Wez Posted April 8, 2020 Share Posted April 8, 2020 1 hour ago, CedB said: and specific type of flour? Beggars can't be choosers Ced, use whatever flour you can get because there's sod all on the supermarket shelves! 6 Link to comment Share on other sites More sharing options...
corsaircorp Posted April 8, 2020 Share Posted April 8, 2020 9 minutes ago, Wez said: Beggars can't be choosers Ced, use whatever flour you can get because there's sod all on the supermarket shelves! Whaaat flour too ??? I knew for the toilet paper and coffee filters... But flour ?? Forget the pastas, and then it's boring to smash it into flour.... Sincerely. CC 1 Link to comment Share on other sites More sharing options...
giemme Posted April 8, 2020 Author Share Posted April 8, 2020 4 hours ago, CedB said: Nice work Giorgio I must try the CA and flour thing… and specific type of flour? Not really. Regular wheat flour, and I think the finer the better (like 00). I'm using gluten free flour though, as 3 out of 5 in my family have celiac disease and it's the only kind of flour we keep at home - and it works great HTH 2 1 Link to comment Share on other sites More sharing options...
Terry1954 Posted April 8, 2020 Share Posted April 8, 2020 21 minutes ago, giemme said: Not really. Regular wheat flour, and I think the finer the better (like 00). I'm using gluten free flour though, as 3 out of 5 in my family have celiac disease and it's the only kind of flour we keep at home - and it works great HTH And remember @CedB, don't use any yeast or the model will rise.............. Terry 6 Link to comment Share on other sites More sharing options...
Biggles87 Posted April 8, 2020 Share Posted April 8, 2020 You really seem to be making up for lost time now G. No flour here either, presumably there’s a lot of bread making going on. John 1 1 Link to comment Share on other sites More sharing options...
Spookytooth Posted April 8, 2020 Share Posted April 8, 2020 Good to see you back on the bench again G. Yep that canopy is going to be faired in. If you are using PPP, or similar acrylic filler, add a drop of the cockpit colour to it. It hides it. Simon. 1 2 Link to comment Share on other sites More sharing options...
giemme Posted April 8, 2020 Author Share Posted April 8, 2020 5 hours ago, Biggles87 said: You really seem to be making up for lost time now G. Thanks John Yes, and trying to keep my mind away from all the worries related to this period ... 5 hours ago, Spookytooth said: Good to see you back on the bench again G. Yep that canopy is going to be faired in. If you are using PPP, or similar acrylic filler, add a drop of the cockpit colour to it. It hides it. Simon. Cheers Simon, will do - thanks for the heads up! Here's some more progress for your consideration, guys: bottom seam sorted Including the tail light I'm still considering the idea of scratch building a new one from some clear plastic scrap, will see... Next task was to deal with the intake, more precisely the "nose ring" as you can see from next pic, the kit sports a pretty thick edge there So using an appropriate Dremel tool I tried to sharpen it Definitely better, although not easy to photograph the difference. While I was at it, I decided to add a strip of alu tape for the inside the plan is to paint the outside, instead. That's it for tonight, all comments welcome Ciao 17 Link to comment Share on other sites More sharing options...
CedB Posted April 9, 2020 Share Posted April 9, 2020 Nice thinning Giorgio, looks much better Thanks for the tip on the flour - I'll give it a try, one day when I'm feeling brave! 14 hours ago, Terry1954 said: And remember @CedB, don't use any yeast or the model will rise.............. Thanks Terry - that'll help get them on the ceiling won't it? 14 hours ago, Biggles87 said: No flour here either, presumably there’s a lot of bread making going on. Let them eat cake? 6 Link to comment Share on other sites More sharing options...
Ray S Posted April 9, 2020 Share Posted April 9, 2020 15 hours ago, Spookytooth said: Yep that canopy is going to be faired in. If you are using PPP, or similar acrylic filler, add a drop of the cockpit colour to it. It hides it. Simon. I have often wondered how to use filler around a canopy and not have it showing on the inside. Yet that is such a simple solution...why did I not think of that? (PS- do not answer that one please!)> All the best, Ray 4 Link to comment Share on other sites More sharing options...
giemme Posted April 13, 2020 Author Share Posted April 13, 2020 (edited) Hi everybody! I hope you all had a Happy (and safe) Easter, compatibly with the current situation. There's been wine and food around here, but I also managed some modelling. Remember the IP coaming I scratch built from brass? Using a Dremel cutting disc, I opened the two slots for the Pilot Attack Sights and scratch built those from sprue runners (actually, the small rectangular bits showing the part number from a Tamiya kit) Glued in place with CA, acting also as filler. I also drilled a small hole on top of them, to represent a sort of projector. I then airbrushed it with Tamiya Flat Black and glued in place using Gator's Grip With the PAS in place and all, it ended up not fitting quite as I wanted .... so I followed Simon's @Spookytooth advice and mixed some Italeri Black with PPP, and filled in the gaps It turned dark grey, as you can see, but that's good anyway because I then resprayed the outside, while for the inside it was dark enough not to show any contrast. So, once cleaned up and resprayed: I then painted the projectors with Italeri Steel, followed by Tamiya Clear Green; the coaming received a drybrush with Lifecolor Dark Grey and Dark Gull Grey, and a coat of W&N Galeria Flat clear then I glued in the reflector screens (made from a thin acetate sheet) rather simplified compared to the real thing, but better than nothing (the kit doesn't supply them) I masked the windshield with Oramask, outside and inside (leaving only the outer frames uncovered) A quick pass with a fine brush and Aqua Gloss along the mask edges, and then it received a coat of Tamiya Flat Black too I then glued it in place using Formula 560 canopy glue While I was at it, I also masked the canopy: this time, I had to use Tamiya tape on the outside, as Oramask wouldn't conform to the curvy shapes and was leaving wrinkles near the edges (being quite thick) I used Oramask for the inside, though (not very visible from here, but it's there) and sliced a couple of fingers in the process, while cutting around the masks with a #15 Swann- Morton blade - boy, they're sharp! As you can see, the canopy has two hinges on the back side, whose corresponding slots are .... missing on the airframe I'll be posing the canopy open, like this So I carved out the slots using a razor saw, a chisel and a microdrill bit; here they are, after brushing in some TET to clean out the job That's it for the day, all comments welcome Ciao Edited April 14, 2020 by giemme 19 Link to comment Share on other sites More sharing options...
keefr22 Posted April 13, 2020 Share Posted April 13, 2020 Great stuff - excellent to see this back underway, and good to hear you and your family are well and had a good Easter! Take care Keith 1 1 Link to comment Share on other sites More sharing options...
Spookytooth Posted April 13, 2020 Share Posted April 13, 2020 Nice work on the detailing the office G. We are glad that you and your family had a good Easter. Simon. 1 Link to comment Share on other sites More sharing options...
bbudde Posted April 13, 2020 Share Posted April 13, 2020 Looks great Giorgio. Stay safe and tuned., Cheers 1 Link to comment Share on other sites More sharing options...
Terry1954 Posted April 13, 2020 Share Posted April 13, 2020 Great stuff there Giorgio. Terry 1 Link to comment Share on other sites More sharing options...
Cookenbacher Posted April 13, 2020 Share Posted April 13, 2020 Fantastic detail work as always Giorgio! 1 Link to comment Share on other sites More sharing options...
CedB Posted April 14, 2020 Share Posted April 14, 2020 ^ Wot he said! Great stuff Giorgio 1 Link to comment Share on other sites More sharing options...
perdu Posted April 14, 2020 Share Posted April 14, 2020 Very very Giorgio, the gold standard as we have become accustomed Lovely work G 1 Link to comment Share on other sites More sharing options...
giemme Posted April 14, 2020 Author Share Posted April 14, 2020 13 hours ago, keefr22 said: Great stuff - excellent to see this back underway, and good to hear you and your family are well and had a good Easter! Take care Keith Thanks Keith, much appreciated! 13 hours ago, Spookytooth said: Nice work on the detailing the office G. We are glad that you and your family had a good Easter. Simon. Cheers Simon, thanks I hope you guys are keeping good too! 13 hours ago, bbudde said: Looks great Giorgio. Stay safe and tuned., Cheers Thanks Benedikt, I will 13 hours ago, Terry1954 said: Great stuff there Giorgio. Terry Glad you like it, Terry 11 hours ago, Cookenbacher said: Fantastic detail work as always Giorgio! 1 hour ago, CedB said: ^ Wot he said! Great stuff Giorgio Thanks Cookie and Ced More details coming for the canopy, but that should be almost it for this build 1 hour ago, perdu said: Very very Giorgio, the gold standard as we have become accustomed Lovely work G Thanks Bill, you are way too kind! Back to work today (with mask an distancing and all), trying to get back to some sort of normality Stay safe everybody! Ciao 5 Link to comment Share on other sites More sharing options...
stevehnz Posted April 14, 2020 Share Posted April 14, 2020 15 hours ago, giemme said: all comments welcome Wonderful work on that cockpit combing, it looks very convincing. Steve. 1 Link to comment Share on other sites More sharing options...
phantom61 Posted April 14, 2020 Share Posted April 14, 2020 On 4/8/2020 at 11:34 PM, giemme said: Definitely better, although not easy to photograph the difference. While I was at it, I decided to add a strip of alu tape for the inside I like very much... fine and clean... 👍 ciao Silvano 1 Link to comment Share on other sites More sharing options...
corsaircorp Posted April 16, 2020 Share Posted April 16, 2020 Nice and tidy job Giorgio !! Congrats ! great cockpit saving ! Hope the fingers are operationals again ! CC 1 Link to comment Share on other sites More sharing options...
Biggles87 Posted April 16, 2020 Share Posted April 16, 2020 Coaming along splendidly ( sorry, couldn’t resist ) 4 Link to comment Share on other sites More sharing options...
giemme Posted April 16, 2020 Author Share Posted April 16, 2020 On 14/04/2020 at 11:05, stevehnz said: Wonderful work on that cockpit combing, it looks very convincing. Steve. Thanks Steve, glad you like it! On 14/04/2020 at 11:40, phantom61 said: I like very much... fine and clean... 👍 ciao Silvano Cheers Silvano, thanks Beeing on the inside, you can't really see much of it, so I think it's more than an acceptable solution. 11 hours ago, corsaircorp said: Nice and tidy job Giorgio !! Congrats ! great cockpit saving ! Hope the fingers are operationals again ! CC Thanks CC! Only my right thumb still bothering a little, but it'll be OK in a couple of days 6 hours ago, Biggles87 said: Coaming along splendidly ( sorry, couldn’t resist ) No problem, John - pun and praise at the same time, what could I ask more? I managed a little progress today; gap filling around the windshield, again following the advice from Simon @Spookytooth and mixing PPP with some Italeri Black. After a couple of application and drying I then removed the excess with a wet finger and completed the filling with pure PPP, again smoothed with a wet finger and refined with a spongy makeup brush and after a quick respray I also detailed the inside of the canopy, adding some cabling and a reference tab for the opening arm. All glued with Gator's Grip but the tab, which was glued with TET All comments welcome Ciao 11 Link to comment Share on other sites More sharing options...
Spec7 Posted April 16, 2020 Share Posted April 16, 2020 (edited) Just caught up with this, a twin stick Lightning, excellent it must be good as i joined 9 years ago and this has prompted me to do my 1st post Edited April 16, 2020 by Spec7 4 1 Link to comment Share on other sites More sharing options...
The Spadgent Posted April 16, 2020 Share Posted April 16, 2020 Canopy tastic!!!! ❤️ Simply divine work G. love it. 🤗 Johnny 1 Link to comment Share on other sites More sharing options...
