Mike Posted January 31, 2020 Posted January 31, 2020 Rivet Marking Tool Galaxy Model Riveting a model can make it look a lot more interesting and realistic, even though rivets in real life aren’t holes in the skin of an aircraft, but are either flush or domed. It’s nigh on impossible to achieve that effect for your average modeller though, so most of us compromise and make tiny wee holes in the skin of our models to add visual interest, then don’t worry about it, as if we did we’d also have to be concerned about over-thick canopies, panel lines and so forth. It’s best not to for your own sanity. Re-riveting areas after sanding or other damage can also be a tricky job as you have to mimic the existing pitch and size of the rivets that were there originally, keep them in nice straight lines and stop them right where they’re supposed to finish. That’s not all that easy to do well even with a riveting tool, but it’s a lot more easy if you have a good riveting tool rather than just a cheap pounce wheel or a needle chucked into a pin vice. There are plenty of choices when it comes to riveting tools from the DIY options mentioned above to other commercial offerings from various companies. This is one such commercial option, and from the time I’ve been examining it, it seems to be a good one. The system centres around an anodised black aluminium handle with brass ferule and chuck that vaguely resembles an X-ACTO knife handle. If I had one of mine to hand I would be able to tell you if the wheels fit the grooves in the X-ACTO chuck, but they’re still in storage so I’ll update this when I find them. At this stage I’m 95% sure they’d fit, but please don’t take my word for it. That said I like the handle, as it is high quality and well presented with the Galaxy Tools logo engraved through the anodization toward the back end and a bevelled rear edge, both showing off the bare aluminium. A tip for long-term happiness of your handle is to add a little grease to the screw thread that attaches the chuck to the handle in order to reduce contact and dissimilar metals (galvanic) corrosion over time, particularly if you have to place it in storage for any long periods or in damp cold conditions. The riveting wheels all share a common design but differ slightly between sets. The common features are that they are Photo-Etched (PE) from varying thicknesses of metal with a nickel plating over the top, plus branding and size details etched into one side of the flat surface. Happily the sizing remains visible when chucked into the handle, which is nice and rather practical. The riveting part is attached to the shaft by a hex bolt with a nut on the back, with the necessary hex key and PE spanner included in each set behind the foam insert, and has a smaller diameter washer to spread the load over a wider area to help prevent bending of the wheel. There are three types of set as follows: Fan “Wheel” This tool is at its most useful in tight places and for riveting ends of lines accurately, or riveting up to a perpendicular face or some other obstruction. It contains less than a quadrant of rivets in a fan shape with the rivets going right to the edges and they are applied using a rocking motion from one end to the other. Small Wheel A full 360o of rivets for carrying out general riveting along a template or ruler. It is capable of tighter radiuses if you require curved lines. Large Wheel This has a larger diameter and the shaft flares out past the edge of the wheel for a large proportion of the circumference to protect people and plastic from accidental riveting. The larger wheel also helps staying against the line when riveting longer lengths. They are supplied in plastic boxes of three for each type, with the small pitch sets having 0.75mm, 0.65mm and 0.55mm, while the larger pitch sets have 1.5mm, 1.25mm and 1.0mm sizes. You can choose which sizes and styles you want, and can also splash out on multiple handles if you feel the urge, as no-one’s about to judge you for your profligacy in search of convenience. The wheels are held in place within the latched boxes by a close-fitting dense foam insert, and on first opening you need to remove a piece of tacky plastic sheet that holds them in their recesses during transit. To get at the adjustment tools behind you’ll need to lever out the foam insert with a broad thin tool such as the rounded end of a metal rule. In Action The wheels fit snuggly into the handle, which is comfortable in the hand, and you can use the wheels to tighten or loosen the chuck by holding the knurled section still, which I found quite helpful as I’m still recovering from hand surgery (again). Some of the Nylok axle nuts were a little tight out of the box, but that’s easily remedied by the supplied Allen key and PE spanner, which is closed “ended” so you don’t slip off the nut. It's also worth mentioning that the provision of Nylok nuts should prevent or at least reduce creep of the nut in either direction, which is again another nice feature. Once you’ve experimented and got the rotation to your preferred tension it is advisable to take some time with pieces of scrap plastic or model to get used to using it and also using it in conjunction with a straight-edge or length of Dymo embossing tape. When you’re confident, you can apply your new-found skills to an actual model, using the fan wheels where necessary with either a combination of the two other wheels, or your choice of either. My experience with them was really rather pleasant, firstly running lines of each type freehand to experiment, and finding that they stay on track quite well even without a rule to follow. To make the card demonstrating each pitch I followed a PE rule that was probably a bit too shallow but still stayed on line. I slipped slightly at one point, which left a bit of a short line in the 0.65mm test but that’s down to a slight hangup on the guide that I didn't notice beforehand, not the tool. I also noticed later that I can’t draw parallel lines for toffee, so you’ll have to excuse me! The rivets are nicely formed, and once I had smeared a little ink over them to highlight them for the camera they really look the part and would blend in with pre-existing rivets if you pick the right pitch. Looking at the numbers it’s easy to think that they’re hardly different, but looking at the finished lines its plain to see that they are, and it’s important to choose the correct one if you’re repairing or extending existing rivets. It would be wise to rivet a small slip of styrene sheet and hold it up against the kit rivets for comparison, as once you’ve riveted something, it's more work to un-rivet it, which will slow your progress down. Conclusion I rate these riveting tools pretty highly and am pleased to add them to my tool kit. Whether you’re riveting a whole airframe or just adding some back where they’ve been obliterated by the build process, they’re going to be a very useful tool to have around. Highly recommended. Review sample courtesy of 2 3
janneman36 Posted January 31, 2020 Posted January 31, 2020 Great sets and they look pretty much the same as the Radu Brinzan riveters... Thank you for the review👍 cheers, Jan
Kushan_Farsight Posted January 31, 2020 Posted January 31, 2020 Any approximate price for these to the UK? There are a couple of these little riveter tools out there now but this seems well engineered, and the inclusion of the fan wheels is a very good idea for getting into those tight wing->fuselage joins. May just have to have a punt!
stringbag Posted February 2, 2020 Posted February 2, 2020 On 1/31/2020 at 4:20 PM, Kushan_Farsight said: Any approximate price for these to the UK? There are a couple of these little riveter tools out there now but this seems well engineered, and the inclusion of the fan wheels is a very good idea for getting into those tight wing->fuselage joins. May just have to have a punt! Pressing the "Available here" button takes you to their website for all the mailing options. 👍
Kushan_Farsight Posted February 2, 2020 Posted February 2, 2020 8 hours ago, stringbag said: Pressing the "Available here" button takes you to their website for all the mailing options. 👍 i dont know if it is because i am on viewing on mobile, that page just seems to take me to their contact emails, and the rivet marking tool isnt in their current catalog. just a ballpark sans shipping would do me for now, as there are alternative versions of these on the market and i just want to know how these fare up price wise before blindly ordering some. just looking at the URL header, i cant see any specific 'trackback code' specific to britmodeller, which is unsusual as thats generally how they determine commission etc on products, so im all a bit confused
Julien Posted February 2, 2020 Posted February 2, 2020 There is a link to Galaxy models , however on their catalog page where you can buy things this product is not listed. We will ask then about it. Julien 1
Richard E Posted February 2, 2020 Posted February 2, 2020 6 minutes ago, Julien said: There is a link to Galaxy models , however on their catalog page where you can buy things this product is not listed. We will ask then about it. Julien It looks like they are available from at least one Chinese vendor on that certain well know online auction site. 1
Kushan_Farsight Posted February 3, 2020 Posted February 3, 2020 Anyone know if they have an "Official" Store on any of these well known auction sites? i have found the part in question, but from numerous sellers, and i always prefer to buy direct if i can!
foeth Posted February 4, 2020 Posted February 4, 2020 If you are cheap you can raid your local antique clock shop 😁 But seriously, this looks like a nice set. 1
janneman36 Posted February 4, 2020 Posted February 4, 2020 Check this out http://www.radubstore.com/index.php?main_page=index&cPath=77_110 The same thing but allready for years available...I use them and am pretty pleased with them.. cheers, Jan
art2noise Posted December 27, 2021 Posted December 27, 2021 I know this topic is nearly a year old but they have a Facebook page. I purchased a set not too long ago but I had to contact them via email. They will send you a spreadsheet with the total costs once you let them know product and quantity. https://www.facebook.com/galaxymodelhobby Cheers, Jorge 1
woody37 Posted September 7, 2023 Posted September 7, 2023 On 12/27/2021 at 7:20 PM, art2noise said: I know this topic is nearly a year old but they have a Facebook page. I purchased a set not too long ago but I had to contact them via email. They will send you a spreadsheet with the total costs once you let them know product and quantity. https://www.facebook.com/galaxymodelhobby Cheers, Jorge I've just emailed them too. I need some rivet making tools with small wheels as the bigger ones wonder more and are unable to get close to obstacles in the way such as engine nacelles
MrB17 Posted September 7, 2023 Posted September 7, 2023 I purchased some “Rosie the Riveter” tools from UMM Tools a while back. However the owner of the Rosie the Riveter tools sadly passed away. UMM has a few left, however they also carry full stock of UBZI riveting tools, they are the same small size as the Rosie, the only difference I can see is that the handle is not wood, but laminated plastic. These are the smallest rivet wheels that I could find and they also come in double row and triple row (staggered). If you were doing a large aircraft like a B-17, the double and triple row are a huge asset. I’ve also seen the UBZI tools on eBay as well. I have used them, and they don’t wander at all. The price is a bit high, but if you want precision, there are none better. HTH Cheers Jeff
Flanker37 Posted January 16 Posted January 16 how would i go about having a custom made one in 1/33rd scale?
MrB17 Posted January 16 Posted January 16 5 minutes ago, Flanker37 said: how would i go about having a custom made one in 1/33rd scale? Are you building paper models? The wheels have different pitches (spacing), you would have to estimate the spacing of the rivets in your scale and find a pitch that comes close. Bear in mind that on a real aircraft, there are variations in the spacing and the actual size of the rivets. 1/33 is considered a large scale for aircraft, and I have seen some done using pounce wheels, which are usually available at art or craft shops. Having one custom made, might be an expensive proposition depending on materials. For a paper model, you might be able to have some wheels 3d printed in hard plastic. HTH Cheers Jeff
Flanker37 Posted January 17 Posted January 17 18 hours ago, MrB17 said: Are you building paper models? The wheels have different pitches (spacing), you would have to estimate the spacing of the rivets in your scale and find a pitch that comes close. Bear in mind that on a real aircraft, there are variations in the spacing and the actual size of the rivets. 1/33 is considered a large scale for aircraft, and I have seen some done using pounce wheels, which are usually available at art or craft shops. Having one custom made, might be an expensive proposition depending on materials. For a paper model, you might be able to have some wheels 3d printed in hard plastic. HTH Cheers Jeff there is something i want to try. yes its going to be a paper/card model. but i am going to transfer the design to the metal from a beer can [well, several beer cans] so the metal can be scored for panel lines, but i was worried about the rivets. i sure as hell didnt feel like popping them in 1 by 1. and didnt know if a 1/32nd rivet wheel would work. i mean im not entering any competitions with it. and i doubt many will see it. I am a metal fabricator in the aviation industry since 2011. and this is something i have been dying to try for a long time
