Mike Posted February 9, 2020 Share Posted February 9, 2020 Hawker Hunter F.6 Wheels (4392 for Airfix) 1:48 CMK from Special Hobby With Airfix’s new kit now on the market and readily available, CMK have created a set of highly detailed wheels for this much-loved aircraft to improve on what’s in the kit box. Arriving in a yellow-themed blister pack held together with a single staple, it contains three wheels including nose wheel and two main wheels, each on their own individual casting block that is attached to the wheel by the slightly flattened contact patch that gives the model the impression of weight, without looking like the erks haven’t put enough air in the tyres. The main wheels have detailed bolts on the front hub and a flatter rear with hole for the axle, which will need a little deepening to attach to the kit. The nose wheel has six spokes on each side, and all three have circumferential tread on their rolling surface, with the supporting webs carefully located so as not to disrupt or damage the tread pattern, which is great planning. The main attachment point will be under the wheel, so it just needs cutting off and sanding smooth so that the wheel stands up squarely without any gaps underneath. Highly recommended. Review sample courtesy of 1 Link to comment Share on other sites More sharing options...
