue A are common to all three kits The devil is in the details ... Badsworth's main deck is different from that of Middleton and of Zetland. Middleton's bridge and deck houses differ from the other two The funnels are common to the three kits Badsworth also has a different locker arrangement on her no 2 gun platform (?) (Shown here after priming) Paint has been ordered, which will (I hope) arrive next week some time. Both kits have been primed, though the parts remain on the sprues. I've also started their sea bases. In a change of strategy, this time I'm using foam board. The boards have been given a coat of acrylic gel (mat, 'cause it is what I had to hand). As an experiment, I used the gel to add a chamfer - this image shows one board right side up, the other is upside down. (Now, which is which?) Side view of sea bases 6 Link to comment Share on other sites More sharing options...
Robert Stuart Posted March 22, 2020 Author Share Posted March 22, 2020 Glue has been applied to Badsworth and Middleton. Following a struggle of some hours with the carpet moster, we have arrived at this point ... Middleton is more advanced as her camouflage pattern is the simplest design of these three ships. Obviously, there is some clean-up to be done here, but, beyond that, I'll be waiting for paint. 5 Link to comment Share on other sites More sharing options...
Robert Stuart Posted March 23, 2020 Author Share Posted March 23, 2020 Had a chance to do some work on the two new bases. While continuing with the foam board (seen in post 37) I adapted @Ray S's paper over sticks method shown in his HMS Gloster build, post 7. My waves are only one stick wide and I changed some of the materials (sticks from cotton buds and water colour paper here) but the approach was similar. I followed up with acrylic molding paste and acrylic gell for texture before adding colour. The new bases are the darker ones in these photos. 7 Link to comment Share on other sites More sharing options...
Rob S Posted March 24, 2020 Share Posted March 24, 2020 18 hours ago, Robert Stuart said: ... I adapted @Rob S's paper over sticks method shown in his HMS Gloster build, post 7. ... Sorry I can’t claim credit for that technique that would be @Ray S Nice work by the way glad I was directed to this Thread. 1 Link to comment Share on other sites More sharing options...
Robert Stuart Posted March 24, 2020 Author Share Posted March 24, 2020 3 hours ago, Rob S said: Sorry I can’t claim credit for that technique that would be @Ray S Nice work by the way glad I was directed to this Thread. Thanks Rob, I've edited my post to credit Ray Ray, Sory for the wrong credit earlier. Link to comment Share on other sites More sharing options...
Ray S Posted March 24, 2020 Share Posted March 24, 2020 2 hours ago, Robert Stuart said: Thanks Rob, I've edited my post to credit Ray Ray, Sory for the wrong credit earlier. No worries! The results look great! I have been painting my bases up but not got to a stage to be able to show yet. I am a bit slow at the mo! All the best, Ray 1 Link to comment Share on other sites More sharing options...
Ratch Posted March 24, 2020 Share Posted March 24, 2020 I wish I had seen this earlier. I'm currently converting Airfix's 1/600 Hotspur into HMS Dulverton, a Type II Hunt. My grandmothers brother was lost on Dulverton in 1942, aged 19. 1 Link to comment Share on other sites More sharing options...
Robert Stuart Posted March 24, 2020 Author Share Posted March 24, 2020 2 hours ago, Ray S said: The results look great! I have been painting my bases up but not got to a stage to be able to show yet. I am a bit slow at the mo! Thanks Ray 2 hours ago, Ratch said: I wish I had seen this earlier. I'm currently converting Airfix's 1/600 Hotspur into HMS Dulverton, a Type II Hunt. My grandmothers brother was lost on Dulverton in 1942, aged 19. Wish you luck with that conversion, Hotspur looks so very different to my eye. I googled photos of HMS Dulverton - though smaller Zetland might be an easier base kit? Some progress with my bases today. More green and blue was sprayed on, sometimes mixed with white. Thesw were followed up with a spotter (short haired brush) loaded with some greenish white mixes for the foam. The paint was spotted into low areas, then wiped back before moving on. Had an email last night, suggesting the paint for Midleton and Badsworth is in the post. 🤞 5 Link to comment Share on other sites More sharing options...
PeterB Posted March 24, 2020 Share Posted March 24, 2020 (edited) " I googled photos of HMS Dulverton - though smaller Zetland might be an easier base kit?" According to Conway's.there were 3 main groups of Hunt, with a couple of a fourth type built as well - all of yours are "Type II" (as is HMS Dulverton) which had a 2ft 6inches more beam than the Type I batch, which proved unstable with the original planned 6 x 4" guns, so only 4 were fitted - the following batches had all 6. Badsworth was launched in March 41, Dulverton in April 41, Middleton in May 41, and Zetland seems to have been the last Type II launched in March 1942 so that gives more than long enough for the inevitable detail changes to be introduced, though I have no information on what they might have been other than changes to the AA armament and perhaps the number of depth charges carried. They all seem to have been the same size. Pete Edited March 24, 2020 by PeterB 1 Link to comment Share on other sites More sharing options...
Robert Stuart Posted March 28, 2020 Author Share Posted March 28, 2020 I've started the camouflage for Middleton and for Badsworth Middleton looks like a simple scheme, dark grey and green grey. Except matching the shapes of those blobs of colour on the hull had me scratching my head for days. I wound up scanning the instructions, and scaling them down to match the kit. I then put strips of masking tape on a surface (plastic film in this case), then laying the reduced scheme over the tape and cutting through. Both ships have a dark grey deck ... But Badsworth's hull has a more complex form. Not quite a dazzel scheme, but clearly influenced by those designs - with lots of straight edges. Seen here placed on the sea base. Setting that up took most of a day, with plenty of eye-breaks 8 Link to comment Share on other sites More sharing options...
Bugle07 Posted March 28, 2020 Share Posted March 28, 2020 Lovely looking bases there, and well done with the painting on Badsworths camo scheme! That's a complicated mask in that scale! Geoff Link to comment Share on other sites More sharing options...
rob85 Posted March 29, 2020 Share Posted March 29, 2020 Nice to see the paint getting laid down! Rob Link to comment Share on other sites More sharing options...
Ray S Posted March 29, 2020 Share Posted March 29, 2020 14 hours ago, Bugle07 said: Lovely looking bases there, and well done with the painting on Badsworths camo scheme! That's a complicated mask in that scale! Geoff Yes, the camo is 'challenging' isn't it? Good work so far @Robert Stuart, it must also be tricking keeping tabs on which is which! All the best, Ray Link to comment Share on other sites More sharing options...
PlaStix Posted March 29, 2020 Share Posted March 29, 2020 Excellent progress Robert and the bases look superb! It all seems to be coming together beautifully. Kind regards, Stix Link to comment Share on other sites More sharing options...
