AltcarBoB Posted January 18, 2020 Share Posted January 18, 2020 (edited) This is the first of a series of 1/72 monoplane fighter aircraft I am planning to work on that were built as paper planes, as prototypes, or limited production by the 2nd Division European powers. I have always been fascinated by the oddballs, never weres and didnt get a chance aircraft. So far I have in my little stash from the Netherlands Fokker DXXI, Koolhoven FK58, Polish PZL 50, Yugoslavian Rozogarski IK3 and Czech Avai B35. More will be added to the stash as I spot them online. Fokker DXXI by MPM a short run kit of the Danish Airforce prototype cannon armed version. It wasnt successful as the pair of big heavy Madsen 20mm cannon were too heavy for the 645hp Bristol Mercury XIS engine, even though the Madsens 20mm x 120mm ammunition packed a real punch. The sprues are quite clean with only some small flash and ejector pins. I built the cockpit carefully painted it and found out it didnt fit and needed some serious emery stick action. The fuselage halves and the panel lines matched quite well but the lower wing didnt want to fit and needed some very careful work with a scalpel I am still not happy with the fit of the rear of the wing. The wing tops also needed some work to fit against the fuselage and I have had to do some filling. I wanted to cut the undercarriage legs so it would look like it was on the ground with the oleos compressed. I drilled down through the legs with a 0.50mm drill bit then cut a section out of the legs and glued it back together with brass wire to add strength. IMG_20200113_122817999 by Stuart, on Flickr IMG_20200115_185938319 by Stuart, on Flickr IMG_20200117_234536524 by Stuart, on Flickr IMG_20200118_144355640 by Stuart, on Flickr IMG_20200118_144432401 by Stuart, on Flickr IMG_20200118_144412735 by Stuart, on Flickr IMG_20200118_174940271 by Stuart, on Flickr IMG_20200118_181038028 by Stuart, on Flickr IMG_20200118_181653833 by Stuart, on Flickr Edited January 18, 2020 by AltcarBoB added info 6 Link to comment Share on other sites More sharing options...
dogsbody Posted January 18, 2020 Share Posted January 18, 2020 Looking good! Chris Link to comment Share on other sites More sharing options...
Courageous Posted January 18, 2020 Share Posted January 18, 2020 Coming along quickly and looking good. Nice to see these lesser known types. Stuart Link to comment Share on other sites More sharing options...
AltcarBoB Posted January 19, 2020 Author Share Posted January 19, 2020 I have managed to screw up making the propeller by supergluing one of the blades into the hub backwards. I have cut it away turned it and reglued it but it looks horrible and wonky. Anyone know of an aftermarket propeller that would suit the Fokker, I have measured the prop as having a blade length of 22.5mm which scales up to 3240mm or 10 feet 7.6 inches. I have googled for a replacement till my eyes are on the point of bleeding but no joy. 🤔 Link to comment Share on other sites More sharing options...
AltcarBoB Posted January 23, 2020 Author Share Posted January 23, 2020 Well after a hiatus whilst I hunted for a replacement prop that didnt cost more than the kit I have found a prop which was from a Bristol Mercury engined kit. The hub needed a good filing because it was meant to have a spinner over the hub but its good enough for my wonky eyes. Masked the cockpit canopy, finished the tail and given everything a wet rub down with 6000 grit MicroMesh. Wow the Micromesh is good I have removed a glue fingerprint and you cant see where it was, so smooth. I am going to give it a coat of gloss black before topcoating it with Tamiya Flat Aluinium. IMG_20200123_182946155 by Stuart, on Flickr IMG_20200123_182813529 by Stuart, on Flickr IMG_20200123_182838836 by Stuart, on Flickr 4 Link to comment Share on other sites More sharing options...
David Hényk CZ Posted January 24, 2020 Share Posted January 24, 2020 Little inspiration for you 😉 not cannon version though. https://www.tapatalk.com/groups/72nd_aircraft/viewtopic.php?p=107720#p107720 1 Link to comment Share on other sites More sharing options...
AltcarBoB Posted January 24, 2020 Author Share Posted January 24, 2020 (edited) Just given it the first blow of two of Airfix Acrylic Gloss Black as a base for the Aluminium paint. Everything looks good in black. Spotted that I need to do a bit more sanding on the cowling. I was going to use Tamiya Flat Aluminium XF16 but a test of it left me a bit unimpressed it looked very grainy, whats everyones favourite Aluminium paint brand. I like Vallejo Air paints so I was thinking of trying that. IMG_20200124_114702485 by Stuart, on Flickr Edited January 24, 2020 by AltcarBoB 2 Link to comment Share on other sites More sharing options...
