Retired Bob
Battle of Britain Junkers Ju 87B Stuka
Having not built a Stuka for nearly 50 years I thought joining this GB would sort that out, this year is also the 80th anniversary of the Battle of Britain so I could also start my build of aircraft that took part in that epic battle.  On checking through my stash I had two Hasegawa Stukas, one with resin ski's and this one for the Balkan operation.
IMG_1204
I was going to build it in North African markings, yes with the snake, I have the Peddinghaus set for that, but as I have always wanted an aircraft from 6./St.G 1, their badge has a devil holding a flaming torch and sitting on a bomb, I thought why not.
IMG_1205
The plan is to build it almost straight out the box with just the Eduard zoom to improve the cockpit, Eduard mask to help with the canopy and Quickboost resin machine guns and exhausts to improve those two areas.  I do not want to over complicate this build, that's how I end up not finishing in time.
Let the fun begin.
Good luck with the build I hope all goes well for you. There's plenty of time.
The JU 87 belongs to my favourite WWII planes, so i have to follow your build thread.
Good luck and hope you will enjoy this build.
Do you remember which kit you built 50 years ago?
Sounds very familiar :whistle:
Your selected parts will definitely enhance the model nicely.
Cheers, Peter
Hi Peter, not sure if was a FROG or Revell Ju 87D with a worn white finish over the 70/71 camouflage.
Today's work has already changed that plan, plus my idea not to buy anymore kits until my stash is reduced has been forgotten has I have ordered a new Airfix 1/48 Ju 87B for my "snake" decals. :like:
Today I started on the cockpit, I removed the raised detail on the instrument panel, side panels and radio boxes ready for the Eduard photo etch, the seat and seat armour will need some work to make them more realistic before I paint them RLM 66 black/grey.
IMG_1209
This kit is over 20 years old and as with models of that period there is nothing in the wing behind the landing light lens, the instructions have you fit the wheels into and glue the spats together, I have removed the lower part of the wheel retaining ring so that the wheels can be fitted after clean up and painting.   Hasegawa have moulded the slats with the wings, this results in six lumps where there should just be rods and actuators.  I did think about ignoring these since they are on the underside, but that's what chisels and scalpels are for and mainly I would know they were there.  Should keep me busy for a couple of hours. 😉
IMG_1207
Been a bit of a delay, but I did not listen to myself when I said I was going to build it OOB.  I sprayed the interior RLM 66 then after the discussion on interior colours I have resprayed it RLM 02, using the RLM 66 as pre-shade.  I cut back the roll cage to remove the armour and modified the seat.  Thanks Greg @Greg Law for the info on the Yahu I/P but I have just touched up the Eduard I/P with some RLM 02.
IMG_1213
I have chopped off the lumpy control actuators and replaced them with some brass rod after re-scribingthe panel lines.  My Airfix Ju 87 arrived a couple of days ago, rather disappointed,  I had read of the shocking amount of injector pin marks and the soft details, the tyres on wheels remind me of ring doughnuts, the tread lines are so soft!  I used the spare propeller and spinner to make my Hasegawa  Stuka a B1, the profiles for this aircraft in both the Kagero and Classic Colours books use a B2 profile but call it a B1.
IMG_1215
Just have to finish off installing the landing light, now where did I put those PE ones I bought at Telford? :hmmm:
Great effort on the cockpit and changing the seat does contribute to an authentic look :thumbsup: Did you use the Eduard Steel harness and how was it to fit? I will use them on my build for the first time when I get to that stage. Also the replaced actuator rods look so much better.
Unfortunately there is a lot published which lacks research and accuracy and I too fund the new tool Airfix kit a bit disappointing.
Keep up the good work.
Peter
Hi Peter, I had no problems with the Eduard seat belts, apart from the usual springiness, but a dab of superglue gel usually holds them where you want them.  The actuator rods were a thing that I had to change, even with them being on the underside and out of sight, but being so pedantic slows my build rate to glacial speed. :rolleyes:
I was rather annoyed when I read up on the various differences between late B1s and early B2s and that the profiles were all B2s, luckily there are photos, rather grainy but at least something to work off.  Pehaps I was expecting too much of the Airfix Ju 87 kit, but after getting the new Eduard P-51 kit and the quality moulding that Eduard have achieved, I can only assume that Airfix are happy to remain producing retro kits with last century's quality. ☹️
Thanks for showing your approach for improving the wing hinges. I opened up my Hasegawa kit last night and my heart sort of sank when I saw those
The seat looks good. The one in my kit is just as bad. I think I will replace it with one out of the Airfix kit or use the quick boost one. Also the gunners seat doesn't look right. That may have to go as well. Good call on the wings gear. I did the same thing on my old Stuka.
It does have that effect on you, when I started this I thought "just build it" and a week later I still haven't got the fuselage glued together.  The other thing with the wings is the empty gap where the landing light goes, I have boxed it in with plastic card, just trying to find a round dished "light" I thought I had one from the spares box but it's too big, I'll just have to make one, more delay!
That is the kit seat with some stretched sprue added for the frame work, I didn't know it was a canvas seat until Peter @Basilisk mentioned it, so I have removed the chipped effect as canvas doesn't scratch like metal. :penguin: I think the rear side of the gunners seat should be higher, but it's not too bad.  Just trying to make the cockpit a bit more "busy".
Maybe you should add the chipping once more as I think I got it wrong. After doing some more searching on the web I came across two interesting pictures.
Both pictures are apparently a seat from a Ju 87G. The right side picture does look like the seat as used in the RAF Museum example, but the left seat does certainly not and I have a feeling it s actually a seat from a Berta (or maybe two types of seat had been used in late model Stukas). And one thing is sure, it is not made from canvas!
Cheers, Peter
Some more done on my Stuka today, happy at last with my cockpit I have glued the fuselage together and sprayed a light coat of RLM 65 to check for any imperfections on the wings and lower engine cowling.
IMG_1218
The wheel spats are just pushed on, the fit of parts is pretty good.  I was almost tempted to buy another....but managed to resist. :unsure:
IMG_1219
Thanks for looking.
Hello bob,rapid progress,  a superb job on the cockpit and it seems to be  going together well too .
Wings and engine section glued on, I have also attached the siren propeller, the photos show only the starboard one fitted.  The spinner has been painted yellow prior to masking the band, the front and rear will be RLM 71.
IMG_1220
A trial fit of the canopy sections showed a problem with the centre section not fitting over the roll bar, it's too wide and needs about 0.5 mm off each side, it's pretty thin already.
IMG_1222
A careful bit of shaving with my trusty chisel and the canopy now fits.  As I want the pilots canopy open I will apply the masks and paint the canopies as separate parts.
Edited by Retired Bob
missing word
