Pz.Kpfw.VI Sd.kfz.182 Tiger II (Henschel Feb 45 Production) (84532) - 1:35 Hobby Boss via Creative Models
Often called the King Tiger (incorrectly) the Tiger II was a German Heavy Tank of WWII and was the successor to the Tiger I tank.  The tank still had the thick armour of the original Tiger, however this was sloped like the Panther.  The Tiger II weighed in at 70 tonnes putting increasing pressure on the drive train which was based on the original design, The tank featured a long barrelled 88mm gun. Even though orders were placed for 1500 tanks production was severely disrupted by allied bombing with only 492 being produced.  Henschel won the design contract for the Tiger II and all the examples were produced by them. Two turrets were designed for the Tank; the rounded Krupp design (erroneously called the Porche turret), the second was the easier to produce angular turret (again erroneously called the Henschel turret).
The Kit
This is a re-boxing with additional parts of HobbyBoss's King Tiger from 2018. The kit arrives on 14 sprues of plastic for the tank, 11 track sprues,; separate upper & lower hulls, the turret casting, a small PE fret and a metal gun barrel. Overall a nice looking package. Construction starts with the lower hull; the torsion bars for the suspension are attached connectors for the wheels  There are 10 pairs for road wheels for each side which are interleaved. Idler wheels, drive sprockets, and return rollers are also added.
The tracks go on next. These are individual links which clip together, however care must be taken as the different sides build up slightly differently, this is not helped by the instructions not saying how many links are need for each side.  Next up the rear bulkhead for the tank is built up with the exhausts being added. Once complete this can be added to the lower hull. The front MG and mount are then added into the upper hull. At the back the engine deck is made up and added along with tools and towing cables. PE mesh parts are provided for the intakes.  The front hatches are then added along with the side skirts. The top hull is now added to the rear hull. Once its on the front mud guards are put in place along with a pair of towing shackles. At the rear another pair of mud guards go on. Moulded cables are provided for the sides.
Work now moves to the turret. The commander copula is built up, next up the comprehensive main gun and breach are constructed. There is no interior in the rest of the tank, but the internals for the main gun are pretty good. The barrel is attached and HB provide an open muzzle, or a cover one for you to use. The Gun is added to the turret base and the main part of the turret added over it. The rear hatch is added along with the command copula. Spare track links are provided for mounting to the turret if the modeller wants. The turret is then joined to the hull.
Markings
Despite this being a big model, it has a smallish decal sheet.  markings are provided for 6 different tanks, however there is nothing on the painting guide to indicate anything about them at all.
Conclusion
There is no doubt this will make up to a great looking model of the King Tiger. It is a shame HobbyBoss cant put in anything about the markings at all.
Highly recommended.
Review sample courtesy of
