ProjeKtWEREWOLF Posted January 28, 2020 Share Posted January 28, 2020 I snapped a tiny pcb drill bit while trying to make the aerial attachment hole bigger in a tamiya chieftain mk5. Dammit. The first hole went fine, but the second snapped flush. I can't reach the inside and now it is stuck. Any ideas what to do? Link to comment Share on other sites More sharing options...
modelmaker Posted January 28, 2020 Share Posted January 28, 2020 it depends upon luck and what size the bit was; I have a trick which CAN sometimes work, by possibly pushing the bit through, if indeed your broken bit had broken through. if it hadn't then you might be scuppered. drilling a horrible hole alongside it then carving the broken bit out then re-filling the mess, but it'll be horrible to do. so, if the bit HAD broken through you might try a tiny homemade punch; take a piece of Bowden cable (like a bit of bike brake cable, or meter sealing wire if you work in my industry!). carefully peel away all the outer strands and you will be left with a straight length of hardened steel cable. cut off a short length and chuck it in a pin vice so only a tiny bit protrudes, and dress the end you cut to make it clean. if the broken bit broke through you MIGHT be able to push, or punch it through. if nothing else this thin steel 'rod' is great for making splints in broken undercarriage legs and many other things. very best of luck, although I don't think this WILL work, it might, it has for me JD 1 Link to comment Share on other sites More sharing options...
ProjeKtWEREWOLF Posted January 28, 2020 Author Share Posted January 28, 2020 Well. It's out. I had to remove the raised detail where the aerial is inserted. I will have to sculpt *something* to replace it. @modelmaker I tried the wire thing but it failed, so I used a bigger carbide drill bit. Made me sad. Thanks for the advice. Link to comment Share on other sites More sharing options...
Red Five Posted February 7, 2020 Share Posted February 7, 2020 I put a 0.8cm drill bit about 1/4inch right into the very top of my finger last week ouch Link to comment Share on other sites More sharing options...
