LostCosmonauts
Carrier landings with a twin fuselage aircraft
Mornin’ all
Quick question on this never made Cold War oddity
I’ve been having a look at the Vickers Type 582 with a view to modelling both proposed RAF and RN variants and would appreciate ideas from the BM hivemind on they might have hooked up a twin fuselaged plane for catapult launch or have attached an arrestor hook. There don’t seem to be many details of the type other than a 3-view outline and a couple of artist’s impressions.
In the absence of detailed drawings any suggestions on how to add the practicalities that Vickers didn’t?
I think you're seeing one of the many reasons why it didn't happen!
The only real way of putting a hook on it would be a truly massive one extending down and back a long way from the centre of the bomb-carrying central wing section, and the structural issues would be horrendous.
Seriously, the single-fuselage version of the 582 proposal would have been far more credible as a naval aircraft. If you want to build two anyway, why not have one of each of the two proposals? An RAF twin-fuselage one and this Navy version?
Edited by Work In Progress
Fair point, well made @Work In Progress - I was half hoping that I'd get twice the bang for my buck and be able to make two models from the same bit of drafting work but you're probably right. Single (or triple depending on how you look at it) fuselage for the Navy and twin fuselage for the RAF unless some bright spark can come up with a better solution
I thought those were the engines in the central wing section.
The nearest I can think to your arrestor hook problem, is the Sea Vixen:
Obviously that doesn't help with the launch.
Yes, you're right, I should have said that.
The Vixen is indeed the only vaguely usable point of reference and look at how long its fuselage is, it goes a long way back aft of the main wheels, enabling the hook to be in a reasonably sensible place.  And it is the main structure of the aircraft.
Then imagine how far a hook would have to extend back and down from the wing centre-section of the wing on the twin-fuselage version of the 582, and how those stresses would feed into the structure.  Even a normal carrier landing exercises about 2.5 x the weight of the aircraft on the root of the tail hook so it's a hefty pull, plus you have to allow for snatches and jerks and off-centre loads. All on a piece of structure that has to then feed that retardation into the twin fuselages where most of the mass is.
download
Sea Vixen had been my reference point as well. Had been eyeing pictures and came up with exactly the same problems
I also wasn’t sure about stores though. Bombbay in the right fuselage, under the central wing and/or  outer wings?
You are going to need a first class honours degree in Origami to fit either into the standard flight deck lift irrespective of where anything is.
Dennis
On that 3-view of the twin fuselage version it looks like a biggish bomb bay under the wing in each fuselage. Does that look about the right shape and size to be a Red Beard?
7 minutes ago, Work In Progress said:
Good point. Any dimensions knocking about, LostCosmo?
Not in the house right now but from memory the right fuselage was almost spot on 20m long. 3 view drawing is on my WIP thread in the “They Also Serve” GB
That was my first thought but the sketched bomb in the side view looks like it would clash with the landing gear
well, we have no great reason to think ANY of it is particularly well thought-out...
I quite like the notion of all these tiny screaming mini-Speys blowing the wing and tail though.
Visually it looks more like an Ekranoplan than a flying machine: now that could be an interesting concept !
Dennis
Might have fitted the lifts of the cancelled CVA-01 of the 1960s. Her lifts were to be 70ft long and 35ft wide forward and 70x32ft aft (deck edge so it might have been able to be a bit wider) both rated at 75,000lb.
In the drawings the MLG retracts rearwards and the top of the leg is offset inwards. I imagine one bomb and t'other side being a big fuel tank.
If it doesn't look right there's something wrong going on — and this asymmetric beast looks like trouble for everyone concerned.
Tony
Tony
RE: gear folding away. Ah-ha! good point. So the bombbay and gear door on the cockpit side would be one integrated piece and on the other just the gear door. I think (for the purposes of the model I can make that work)
RE: not looking right. Think of it as two F-104s flying in intimate formation - what could possibly go wrong?
Now, now .... dont diss my favourite machine ;)
Martin
Heaven forbid. The Starfighter is a beautiful and elegant plane. Even detractors will admit that the F-104 was the most dramatic way found of creating smoking craters around Western Europe since the last Grand Slam was dropped. ;)
...and that’s without anyone even considering landing one on a carrier, which is where we started.
With an F-104 it's enough to be able to launch it, use the ZELL to give you a solution similar to the CAM Ship Hurricane launch
16 minutes ago, RODH2 said:
Two hooks, surely!?   🤔
A possible solution with one serious drawback: if one hook catches correctly and the other doesn't the aircraft would swing to one side very dangerously, more so as standard procedure is to apply full power as soon as the pilot believes the hook has caught the wire
Yes, I'm thinking current day double-redundancy and electronic interlocks, so I will try again with my '60's cap on!  🤔😄
The Hurricat launch might have been OK, but recovery...?
“‘Once the rockets are up who cares where they come down?  That’s not my department’, says Werner von Braun” [Tom Lehrer]
The launch is the easy part. You would just use a bridle like many of the aircraft of the period (like F-4's and A-4's).
