Stupid Hurricane question ?
Corsairfoxfouruncle
12 minutes ago, noelh said:
On the other hand is this quote from Pilot Officer Frank Mitchell of 87 squadron before Dieppe. 'August 18 - spent the day, apart from briefing, in converting the black night fighters to daytime camouflage. Paint everywhere - very rushed job'. So yes exactly as you say and as seen in the pictures of 87 squadron.
Thank you, interesting point.
Except.... what the 87 Sq photos show is the night intruder scheme.
Now, some observations .
I don't when the 87 Sq photos were taken
P/O Mitchell is not likely to have known what the paint scheme was called, and taken adding upper in green/grey uppers as daytime camouflage?  If you were unaware of the specifications of the night intruder scheme, (and why would you be as a pilot)  and knew that green/grey uppers are daytime camouflage, then his comment makes sense as being repainted to "daytime colours"  AND fits the photos.  Just a suggestion.
Also, I have not seen an 87 Sq IIc in standard DFS.
HTH
Thanks Troy and like P/O Mitchell I didn't recognise the the night intruder scheme either.
I checked the IWM website and that photo of the 87 squadron Hurricane LK-R is dated as the 2nd September 1942. Two weeks after Dieppe. Which fits with the obviously messy paint job. Interestingly in the right background there is an all black Hurricane. Not yet repainted.
Edited by noelh
@Troy Smith,
Troy,
I have a question regarding HL603 in the photo posted earlier in this discussion of the six No. 87 Sq. IIc's in formation. Am I correct in assuming that JX-I, HL603 has a sky spinner and fuselage band, yellow LE ID stripes, and a dark green/medium sea grey/night camouflage scheme? Codes in sky? Hard to tell in the photo if the underside is night. (Help me Obie-Wan- you're my only hope!)
Mike
On 2/5/2020 at 3:23 PM, Troy Smith said:
No, the 87 sq pics show the Night Intruder scheme AFAIK, uppers repainted in Dark Green and Medium Sea Grey, underside staying Night.
Troy,
See the attached link; can you scroll down to the very large formation photo of the 87 Squadron Mk IIc's that have been posted in this discussion, and give me your thoughts on the upper surface and undersurface colors, especially the probability of night undersurfaces? There are some outstanding photos in the linked site, fighters and bombers, many of which I think might be new to many interested parties, but it is the Hurricane photos I wanted your comments on. Thanks!
Mike
http://virtpilot.org/files/lib/book366.pdf
8 hours ago, 72modeler said:
@Troy Smith,
Troy,
Mike
Edit . This is 1 Sq .  There are some formation photos of 87 Sq in the Night Intruder scheme (see post below)
Hawker-Hurricane-IIc-RAF-1-Squadron-JXY-
Mike, if anything HL603 JX-I  is a 'vanilla' scheme and is just in factory Day Fighter Scheme,
why? ....the serial on the Sky band, is per factory application. Right position 'font' and size, only plane in the line up like this.
yes
and a dark green/medium sea grey/night Ocean Grey/ Medium Sea grey camouflage scheme?
yes
Codes in sky?
Yes
No
@Seahawk perhaps will be kind enough to have a look at Air Britain  and see if there is any info.   If I can get to mine, I will.
this turned up in an image search
hurribomber.jpg?w=424&h=224
re the Dieppe raid
https://making-history.ca/2019/07/06/the-greatest-air-battle-dieppe-19th-august-1942/
Looks to be a film still,  so time to do some hunting.
EDIT - bingo
https://film.iwmcollections.org.uk/record/807
Quote
Description:Dawn and a flare arcs down to the ground. Hurricanes of 87 Squadron emerge through the mist to land, one without undercarriage. A "vic" formation and a flight of four aircraft take off followed by a squadron of 12 Spitfires flying over the airfield. Assembled ground crew in a group watch something off camera. Aircrew fool around. A Hurricane of 43 Squadron warms up. 501 Squadron Spitfires start their take off run. Ground crew are filmed performing various duties (re-fuelling, attaching aircraft panels) as aircraft continue to taxi, take off, land, and fly over the airfield. Aircraft seen are Bostons of 88 and 107 Squadrons and Hurricanes of 174 and 175.
The blog references here so I'll see if the he can add some info on the image source.
ah
Note LK-Q here
hurricane_87sqn.jpg&key=1bed5ac4cc03a075
LK-T looks to be a IIA .
The non standard pattern at least is fairly consistent in it's application.
11 hours ago, Troy Smith said:
This is 1 Sq
Yep- I realized what I had done  after I posted- sorry! Thanks for the correction! I have always thought that the night intruder scheme with the green/medium grey/night colors  was so neat-looking, especially with the external tanks, that I would like to do one, but don't really want to do one that has the serial overpainted. My first airbrushed model was the old Airfix Mk IV done as Kuttlewascher's IIc, using the Frog kit decals and 20mm, and I was so proud of myself that for the first time, I used a written referecne, the old Ducimus color 4-view profile, and even duplicated the doped red patches with decal stock. Imagine my heartbreak upon becoming a regular here on BM and finding out that the scheme and markings were pants, as you UK types say. I'm still in mourning! 😥 (Oh, the humanity!) Thanks for taking the time to research and answer my query.
Mike
Edited by 72modeler
corrected spelling
want the moon on a stick do we!
https://www.petermesser.com/components/com_eventgallery/helpers/image.php?&mode=full&folder=archived-work&file=The+Moon+On+A+Stick.jpgimage.php?&mode=full&folder=archived-wor
HL684,  look carefully under the tailplane.
caption
Quote
Hurricane IIc RAF 87Sqn LK Question Nightingale PO Frank Mitchell HL864
Hurricane-IIc-RAF-87Sqn-LK-Question-Nigh
so I presume that the scroll says 'Nightingale' ?
The record for HL603 simply remarks that it was a II c and that it served with 1 Sq, 539 Sq and 1 AFU before being struck off charge on 2 Aug 45.
The entry in Mason's The Hawker Hurricane (1990 Ed) says "NF. Mk. IIc  No 1 Sq Acklington; operational training 9-42 JX-I.  No 539 (Turbinlite) Sq, Acklington, 10-42."
  • 3 weeks later...
On 2/8/2020 at 6:19 AM, Troy Smith said:
@72modeler
87 Sq Night Intruder in flight photos,   will edit in more, just found something else
Hurricane-IIa-RAF-87Sqn-LKA-Ian-Gleed-BE
Can I ask the collective what the spinner color is on LK*A ? Profiles and some threads state Red, would that be correct ?
Dennis
Troy, 87 Squadron were certainly under the impression that they were putting Day Fighter colours on their Hurris in preparation for Dieppe.
Quote
For the rest of the evening [18th Aug] there were hasty preparations, studying of maps, pictures, etc.  Among other things all the Squadron aircraft had to be re-camouflaged in day colouring in a few hours.  All hands got down to this and it was completed by nightfall.
Edit: Following Dieppe, they were released, there was also a spell of bad weather, and they did not return to operations in August.  In early September they DID return to night duties in cooperation with Turbinlites, but on the 7th were taken off night duties for a period of day training.  I saw no further mention of alterations to the paint jobs, but I thought that the context might be useful.
Edited by gingerbob
I agree with WIP- especially if you compare the spinner to the red on the fuselage roundel and fin flash,
Mike
13 hours ago, Work In Progress said:
The best evidence is red
this was posted by Chris on page 1
large_000000.jpg?_ga=2.217579478.1910310
there is an enlargement showing the canopy paint flaking, so I suspect that this is the same  LK-A as above. (I need to check Air Britain as that may confirm)
The red spinner maybe a 'tradition'  or precedent set from Ian Gleed's red spinner on his BoB and nightfighter Hurricane in 1940/41, also coded LK-A, just a suggestion.
Thanks @Troy Smith... Ive seen the photo however its on the all black Hurricane. I was just trying to confirm if it stayed red when the day colors were hastily added. I am going with red as thats what the consensus say and it agrees with my views on both photo’s and profiles.
Dennis
