Smudge
Revell 1/72 Junkers Ju-87B/R Stuka
Hello, Chaps.
I have been having a sort out of my kit 'stash' and found this oldie, and thought about 'disposing' of it. Then I saw the Stuka GB, and thought I might join in, if I may?
Probably have a root about for some decals, as I'm sure I have a couple of Stukas on some 'mixed types' sheets.
I always liked the engine detail on this one, so might have a bash at doing something with that.
2020-01-16_10-21-18
2020-01-16_10-21-53
Thank you.
Great idea to build this kit here instead of binning it :thumbsup:  and of course you can join, no permission needed.
Even though an old kit, I am sure you will enjoy the build.
Cheers, Peter
Hi Smudge,
I did start this same kit at least 20 years ago! Only difference, mine is molded in dark green plastic.
It has some decent details for its time, and I am interested to see what it will look like when you are finished with it!
Have a lot of fun!
JR
Nice choice Smudge I'm really into these older kit's right now and this one does look a beauty.
Thanks, Guys.
For an old kit it does have some very nice panel line and surface detail. Unfortunately the canopy is all one piece, but the cockpit is of course quite sparse, so maybe no bad thing. Looks like it should scrub up ok though.
Ok, so were off.
This is the radiator front fitted inside the nose.
20200121_194937
Some nice cockpit detail. (for it's time!)
20200121_195404
Test fitted in place, with the control panel and engine bulkhead cemented in.
20200121_195043
Some parts cleaned up. The prop and spinner are all one piece, and needs a little bit of attention.
20200121_195230
The engine. Possibility of leaving the cowling off and doing some detailing. Need to find some references really.
20200121_195314
20200121_195303
The one part canopy. I think I might have a go at cutting this into the various sections, for an 'open' look.
20200121_195132
Enjoyable work so far.
Thanks for looking.
I would think twice about cutting that canopy.  It looks rather thick and  might not sit well when open. You could try a vac canopy.
I do concur with Greg. Cutting this canopy may end up in disaster!
This looks good!
JR
Yes, I have to agree. It doesn't look promising :(
I'll have a think about it.
Thank you, Basilisk. It's really quite a nice kit.
Been tinkering away. Here are a few pictures.
This is the kit instrument panel and decal.
20200203_193630_001
And the cockpit, with some tape seatbelts.
20200203_193936
20200203_193945
Probably won't be able to see much through the canopy, but we'll know it's there.
The wheels are really rather good, which is a shame as they are now hidden in the spats. The spats need a little persuasion to fit tightly together.
20200203_193811
This is the underside of the wings. The flaps and ailerons are all one piece. I should probably try and separate them.
20200203_193828
I'm still not sure what 'scheme' to finish it in.
Thanks for looking.
Looking good 👍
Keep up the good work! 🍺 Greg
Coming along nicely.  Do a desert scheme. This way if you miss painting a bit you won't notice. 🙂
20 hours ago, Greg Law said:
.........Do a desert scheme. This way if you miss painting a bit you won't notice. 🙂
Ha ha, yes, I am leaning towards that :D
20200203_193630_001
20200203_193936
20200203_193945
20200203_193811
Hi, Smudge,
good progress!!!
This old kit is quite surprising, as it offers the occasional very detailed parts.
The IP decal is actually spot on: a perfect rendition of the original, at a time when few manufacturers offered more than a flat piece of plastic or some crude, raised lines supposed to look like dials!
The wheels are actually better looking than the ones in the "new tool"Airfix I am busy building.
As for the ailerons and flaps, I did separate them from the wing... Although it allowed me to make everything razor sharp, I have regretted my decision ever since...
My advice: if you want a fairly quick build, don't!
Keep having fun with this Stuka
JR
Thanks @jean. Yes the instrument panel decal is very nice, better than in some modern kits. All the dials are very clearly printed.
Advice heeded for the flaps/ailerons :)
I think I have decided on a scheme. I have two decal sheets which have markings for a Ju-87R-2/Trop of 6/St.G 2 with the 'Sand Snake' marking.
Almark with the sand coloured snake
20200207_211604
And Crazy Modeler with a red coloured snake.
2020-02-07_09-23-58
There are a couple of other choices, but I'm really drawn to the red snake marked T6+MP.
The red snake divides opinion as to whether or not it was ever red, the sand coloured version being the accepted colour. However, as building this old Revell kit is just a bit of fun, well why not.
I do like the 'red circle with the dog' marking of II/St.G 2 but the overall finish is a little dull, being green over light blue.
So many choices :unsure:
Just build it the way you want. If you like the red snake use it.
My build is going so fast now it will be held up waiting for my decals to arrive.
Kit cockpit did indeed look less complicated in old kits.
If you like the red snake, go with it :thumbsup:
Cheers, Peter
The snake is supposed to be sand colored and possibly only on one side.... Life is too short for this type of scheme!
I will join the general chorus: "Do it red, and do it on both sides!!!!"
I have always dreamed of doing such a Stuka.
Enjoy.
JR
Most of the construction and filling is now complete. I decided against leaving the engine exposed as obviously this would have required quite a bit of additional scratch building, and in any case would not really suit the 'Desert Snake' scheme. The join of the cowling is not great, so I used a little filler, but I'm not sure if I have gone too far, as I think maybe the real thing wasn't great at this point?
I did cut out the rudder and replace it slightly offset, and ran a razor saw between the flaps and ailerons for some added detail. Also had to add the machine gun armament to the wings, as these were not represented in the kit.
2020-02-20_10-38-49
I opted for the long range tanks, as the bombs weren't great, and these seem to be more suitable for an 'R version.
2020-02-20_10-39-08
Need to start sorting out my paints.
Cheers.
That's coming along well. I think the wing tanks were a good call.
Very neat build on an old kit. Looking good.
