Sign in to follow this
Paul A H
German Kanonen und Flakwagen of BP-42 (82925) - 1:72 Hobbyboss
1:72 Hobbyboss
The Wehrmacht made good use of the European railway network during the Second World War, moving men and material to the front line quickly and efficiently. The railway network became an obvious target for sabotage, which in turn meant that armoured trains became a natural requirement, particularly for operating in high risk areas where partisans might be present. Unfortunately the rapid development of ground attack aircraft meant that armoured trains became ineffective for the role they were intended to fulfil. Mike reviewed Hobbyboss's BR57 armoured locomotive some time ago (quite by accident, because he forgot to check the scale) and I've reviewed various iterations of their armoured wagons. This is the latest in the series, depicting a variant armed with quad flak and cannon turrets.
In classic Hobbyboss style, the kit is tightly packed into a sturdy box, with everything meticulously wrapped to ensure it survives the journey from China to wherever you are. The kit is very simple, composed of a handful or slide-moulded parts, two sprues of smaller parts and two sprues holding Hobbyboss's standard track sections. Also in the box are the instructions, a glossy A4 painting sheet and a small sheet of generic decals. The detail of the slide-moulded parts is excellent, with crisp and fine surface details.
Construction begins with the lower chassis. The axles and wheels fit in from above and are then boxed in so there is no see-through effect. As with other similar kits from Hobbyboss, the brake blocks are moulded in place on the wheels, while the leaf spring suspension units are separate parts. The buffers and couplings are provided for either end. The 2cm Flakvierling 38 mount is a mini-model in its own right, although in usual Hobbyboss style, the part count isn't excessive. There are some nice touches, including spare magazines and a nicely moulded splinter shield. The howitzer turret is a very simple affair by comparison, and it should be noted that none of the turrets can be posed in the open position (not that there is any interior detail in any case). The track is split into four sections, the joins in which are cleverly matched to the natural breaks and joined with nicely moulded fish plates. If you really want to hide the joins properly, some 00 gauge ballast could be used, while the detail could really be ramped up with some proper track.
Only one colour scheme is included on the sheet, for a vehicle with a base of Dark Yellow, over which Red brown and Field Green stripes are applied in a similar fashion to contemporary armoured vehicles.  Given how filthy railway rolling stock gets due to the soot and grease, there is huge scope for the builder to express him or herself with weathering.
Conclusion
I thought Hobbyboss had finished their range of German armoured trains, but apparently not. This model - ho ho - rails (that pun never gets old) against the trend of producing models with ever increasing levels of detail and complexity. It will make a great model when paired with Hobboyboss's BR57 and other armoured wagons. Whatever you decide to do with it, you can't deny that it's nice to have a mainstream model of this interesting subject. Recommended.
Review sample courtesy of
