Sign in to follow this
mastic
weapons
Hi all, i am currently building a 75mm figure but would like to add a couple of arrows and spears into the diorama. What is the best thing to make them out of please, newbie to making my own stuff by the way so go easy on me please😟
I'm not a figure man but I'd you use metal rod of the appropriate diameter.
Stuart
Hi @mastic in 75mm the (broken?) spear(s) I would suggest either a wooden cocktail stick or a barbecue skewer, cut to length, nowt better than wood for wood!
As for arrows, the suggestion made by Stuart @Courageous above makes good sense, as you can get metal rod from https://www.albionhobbies.com/
in a variety of sizes.
Paul
Thank you, I was worried a cocktail stick maybe be out of scale and the rods looks exactly what i need. I don't mind using a bit of green stuff to make arrowheads and the wrapping for the spear. Thank you once again
Make sure the arrows are the correct length too. Often they are way too short. I've not tried the before but I'd probably go for a relevant metal rod painted and paper for fletching. Good luck with it.
