robgizlu Posted January 28, 2020 Share Posted January 28, 2020 WIP here: Thanks for looking Rob 39 Link to comment Share on other sites More sharing options...
Ray S Posted January 28, 2020 Share Posted January 28, 2020 Hello Rob, and excellent result there. The rigging and the sea base look exceptionally good too. All the best, Ray 1 Link to comment Share on other sites More sharing options...
longshanks Posted January 28, 2020 Share Posted January 28, 2020 Ah now I can see the splinter mats A great job at any scale Kev 1 Link to comment Share on other sites More sharing options...
JohnWS Posted January 28, 2020 Share Posted January 28, 2020 Looks great, Rob! I'm still amazed at the detail you've included at such a tiny scale. John 1 Link to comment Share on other sites More sharing options...
Michael M Posted January 29, 2020 Share Posted January 29, 2020 Nice one Rob, good job 1 Link to comment Share on other sites More sharing options...
Courageous Posted January 29, 2020 Share Posted January 29, 2020 9 hours ago, longshanks said: Ah now I can see the splinter mats . She looks great, nice to what can be achieved on these little ships. Care to explain you simple but effective sea base? Stuart Link to comment Share on other sites More sharing options...
beefy66 Posted January 29, 2020 Share Posted January 29, 2020 Cracking job sir you should be well chuffed with the final results great model and display👍 beefy 1 Link to comment Share on other sites More sharing options...
Silenoz Posted January 29, 2020 Share Posted January 29, 2020 Very nice result, especially when keeping in mind this is 1/700. 1 Link to comment Share on other sites More sharing options...
Jamie @ Sovereign Hobbies Posted January 29, 2020 Share Posted January 29, 2020 Lovely job Rob. It has a subtle charm this 1 Link to comment Share on other sites More sharing options...
robgizlu Posted January 29, 2020 Author Share Posted January 29, 2020 Thanks Fellas Appreciate the support and comments 15 hours ago, Courageous said: . She looks great, nice to what can be achieved on these little ships. Care to explain you simple but effective sea base? Stuart Hi Stuart I'm getting lazy in my old age and I was after a simple and quick method to display. When I have more time I'm going to try resin as per Kosatas Katseas. The method is directly lifted from Chris Flodberg who along with Kostas Katseas and Jim baumann seem to be the seascape Gurus http://www.shipmodels.info/mws_forum/viewtopic.php?f=4&t=158909&p=651903#p651903 I use "Bockingford paper Extra rough 140gm" which is dimpled and textured and frankly on it's own passes muster. I sprayed that (RLM 75), then use Liquitex "Gloss Medium and Varnish" and with the brush (as in the pic) "dapple" on gloss medium as per the Chris Flodberg direction. Do this over several sesssions, then when you are sufficiently rippled, give the whole base a further continouse layer of Gloss medium and after it's dry apply several coats of Liquitex "High Gloss Varnish". I knocked this out really quickly as a "test" piece but stuck with it. I've done a couple more base boards using different wake patterns - I've decided the simpler the better - the wake is just a Vallejo light pastel green. I've mounted the paper on a couple of "test" Daler boards which seem to be increasingly hard to get hold of. The plan was to build a couple of Tamiya Z class destroyers for practice prior to HMS Penelope, but they are actually pretty crude. We'll see. I'm clearing old unfinished builds at the moment so there's another AFV and a U-boat to finish at some point. As to the Splinter mats by the way - I hope the RFI pics above highlight them more clearly. Ned feels that Ithuriel did not have mats on the deck edges and I think he's right, so i got that bit wrong. Rather they were ?metal ??canvas strips. Rob 3 2 Link to comment Share on other sites More sharing options...
QuadrantIV Posted February 12, 2020 Share Posted February 12, 2020 On 1/30/2020 at 10:08 AM, robgizlu said: Thanks Fellas Appreciate the support and comments Hi Stuart I'm getting lazy in my old age and I was after a simple and quick method to display. When I have more time I'm going to try resin as per Kosatas Katseas. The method is directly lifted from Chris Flodberg who along with Kostas Katseas and Jim baumann seem to be the seascape Gurus http://www.shipmodels.info/mws_forum/viewtopic.php?f=4&t=158909&p=651903#p651903 I use "Bockingford paper Extra rough 140gm" which is dimpled and textured and frankly on it's own passes muster. I sprayed that (RLM 75), then use Liquitex "Gloss Medium and Varnish" and with the brush (as in the pic) "dapple" on gloss medium as per the Chris Flodberg direction. Do this over several sesssions, then when you are sufficiently rippled, give the whole base a further continouse layer of Gloss medium and after it's dry apply several coats of Liquitex "High Gloss Varnish". I knocked this out really quickly as a "test" piece but stuck with it. I've done a couple more base boards using different wake patterns - I've decided the simpler the better - the wake is just a Vallejo light pastel green. I've mounted the paper on a couple of "test" Daler boards which seem to be increasingly hard to get hold of. The plan was to build a couple of Tamiya Z class destroyers for practice prior to HMS Penelope, but they are actually pretty crude. We'll see. I'm clearing old unfinished builds at the moment so there's another AFV and a U-boat to finish at some point. As to the Splinter mats by the way - I hope the RFI pics above highlight them more clearly. Ned feels that Ithuriel did not have mats on the deck edges and I think he's right, so i got that bit wrong. Rather they were ?metal ??canvas strips. Rob Ah! I have been looking for such a simple and understated technique for two 1/700 ship models that I have recently built..one being IJNS Chokai and the other being HMS Glowworm. Thank you and Chris Flodberg. Link to comment Share on other sites More sharing options...
Bugle07 Posted February 23, 2020 Share Posted February 23, 2020 Top job there, a great finish all round! Well done! Geoff 1 Link to comment Share on other sites More sharing options...
Nobby57 Posted February 23, 2020 Share Posted February 23, 2020 Excellent work. I like the clean finish you've achieved. It displays how nice these kits look. Must try one and hope it turns out better than an old Pit Road O class I seem to remember making about 30 years ago. Thank you for a great share. 1 Link to comment Share on other sites More sharing options...
Terry1954 Posted February 27, 2020 Share Posted February 27, 2020 Entirely missed this Rob, and the WIP. Lovely result. I'm easing myself back (after 45 plus years) into 1/700, but it's challenging - eyes mostly! I'll spend some time retro studying (is that a real phrase?) the WIP. Thanks for sharing. Terry 1 Link to comment Share on other sites More sharing options...
