Jpthedog Posted February 29, 2020 Author Share Posted February 29, 2020 15 hours ago, CliffB said: Nice work with the gloss black. It's never easy! Cheers Cliff - still not got it right! 15 hours ago, Col. said: Looks smooth John Col - looks can be deceptive! Not as smooth in real life - I had the plastic polished smoother! Considering using my polishing cloths on it before going with the AK aluminium - probably over thinking things! 2 Link to comment Share on other sites More sharing options...
trickyrich Posted February 29, 2020 Share Posted February 29, 2020 getting a super smooth gloss blank is so hard to do, but it looks pretty good, well done. As you say a good buffing could be all she needs to get a good base for the metallic. Just give the paint plenty of time to cure first. 1 Link to comment Share on other sites More sharing options...
Jpthedog Posted March 1, 2020 Author Share Posted March 1, 2020 Sunday afternoons progress: So here I have added a tail light for this civil DC3 - clear sprue, cut to small length, drilled and filled with red paint, then glue to plastic sprue, then sanded with increasingly fine grit to a smooth tube. Then i hacked a slice in the tail for the light and filled around with sprue goo! Here we see the gloss sanded with polishing cloths 3600 grit - i felty this was smoother. Venturi isnt in the way of the decal I dont think, so its staying there. Foam I had used to mask/block the windows removed as it was masking too much. Just sparayed around the windows... Shiny DC3 with masking still on the control surfaces and cone masks on the engines. AK Xtreme metal sprayed on, which is quite forgiving. A few annoying blemishes to rectify. Side view Masking to aileron removed Tail light on and painted Probably seal the whole lot now with Kleer to protect it from my clumsy way of working. It can be polished but tahts where i muck it up, so not doing that this time. Then re-spray a couple of the panels with blemishes - then decals! 9 Link to comment Share on other sites More sharing options...
Col. Posted March 1, 2020 Share Posted March 1, 2020 Tidy work John Particularly liking the tailight but it's all good. 1 Link to comment Share on other sites More sharing options...
trickyrich Posted March 2, 2020 Share Posted March 2, 2020 wow she is nice and shiny, well done on the finish. 1 Link to comment Share on other sites More sharing options...
Jpthedog Posted March 11, 2020 Author Share Posted March 11, 2020 On 2/26/2020 at 8:29 AM, ragnarec said: Another small thing I forgot to mention. On my model, the venturi tube on the left fuselage got in conflict with the window stripe decal. The decals are correct, the problem is the venturi. I would suggest slicing it off and repositioning it according to the drawings. Ragnarec Hmm - I thought the decal would miss the venturi - no, so I had to slice it off mid-decalling! Not the best - now its a respray of one panel.... as i say I seem to take two steps forward and one back! 1 Link to comment Share on other sites More sharing options...
Jpthedog Posted March 11, 2020 Author Share Posted March 11, 2020 Pictorial update - should have been finished by now but the usual glitches.. Landing lights in - used the rhinestones for the first time! Another view with the painted props Tail decal on - quite thick and inflexible One side strip on Aaargh! The venturi was indeed in the wrong place for the decal - scalpel to the rescue mid decalling session - not best practice! Will need to respray the panel. You can see the bubbles in the humbrol clear fix too - will look great from 6 feet away! 10 Link to comment Share on other sites More sharing options...
Col. Posted March 11, 2020 Share Posted March 11, 2020 There's a good excuse to scratch-build a better venturi John With those decals on the right side this one really is looking great 1 Link to comment Share on other sites More sharing options...
ragnarec Posted March 11, 2020 Share Posted March 11, 2020 5 hours ago, Jpthedog said: Tail decal on - quite thick and inflexible That was my experience, too. I ended up masking and painting the tail stripe. On the other hand, it seems that you have avoided the strange decal shrinking I experienced - I must have got a bad sample of the decal sheet. Very nice work so far, btw. I really like the metal finish. Have you had any problems with masking over the Xtreme Metal paint? 1 Link to comment Share on other sites More sharing options...
Jpthedog Posted March 11, 2020 Author Share Posted March 11, 2020 8 hours ago, Col. said: There's a good excuse to scratch-build a better venturi John With those decals on the right side this one really is looking great Cheers Col - oh I've yot to replace it?? 3 hours ago, ragnarec said: That was my experience, too. I ended up masking and painting the tail stripe. On the other hand, it seems that you have avoided the strange decal shrinking I experienced - I must have got a bad sample of the decal sheet. Very nice work so far, btw. I really like the metal finish. Have you had any problems with masking over the Xtreme Metal paint? Ragnarec - i will settle the tail decal still but no shrinking which is important to match the windows. Metal xtreme is sealed with Klear to protect it but no problem masking etc. Thanks for the comments 1 Link to comment Share on other sites More sharing options...
trickyrich Posted March 12, 2020 Share Posted March 12, 2020 gee she looks really smart with some decals on!! I've lost count of the number of time I've hd to do the sort of correction/masking/repainting. Luckily it looks like you had plenty of room to work around that area, no decals to worry about. 1 Link to comment Share on other sites More sharing options...
Jpthedog Posted March 31, 2020 Author Share Posted March 31, 2020 On 3/12/2020 at 10:15 PM, trickyrich said: gee she looks really smart with some decals on!! I've lost count of the number of time I've hd to do the sort of correction/masking/repainting. Luckily it looks like you had plenty of room to work around that area, no decals to worry about. Rich - cheers. Was a relatively easy spray of a panel and plenty space to work round as you say. Here is the DC3 finished anyway. Got there eventually after spending ages on aerials etc. Not perfect but overall a good addition to my collection of completed models. 16 Link to comment Share on other sites More sharing options...
CliffB Posted March 31, 2020 Share Posted March 31, 2020 A simple scheme, but really effective. Congratulations Cheers 1 Link to comment Share on other sites More sharing options...
Col. Posted March 31, 2020 Share Posted March 31, 2020 Lovely work John 1 Link to comment Share on other sites More sharing options...
desert falcon Posted March 31, 2020 Share Posted March 31, 2020 She looks fantastic 👍 Is that a DC-10 in the background? 1 Link to comment Share on other sites More sharing options...
Jpthedog Posted March 31, 2020 Author Share Posted March 31, 2020 1 hour ago, Col. said: Lovely work John Cheers Col 1 hour ago, desert falcon said: She looks fantastic 👍 Is that a DC-10 in the background? Thanks for that. looks fine from a distance! Yes SAS DC10 that I acquired from a club member - fine trijet! 1 Link to comment Share on other sites More sharing options...
Terry1954 Posted April 2, 2020 Share Posted April 2, 2020 Lovely job there! Terry 1 Link to comment Share on other sites More sharing options...
ragnarec Posted April 4, 2020 Share Posted April 4, 2020 Very nice build! 👍 1 Link to comment Share on other sites More sharing options...
trickyrich Posted April 4, 2020 Share Posted April 4, 2020 NICE!!! You can't beat a nice simple scheme on NMF and the NMF just shows off the lines on the DC-3 perfectly. Well done, I think she's a fine addition to any collection and will nicely stand out in the gallery! Thanks for joining the GB, I do hope you enjoyed it, as it was a pleasure to have you along. 1 Link to comment Share on other sites More sharing options...
Grandboof Posted April 10, 2020 Share Posted April 10, 2020 Looking nice and polished before the days of quick turn arounds when there was time . Looks great Martin H Link to comment Share on other sites More sharing options...
