Sign in to follow this
markmcguire25
MQ-8 Firescout UAV 'copter
This is the third kit I've built from this manufacturer. For limited run resin, their gems. They do a nice job of using different types of resins to accommodate the build of the kit; hard with fine lines for certain parts, softer to allow for some flex on others, etc.
Unfortunately, one of the landing skids was broken from the start. So I tried soldering on this kit. I think my results were a bit mixed from the perspective of fine detail, but no doubt the parts are much stronger and able to absorb handling.
oiFhaJ6bnuh_iQC3jhRQHqCHjyoHQ42wcobFRjx9
-9GMkaBKoVe3A-h56BawmvXX1PyGJ3XxUsVsy0ii
GXn3FyFiisiRvWCnltu5cCEEozQLYTkWxMWe6yqF
ka_NymwLvNURgAeOQdI4aeAE7qR6fFNIPvI75I3o
ErWhsDSymRYahVNbXwEuFi-eZZlY_-2-mdSazSpD
xQgkAUVKQG9ydmn32EqiVcOTQbnKQS37vgwET2_f
7scFqs1X6I8WxPL3qAkv6DX5KVyWq9ONMe7pLdwo
IKyKNffLkn2HkxQj0BZDIm4FfGnFmMWIVsZrJbgJ
BTW - all these pics were taken with a Galaxy s9+ phone and several photog lights. In less time than it usually takes me to set up one shot on my Canon DSLR?!? I'm either dong something right with the phone, or VERY wrong with the Camera.
xO5JRAnuBbH39T7ZyY37-Wbxn_nWzrn2Gmbzwka_
this is a jig I used to get the rotors lined up. It was a scrap piece from a previous project, and made lining up the blades pretty easy.
FuVG3W-vmt7atwPDG-gCYYcxi47C-Z3kUFe5v896
Drilled holes for the brass rod in preparation for the new landing gear
llkH9RUF-h3kgaxEHlFJbb8IxlWPz1rpGavD8NTf
Getting the angles correct for the legs. you can see the solder at the bottom. You can also see the the one good skid just to the right.
_hxnW7AWa6QBQuyv6e8Qarw2R0U1xsDWDKTpjKeK
Test fitting the struts to the airframe. You can see the high quality finish on the resin parts (I have no affiliation with the company, I'm just impressed with the finish and fit of these kits)
vzcpz0poHOAdLdqdDEUuVQuk6nHQhnno7yYnPDIE
Skids are bent and matched for solder
HBPRPVLIvcRPuwjU1CGUZpgBqnFNz-fxqFJ6uxji
PA5RavQqJs8Y4FrK7MWHUNA2889yHDD_ePoB-2yI
Still some final sanding and shaping, but not too bad for my first try!!!
i1TChQkrLzxjoInm4YLZ0LeL89VSewyPIvGyQobE
Mark
Nice!
I built one of those, and it is a nice kit!
Are these things real? It's got a steampunk look about it.
very nice, and well used :)
That looks very smart, well done!
Lovley
