exdraken Posted February 7, 2020 Share Posted February 7, 2020 (edited) See what came today from the big Hannants!: I could not resist and open it immediately! will be in Austrian Airforce colors, I guess I will search for decals in the decal stash... should not be too hard I hope! if not, Brentair decals does complete ones.... was called Eierspeis Bomber because of its color afaik https://www.gotech.at/saab_91d_safir.htm https://www.gotech.at/saab_91d_safir_3f-sj(c)bundesheer.jpg should be simpler than the Viggen take off project! that is what you get a quick cleanup in order to check shapes cheers, Werner Edited March 7, 2020 by exdraken 10 Link to comment Share on other sites More sharing options...
exdraken Posted February 7, 2020 Author Share Posted February 7, 2020 some glue on already and some PE! the cockpit now needs some light grey base color looks really nice and improves on the kit I think! 5 Link to comment Share on other sites More sharing options...
trickyrich Posted February 7, 2020 Share Posted February 7, 2020 welcome along again Werner, and what I nice model you've brought too. We have the 1/72nd version now the 1/48th of such a nice looking aircraft. That PE set will certainly set off the model, especially the cockpit. Good luck with this build, I look forward to following this one and eventually see her in the gallery too. 1 Link to comment Share on other sites More sharing options...
Rudolf_Filip Posted February 8, 2020 Share Posted February 8, 2020 Good choice of kit! I'm a big fan of the Safir. I have flown in those a couple of times. Perhaps not the most beatiful, but it has quite a lot of character. 🙂 I have (almost) built three of these kits. They are not finished since I'm still haven't bought the last decals for them... The Tarangus kit is short run and need a little care to minimize the amount of work. The main thing to look out for is the fit of the canopy. It is a little wider than the fuselage. I solved this by adding a small piece of plastic card in the nose. Thus spreading the front of the fuselage to fit the clear part. I will be following your build with interest. Andreas 2 1 Link to comment Share on other sites More sharing options...
Col. Posted February 8, 2020 Share Posted February 8, 2020 Nice to see another Safir in the GB Werner and this kit looks to be a good one. 1 Link to comment Share on other sites More sharing options...
Bengalensis Posted February 8, 2020 Share Posted February 8, 2020 It's a nice little kit if you work on it. This Austrian version is on the Maestro sheet. I will not be using it. You will have to mask and paint the arrow though. Link to comment Share on other sites More sharing options...
exdraken Posted February 8, 2020 Author Share Posted February 8, 2020 3 minutes ago, Bengalensis said: It's a nice little kit if you work on it. This Austrian version is on the Maestro sheet. I will not be using it. You will have to mask and paint the arrow though. Thanks! Actuslly I just discovered that early on? or for the display fourship? they were in yellow with the black anti-glare only, no orange... see the photo above! Is it the same yellow though?? 1 Link to comment Share on other sites More sharing options...
Bengalensis Posted February 8, 2020 Share Posted February 8, 2020 The color in my photo looks a bit warmer, more orange, than the instructions are actually printed, although they are printed a much warmer yellow than your photo shows. Maestro suggests these paints: Gunze Aqueous H024 Orange Yellow Gunze Aqueous H014 Orange I have no idea what they look like though. Your photo looks quite like the old yellow Swedish trainers to my eye. Link to comment Share on other sites More sharing options...
exdraken Posted February 8, 2020 Author Share Posted February 8, 2020 1 hour ago, Bengalensis said: The color in my photo looks a bit warmer, more orange, than the instructions are actually printed, although they are printed a much warmer yellow than your photo shows. Maestro suggests these paints: Gunze Aqueous H024 Orange Yellow Gunze Aqueous H014 Orange I have no idea what they look like though. Your photo looks quite like the old yellow Swedish trainers to my eye. thanks, what do they suggest for Swedish colors? there is also this one.... a bit more orange... https://www.gotech.at/saab_91d_safir_3f-si(c)bundesheer.jpg then on the first one, the cowling seems to have an orange touch on top... some progress by the way: 8 Link to comment Share on other sites More sharing options...
Bengalensis Posted February 9, 2020 Share Posted February 9, 2020 The Swedish yellow version is not on the Maestro sheet so no comparable recommendation given there, and the Tarangus instructions don't say anything I think. I ended up getting the dedicated Swedish yellow mix from MRP. However, looking at your second photo I'd say that the Austrian version is certainly a warmer, more orange yellow than the Swedish. I always find it difficult to judge colors... 1 1 Link to comment Share on other sites More sharing options...
exdraken Posted February 9, 2020 Author Share Posted February 9, 2020 some more work done hope to close her soon! ignore the dirt.... added a small styrene stripe to the front cowling as advised - thanks @Rudolf_Filip and @Bengalensis seats need to be cleaned and improved a bit still 12 Link to comment Share on other sites More sharing options...
Christer A Posted February 9, 2020 Share Posted February 9, 2020 That etch on the IP made all the difference! 1 Link to comment Share on other sites More sharing options...
Rabbit Leader Posted February 10, 2020 Share Posted February 10, 2020 Great subject and a lovely start Werner. Looks a lot like the Heller kit only twice as big and ten times better! You're making a great start here and happy to follow along to see how you go. Looks like it's gonna be a great WIP. Cheers and best of luck.. Dave 1 Link to comment Share on other sites More sharing options...
exdraken Posted February 10, 2020 Author Share Posted February 10, 2020 (edited) moving on... PE seatbelts, also add a lot! photos not the best with mobile flash indoors..... nevermind a view not possile any longer test fit of canopy , not the PE fret on the back! IP mounted on one side.... ready for closure?!? Edited February 10, 2020 by exdraken 10 Link to comment Share on other sites More sharing options...
reini Posted February 12, 2020 Share Posted February 12, 2020 Yep, looks about ready to be closed! The belts really add a lot to the cockpit. 1 Link to comment Share on other sites More sharing options...
exdraken Posted February 15, 2020 Author Share Posted February 15, 2020 (edited) after searching for my build thread.... that is a monster GB! 3 days without an update, and page 3 is what you are in 👾 🤣 so, closing ceremony tonight all went well , ok, nearly, I had to remove the IP.... hope to being able to fit it later then... pre-closure state: and afterwards... see the lacking IP? or not? and to get an idea if the canopy will fit later on... looks pretty ok now Edited February 15, 2020 by exdraken 7 Link to comment Share on other sites More sharing options...
Col. Posted February 15, 2020 Share Posted February 15, 2020 Was the instrument panel too wide for the fuselage halves Werner? Link to comment Share on other sites More sharing options...
trickyrich Posted February 16, 2020 Share Posted February 16, 2020 gee she does look nice Link to comment Share on other sites More sharing options...
exdraken Posted February 16, 2020 Author Share Posted February 16, 2020 17 hours ago, Col. said: Was the instrument panel too wide for the fuselage halves Werner? yeah,-.. o I glued it badly.. I remember it fit earlier.. 16 hours ago, trickyrich said: gee she does look nice better still with wings: 7 Link to comment Share on other sites More sharing options...
modelling minion Posted February 16, 2020 Share Posted February 16, 2020 Very nice work Werner, she really is a nice looking aircraft. 1 Link to comment Share on other sites More sharing options...
exdraken Posted February 16, 2020 Author Share Posted February 16, 2020 do not forget nose weight! I assume it necessary after closing everything without... and re-opening ... the Maestro Models, Rebell Hobby masks really speed up masking.... if you care! 7 Link to comment Share on other sites More sharing options...
Col. Posted February 17, 2020 Share Posted February 17, 2020 Great progress Werner. Getting the main components together shows how lovely an aircraft the Safir looks. 1 Link to comment Share on other sites More sharing options...
Rabbit Leader Posted February 17, 2020 Share Posted February 17, 2020 That does look rather excellent Werner. I love the Safir and this 1/48 kit looks to be a rather tempting future investment. You’re doing a great job and she’s coming along beautifully. Cheers.. Dave Link to comment Share on other sites More sharing options...
exdraken Posted February 22, 2020 Author Share Posted February 22, 2020 I did some pre shading, not sire if necesary with a trainer called Eierspeißbomber (scrambled eggs bomber) but nevermind some paint work already accomplished regarding color, we discussed before.... more yellow, warmer, etc... 😅 it is a mix between those 2 shades of yellow, I also added some white for whatever reasons.... ,looks better in the photos than in real life though.. yellow is a f.......antastic color! 5 1 Link to comment Share on other sites More sharing options...
Col. Posted February 22, 2020 Share Posted February 22, 2020 Getting the yellow on has brought new life to this one Werner 1 Link to comment Share on other sites More sharing options...
