PeterB Posted January 30, 2020 Share Posted January 30, 2020 Hi Dave, Your technique with micromesh certainly seems to work - well done! Pete 1 Link to comment Share on other sites More sharing options...
reini Posted January 30, 2020 Share Posted January 30, 2020 What's a micromesh? Link to comment Share on other sites More sharing options...
Rabbit Leader Posted January 30, 2020 Author Share Posted January 30, 2020 56 minutes ago, reini said: What's a micromesh? A US produced polishing system designed to restore clarity on clear / transparent surfaces. I just use small segments of the various grades of sanding cloths. A typical box comes in 1500, 1800, 2400, 3600, 4000 & 6000 grades and you use them like most other sandpaper products from course grade to fine. Once the 6000 is used, I then polish the clear parts with various non sanding cloths and apply a coat or two of Clear to finally restore the finish. I don’t use it on all my canopy’s, however it’s very handy when canopies (often) don’t line up as well as I like. Cheers.. Dave 2 2 Link to comment Share on other sites More sharing options...
SoftScience Posted January 30, 2020 Share Posted January 30, 2020 It's been nice seeing this kit get a slight upgrade. The canopy fix is interesting to watch. As for the shallow gear bays - unless you put the model on a mirror; nobody, including you, is going to be looking down there. I think your solution of plastic insert painted black is sufficient! 1 Link to comment Share on other sites More sharing options...
trickyrich Posted January 31, 2020 Share Posted January 31, 2020 8 hours ago, reini said: What's a micromesh? these are the beasts....would never leave home of the hobby bench without them! A real lifesavers for those canopies with the mould lines down the middle! (F-16, F-14 etc) https://www.amazon.com.au/MICRO-MESH-SOFT-TOUCH-SANDING/dp/B000H6EC4C Lovely work Dave!! 2 Link to comment Share on other sites More sharing options...
Rabbit Leader Posted February 2, 2020 Author Share Posted February 2, 2020 Update #5 - Masking & Painting begins! I really wanted to get more modelling done this weekend, however Mrs RL had better ideas which resulted in more house tidying and three seperate trips to the dump. On the plus side, I did start my Norwegian F-5A GB thread and applied the initial layers of paint to this Safir. I also got to see the new "Midway" movie, so not a bad weekend after all to be honest. So after all the time spent blending the canopy piece to the fuselage, I didn't want to muck it up by doing a bad masking job. The proof of my success will be proven (or horribly realised!) later, however I took my time and tried to be very careful. Fingers crossed it all works out! Now I find that for 1/72 scale kits, black paint is a good solid colour for the internal canopy frames and you don't end up with that transparent look that can sometimes show through. I was fairly liberal with the Tamiya lacquer black paint and covered the inner wing sections as well to represent the wing walkways. As lacquers dry very fast, I didn't have to wait too long before giving the Safir a good three-four coats of Decanted Tamiya AS-12 Airfame Silver. Mixed with Gunze's Leveling Thinner, this stuff goes on beautifully with very fine metallic pigment and is usually tough enough to handle a good dose of masking. Next up will be the Dayglo sections and I've got a few ideas on how best to tackle that faded effect. Cheers.. Dave 17 Link to comment Share on other sites More sharing options...
Grandboof Posted February 2, 2020 Share Posted February 2, 2020 Nice finish Martin H 1 Link to comment Share on other sites More sharing options...
zebra Posted February 2, 2020 Share Posted February 2, 2020 Looking lovely Dave. And another vote for micromesh from me - fantastic stuff. I've got a set of micromesh sanding sticks as well - they've turned out to be indispensable. 1 Link to comment Share on other sites More sharing options...
Rabbit Leader Posted February 2, 2020 Author Share Posted February 2, 2020 1 minute ago, zebra said: micromesh sanding sticks I’ve never heard of those Julian. Might have to look them up. Thanks Cheers.. Dave Link to comment Share on other sites More sharing options...
AaCee26 Posted February 2, 2020 Share Posted February 2, 2020 Hi Dave, It might be still possible to add new exhausts for this? D-model had 4-cylinder engine instead of 6 used in the B so D had exhaust in different location than the B. You can see it slearly from the in-flight picture. Cheers, AaCee 1 1 Link to comment Share on other sites More sharing options...
Rabbit Leader Posted February 2, 2020 Author Share Posted February 2, 2020 30 minutes ago, AaCee26 said: Hi Dave, It might be still possible to add new exhausts for this? D-model had 4-cylinder engine instead of 6 used in the B so D had exhaust in different location than the B. You can see it slearly from the in-flight picture. Cheers, AaCee Ooh... thanks for pointing this out AaCee. I had a feeling that something was not quite right up front, however that’s now confirmed a few things. Let me see what I can come up with. Might need to get a few good photos as well to help me determine what needs doing. Cheers.. Dave 1 Link to comment Share on other sites More sharing options...
trickyrich Posted February 2, 2020 Share Posted February 2, 2020 you got a lovely finish with the paint Dave, looks really nice 1 Link to comment Share on other sites More sharing options...
Greg Law Posted February 3, 2020 Share Posted February 3, 2020 Very nice finish on that Dave. I tried to by those micro sanding pads, but Amazon won't deliver them to me. 1 Link to comment Share on other sites More sharing options...
Rabbit Leader Posted February 8, 2020 Author Share Posted February 8, 2020 Update #6 - Dayglo prep Looks like this little 1/72 Safir is going to get swamped by a few of its 1/48 bigger brothers, so I'd better progress it some more and bring it closer to the finishing line. The silver undersurface is nice and dry so the Dayglo areas were masked off ready for the first layers of paint. Dayglo paints are by their nature quite thin and transparent and I have no idea how some modellers get away with hand brushing them. My tried and trusted way is to paint a solid white base first and then numerous thin coats of the Dayglo paint all applied with an airbrush. The photo sequence below starts with two coats of Mr Color #62 Matt White. Once dried I applied a good coat of Humbrol #24 Trainer Yellow, however I'm experimenting a little bit here. My overall aim is to replicate a faded Dayglo finish, so the underside yellow layer was painted up in a fairly solid finish, whilst the upper sections and tail fin were softly sprayed to represent a lighter / faded look. Not sure if this is the way to do it, however let's see what happens when the orange is applied? Till next time.. Cheers.. Dave 14 Link to comment Share on other sites More sharing options...
Col. Posted February 8, 2020 Share Posted February 8, 2020 Your technique for fading the upper surface makes sense and seems to have yielded a good result 1 Link to comment Share on other sites More sharing options...
trickyrich Posted February 8, 2020 Share Posted February 8, 2020 mmmm very clever. 1 Link to comment Share on other sites More sharing options...
modelling minion Posted February 8, 2020 Share Posted February 8, 2020 Excellent work Dave, I think your idea for the faded dayglo is going to work a treat and you are going to have a great looking model when finished. 1 Link to comment Share on other sites More sharing options...
Grandboof Posted February 9, 2020 Share Posted February 9, 2020 Great idea for the Dayglo Should yield a stunning result Martin H 1 Link to comment Share on other sites More sharing options...
Hewy Posted February 9, 2020 Share Posted February 9, 2020 Smashing job david,this will look really smart👍 1 Link to comment Share on other sites More sharing options...
Rabbit Leader Posted February 17, 2020 Author Share Posted February 17, 2020 Update #7 - Dayglo Orange It's been way too long since I updated this thread so here's some recent progress shots with the application of Humbrol #209 Fluorescent Fire Orange and Black for the Anti Glare panel. As I'm trying to replicate a faded dayglo look, the undersurface orange was applied fairly solid. The paint was gradually feathered as I rotated the model to expose the upper surfaces. The top orange is no more than one or two passes of the airbrush and I had to stop myself from over doing it, not exactly easy when your having fun with the AB! Anyway, I think it's reasonably effective and will hopefully look the part once the decals and other details are applied. Cheers.. Dave 14 Link to comment Share on other sites More sharing options...
Romeo Alpha Yankee Posted February 17, 2020 Share Posted February 17, 2020 Nice effect with the fading paint Dave. What metal colour did you use? I am on the hunt for a nice covering (and easy to apply) metal colours for future projects. 1 Link to comment Share on other sites More sharing options...
Rabbit Leader Posted February 17, 2020 Author Share Posted February 17, 2020 5 minutes ago, Romeo Alpha Yankee said: What metal colour did you use? I am on the hunt for a nice covering (and easy to apply) metal colours for future projects. Decanted Tamiya AS12 Airframe Silver from a Spray Can. Mixed with Mr Color Levelling thinner, it takes about three to four thin coats to get a solid application, however is tough as nails and the pigment is very tight. For this LB-30, you could even spray it straight out of the can, it'll work well for that. Cheers.. Dave 2 Link to comment Share on other sites More sharing options...
Bengalensis Posted February 17, 2020 Share Posted February 17, 2020 That's looking nice. I may try the same for some dayglo patches I have coming. I think I have a can of 209 around. 1 Link to comment Share on other sites More sharing options...
Hewy Posted February 17, 2020 Share Posted February 17, 2020 A really superb looking model david 1 Link to comment Share on other sites More sharing options...
Rabbit Leader Posted February 25, 2020 Author Share Posted February 25, 2020 Update #8 - Finnish-ed! I got a bit of steam ahead in the last week or so and just kept on building this without stopping to photograph it. She's finally done although I'm a little disappointed with the quality of he final photo's now that I'm viewing these on a larger desktop screen (they look so much better on a phone). I was not sure which background to use for the final gallery shots, so have posted the blue background here and the grey ones in the gallery. Anyway, unless I take more photo's later I'll leave it at that and tick off the first of hopefully four builds for this GB. Thanks to all who have commented, especially the GB hosts for running such a great show so far. Cheers and big thanks.. Dave (how hard is Dayglo to photograph?) 18 Link to comment Share on other sites More sharing options...
