busnproplinerfan Posted January 18, 2020 Share Posted January 18, 2020 Is there such a thing like a number 11 blade for example with a right angle bend part way along the blade to the side? Link to comment Share on other sites More sharing options...
Schwarz-Brot Posted January 19, 2020 Share Posted January 19, 2020 How would one cut with that? Sounds more like a punch and die affair to me. So - nothing I'd know of. Link to comment Share on other sites More sharing options...
busnproplinerfan Posted January 19, 2020 Author Share Posted January 19, 2020 15 minutes ago, Schwarz-Brot said: How would one cut with that? Sounds more like a punch and die affair to me. So - nothing I'd know of. I think I saw something like it for clay carving. I want to cut sideways in a narrow cavity in mold rubber. Link to comment Share on other sites More sharing options...
bootneck Posted January 20, 2020 Share Posted January 20, 2020 Could that be a No.9 blade from Swann Morton? Mike Link to comment Share on other sites More sharing options...
busnproplinerfan Posted January 20, 2020 Author Share Posted January 20, 2020 6 hours ago, bootneck said: Could that be a No.9 blade from Swann Morton? Mike No, that's not it. Think it's something like a spoon carving knife, but rounded. Thanks bootneck. Link to comment Share on other sites More sharing options...
bootneck Posted January 20, 2020 Share Posted January 20, 2020 How about these? The centre group have V and crescent (spoon) shape cutting edges. The two V blades, 6th and 7th from the right, are good for cutting flow channels in casting moulds. I believe they can be obtained at Michael's, or equivalent and are quite cheap. In UK, I think they are available in The Works. These are my 'go to' tools for scratchbuilding. The models under construction in the background are to 1:144 scale, with a 1:350 scale Sea Vixen tucked in there as well. Mike 4 Link to comment Share on other sites More sharing options...
dogsbody Posted January 20, 2020 Share Posted January 20, 2020 Do any of these Xacto blades fit the bill? The one on the far right is a regular No. 11 blade. Chris Link to comment Share on other sites More sharing options...
busnproplinerfan Posted January 21, 2020 Author Share Posted January 21, 2020 Thanks, these would but I have to get into a small narrow "valley" in the mold rubber and cut horizontally. I was thinking of taking a strip of metal and bending a right angle about a half inch or so long on the flat edge and sharpening the edge. Link to comment Share on other sites More sharing options...
dragonlanceHR Posted January 21, 2020 Share Posted January 21, 2020 For a similar scraping problem in a narrow space I used an old Excel No. 11 blade. Heat it with a pen torch, bend the 2-3 mm of the tip 90° with small pliers, then dunk in oil. I needed the back of the blade and not the edge, but it should remain sharp long enough for your cut. Cheers, Vedran Link to comment Share on other sites More sharing options...
busnproplinerfan Posted January 21, 2020 Author Share Posted January 21, 2020 4 hours ago, dragonlanceHR said: For a similar scraping problem in a narrow space I used an old Excel No. 11 blade. Heat it with a pen torch, bend the 2-3 mm of the tip 90° with small pliers, then dunk in oil. I needed the back of the blade and not the edge, but it should remain sharp long enough for your cut. Cheers, Vedran I didn't know you could bend those blades. I guess if you heat it, you take the temper out of it. Like the idea. I'll ask one of the mechanics at work for a pen torch or something similar. Thanks. Link to comment Share on other sites More sharing options...
busnproplinerfan Posted January 22, 2020 Author Share Posted January 22, 2020 On 1/21/2020 at 8:40 AM, dragonlanceHR said: For a similar scraping problem in a narrow space I used an old Excel No. 11 blade. Heat it with a pen torch, bend the 2-3 mm of the tip 90° with small pliers, then dunk in oil. I needed the back of the blade and not the edge, but it should remain sharp long enough for your cut. Cheers, Vedran Hi Vedran, I tried you idea and it worked, to easy. Actually, the mechanic at work who did the work for me was from Yugoslavia way back. He's going to retire this year and move back to Croatia. 1 Link to comment Share on other sites More sharing options...
xffw45343tg Posted January 22, 2020 Share Posted January 22, 2020 On 1/20/2020 at 5:41 PM, bootneck said: How about these? The centre group have V and crescent (spoon) shape cutting edges. The two V blades, 6th and 7th from the right, are good for cutting flow channels in casting moulds. I believe they can be obtained at Michael's, or equivalent and are quite cheap. In UK, I think they are available in The Works. These are my 'go to' tools for scratchbuilding. The models under construction in the background are to 1:144 scale, with a 1:350 scale Sea Vixen tucked in there as well. Mike May I ask where you got the razor saw? I have about 3 and they are all too thick for the task in hand (I want to separate the doors and boot, with their curved edges, from a 1:24 Mini). Apologies for the thread hijack! Link to comment Share on other sites More sharing options...
Admiral Puff Posted January 22, 2020 Share Posted January 22, 2020 Not Bootneck, but that looks like a JLC razor saw. Great bit of gear - I wouldn't be without mine! I got mine through Red Roo, but it should be available from most tool suppliers. Link to comment Share on other sites More sharing options...
dogsbody Posted January 22, 2020 Share Posted January 22, 2020 14 minutes ago, Kirk said: May I ask where you got the razor saw? I have about 3 and they are all too thick for the task in hand (I want to separate the doors and boot, with their curved edges, from a 1:24 Mini). Apologies for the thread hijack! CMK saw blades are available on-line from various sites. Ebay has them. I mounted one of mine in a large Xacto handle. Works pretty good. I also put a piece of a broken blade in pin vise handle. It has it's uses too. Chris 1 1 Link to comment Share on other sites More sharing options...
busnproplinerfan Posted January 23, 2020 Author Share Posted January 23, 2020 I have to find one of those cmk type saw blades. I'm sure those other tools shown can be useful. Have to find some to. Link to comment Share on other sites More sharing options...
bootneck Posted January 23, 2020 Share Posted January 23, 2020 8 hours ago, Kirk said: May I ask where you got the razor saw? I have about 3 and they are all too thick for the task in hand (I want to separate the doors and boot, with their curved edges, from a 1:24 Mini). Apologies for the thread hijack! You can get them in UK from Paul at Little Cars. He also carries spare blades and mitre blocks. Mike 1 Link to comment Share on other sites More sharing options...
