Doccur
Airfix RNZAF Mustang IV
Greetings,
I wish to get involved with this GB with this little Airfix mustang that I bagged for about a fiver from Aldi (or Lidl I can’t remember). Not being particularly fond of the stars and bars, I found a nice decal sheet with a lovely 2 Squadron RNZAF aircraft. I seem to have a a soft spot for a nice roundel with a checkerboard. This should hopefully be a relatively quick and straightforward build once I get started! Famous last words...
Ash
Good evening Ash
Welcome aboard and have fun ..
Patrice
Always nice to see an RNZAF (TAF) Mustang
A little bit about your particular airframe (2nd page in link)
NZ2419
( I have No connection to Ventura products what so ever)
Look forward to your build
Regards
Alan
Thanks so much @LDSModeller! Do you happen to know if this particular machine had anything different from the standard ‘D’ mustang? I see in one of those photos NZ2419 has the cuffless prop?
Ash
Ash
Hi Ash,
RNZAF P51D's were pretty much stock, exception being they all ( bar one NZ2413)
had cuff-less props (NZ2413 has standard cuffed prop)
Hard to tell from the photos, but the airframe may have been natural metal or
painted in High Speed Silver (HSS), if HSS then the area around exhaust shroud
was natural metal. Prop nose cone most likely NM
Hope that helps?
Regards
Alan
had cuff-less props
Thanks Alan, I’ll have to source a replacement.
The article suggests a NMF so I’ll go for that, maybe add a couple of different shades on the occasional panel.
Cheers for the help!
Ash
I can send you an Airfix prop if it helps. PM me.
Martin
Edited by RidgeRunner
Thanks to Martin I now have a nice shiny, cuffless prop! Many thanks mate!
Ash
Hi Ash,
Just looking at your photo above (couldn't see them on the kit sprues)
the Rocket Stubs can also be utilized (just remove the rockets) to add
to your RNZAF Model
A colour photo I manged to find (from when Photo Bucket went pear shaped),
you can see the stubs  under the wings
(Image used for Illustration purposes only)
Regards
Alan
Thanks Alan!
I shall definitely have to get the stubs on the wings in that case!
Regarding the finish of the aircraft, it appears to be all over NMF, just with a different shade around the exhausts. Also the tail appears to be a different shade, silver?
Ash
Hi Ash,
Yes, I would agree overall NMF, with exhaust staining/metal discolouration around
the the exhaust.
The Vertical Stabilizer certainly looks Silver, may very well be a replacement from an
airframe Struck off Charge, and reduced to produce, that had been painted with HSS?
Regards
Alan
Alan,
glad we came to the same conclusion... the replacement tail also seems like a plausible explanation! Can’t wait to get started on this Kiwi Pony now 🕺
Ash
The rudder would be painted, because it is fabric-covered, but the vertical fin doesn't look any different to me than the rest of the fuselage (which I agree is naked metal).  As for the wing... ?
Remember to drill those holes before cementing, Ash ;)
Looks NMF to my eye? What do you think?
I’ll try my best... my young mind can end up being distracted however... 😂:whistle:
I'd say that at least the LE is painted, but maybe my interpretation is wrong :)
Do it now, Ash. Its never too soon! :)
Given that these Mustangs were part of the Territorial Air Force as
an arm of the RNZAF, they were only flown (generally) on the weekends
and on RNZAF exercises
The Colour photo above shows NZ2423 as part of 42 Squadron RNZAF
based at Ohakea between Oct 1955 and early 1957 after serving with
TAF 2 Wellington Squadron previous from  July 1954.
Looking at inflight shots of TAF Mustangs, the wings appear to be
Silver (or HSS). I would put the colour photo as an Airframe silver on the wings,
also found on other RNZAF aircraft during that period.
The wings may or may not be puttied, if the putty fell out/ was removed during
overhauls, it was not replaced.
Regards
Alan
Hi all,
I’ll settle for silver wings and rudder, with the rest being NMF!
cheers
Ash
Hows this one going, Ash?
Hi Martin,
just finished off the hunter last weekend so hopefully I will make a start on this shortly.
cheers
Ash
Finally made a start! Painted the interior In ModelMaster interior green with some black details. Not too keen on airfix’s decal instead of raised instrument panel detail. Especially when the decal film is bigger than the instrument panel! Got myself a new phone this week so the quality of my photos has improved somewhat ☺️
Also just received some Vallejo paints which I will be trialling with this build. I am trying to find the ideal acrylic metallic colours to spray and hopefully these do the trick. I have silver (for HSS), Aluminium and Chrome.
Ash
I used Vallejo metallics on my two Mustangs and am very happy with the results.  They are very thin and will run if you spray from too close even with the pressure turned down low, I think mine was 1psi.
AW
Edited by Andwil
Added extra info
Thanks @Andwil
What a good finish you achieved with those! I’ll have to shoot some of the Vallejo onto my paint mule first to get a feel for it.
Ash
Hi all,
Got the fuselage halves together along with the wings. Gave the cockpit an oil wash and some tape seatbelts beforehand. All the parts were very tight fitting. Only annoying thing was that one of the wing tips is bent slightly 🤦🏻‍♂️ Only noticed when I glued it.
49504423543_971abb23d1_b.jpg 49505151492_98f3b4c09b_b.jpg 49504423873_9143a3a4df_b.jpg
Ash
Completed some more assembly on the Kiwi Pony. This kit is going together like a dream. Sanded all the seams on the fuselage, cemented the wings the air intakes. Also got the rocket stubs on. Was going to have the flaps down but reconsidered after I saw what a pain it would be to mask. Quick question for you mustang buffs. The posable vent on the bottom of the rear fuselage, would this usually be positioned opened or closed while on the ground. (P.S like all of us who have or are building this kit, the control column did break when cutting it off the sprue 🤦🏻‍♂️)
Ash
