Tiger Posted January 14, 2020 Share Posted January 14, 2020 Hi with me being new to plastic kit modelling I was not sure which glue to go out and purchase. There are many on the market, so I bought some Humbrol liquid poly. Will this be good enough to use on my AFV models or should I have picked another brand like Tamiya. Any advice will be greatly welcomed.. Link to comment Share on other sites More sharing options...
Graham Boak Posted January 14, 2020 Share Posted January 14, 2020 It'll do perfectly well for any of the polystyrene kits. You will need something else if you want to try resin or etched metal aftermarket parts, kits, or just the detail parts included in many kits nowadays, but worry about that when you come to it. If you are doing any aircraft, or parts with transparencies, then you are best using something else anyway, one of the PVA based white glues. 1 Link to comment Share on other sites More sharing options...
Tiger Posted January 14, 2020 Author Share Posted January 14, 2020 2 minutes ago, Graham Boak said: It'll do perfectly well for any of the polystyrene kits. You will need something else if you want to try resin or etched metal aftermarket parts, kits, or just the detail parts included in many kits nowadays, but worry about that when you come to it. If you are doing any aircraft, or parts with transparencies, then you are best using something else anyway, one of the PVA based white glues. Thanks Graham for the reply to my question, this helps a great deal and I know I’m on the right path. Link to comment Share on other sites More sharing options...
