Sebastian Lachowicz Posted January 8, 2020 Share Posted January 8, 2020 That's end of my struggling with Corsair. My goal was to make model based on the workshop more experienced modeller and based on original photo. I realized that as good as I could. There are difficult to make signs of exploatation, scratch, dirt, stains of fluids. It is not perfect but I think much better than in my previous model. Model represents Corsair MkII JT260 on board HMS "Unicorn". There is some error in my side, because I used revell's model which represents Corsair manufactured by Goodyer FG-1D - in british markings MkIV. Differences beetwen versions are another propeller, with slimmer blades, no air inlets on fuselage. Also, model is not perfect too. There are different shape lower surface of wing flaps, they are too short, too long engine cooling flaps. In engine section engine cowling are too short and mismatched shape of that, cooling flaps and upper part of fuselage. To make model I used eduard's photoetched parts and techmod's decals. Numbers on fuselage are painted by template masks. 36 1 Link to comment Share on other sites More sharing options...
billn53 Posted January 8, 2020 Share Posted January 8, 2020 Nicely done. Your weathering is well executed. 1 Link to comment Share on other sites More sharing options...
Meatbox8 Posted January 8, 2020 Share Posted January 8, 2020 Truly awesome. Some of the best weathering I have ever seen. The Corsair at the FAA Museum looks a bit like this at the moment. They have stripped it down to its origianal paint. 3 Link to comment Share on other sites More sharing options...
dbay133 Posted January 8, 2020 Share Posted January 8, 2020 Stunning model and superb weathering; so realistic. Graeme 1 Link to comment Share on other sites More sharing options...
85sqn Posted January 8, 2020 Share Posted January 8, 2020 Great stuff! 1 Link to comment Share on other sites More sharing options...
Spitfire31 Posted January 8, 2020 Share Posted January 8, 2020 It certainly looks very convincingly used or should I say, abused! Maybe the ground crew felt sorry for it and gave it a new pair of wheels? They look factory fresh compared to the rest of airframe. Impressive weathering job! Kind regards, Joachim 2 Link to comment Share on other sites More sharing options...
Doc72 Posted January 8, 2020 Share Posted January 8, 2020 Impressive weathering! I like well-used paint schemes. What is your technique? 1 Link to comment Share on other sites More sharing options...
exhausted Posted January 8, 2020 Share Posted January 8, 2020 You made that kit your b-nevermind That looks fantastic! The kit may have deficiencies but you made it into a palette, and you possess great talent for that type of finish Awesome work 1 Link to comment Share on other sites More sharing options...
Sebastian Lachowicz Posted January 8, 2020 Author Share Posted January 8, 2020 Thank You for all good words. I didn't imagine that my model will be so compliment. It was only training in weathering, because my previous model looked like dirty toy, not miniature of weathered plane. 3 hours ago, Doc72 said: What is your technique? Making this model I used first time chipping effect technique with MIG chipping fluid. I used it between paint layers. First layer was Vallejo aluminium silver, next gloss varnish (X-22). Next I cover all surface with chipping fluid. There was some wrong, becuse this layer was too thick. Next layer was primer color - Tamiya XF-4 and I made first scratching. Next layer were camouflage colours and again chipping fluid. On chipping fluid layer I repeated camouflage colors but little lighter and I scratched these layers. It made effect of different thickness of paint layer and made additional effect on surface. After taht I cover everything again with gloss. On this layer I used oil paints - mixing black, white and brown to make different fluid leaks on fuselage and wings. I made it several times, and tapped it with brush and ear stick and rub it with paper towel. When I decided that effect is good enough, I cover everything again with gloss. At this moment I made classic wash with dark gray oil paint. 2 Link to comment Share on other sites More sharing options...
RMCS Posted January 8, 2020 Share Posted January 8, 2020 Blimey 1 Link to comment Share on other sites More sharing options...
James G Posted January 8, 2020 Share Posted January 8, 2020 Wow amazing weathering! 1 Link to comment Share on other sites More sharing options...
Sebastian Lachowicz Posted January 8, 2020 Author Share Posted January 8, 2020 Here is original photo which I used to make it's model _IGP1344 by Sebastian Lachowicz, on Flickr 6 Link to comment Share on other sites More sharing options...
Uncle Pete Posted January 8, 2020 Share Posted January 8, 2020 It's brilliant! It knocked my on my dupa! 👍 1 Link to comment Share on other sites More sharing options...
russ c Posted January 8, 2020 Share Posted January 8, 2020 Superb ! Link to comment Share on other sites More sharing options...
tonyot Posted January 9, 2020 Share Posted January 9, 2020 Very nice indeed Sebastian,..... the scheme is very well weathered and it is the best Revell Corsair II that I have seen to date,.... congratulations. Having built two of these,....I know it isn`t exactly a shake and bake kit! Cheers Tony 1 Link to comment Share on other sites More sharing options...
billn53 Posted January 9, 2020 Share Posted January 9, 2020 Now that I’ve seen your photo of the actual aircraft, I’m even more impressed! 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted January 9, 2020 Share Posted January 9, 2020 Well done sir ... Thats a nice looking Vought. 1 Link to comment Share on other sites More sharing options...
Ian Posted January 9, 2020 Share Posted January 9, 2020 Museum quality modelling, simple as that. Ian. 1 Link to comment Share on other sites More sharing options...
Sebastian Lachowicz Posted January 9, 2020 Author Share Posted January 9, 2020 15 hours ago, Spitfire31 said: Maybe the ground crew felt sorry for it and gave it a new pair of wheels? They look factory fresh compared to the rest of airframe. Kind regards, Joachim Good observation. I have to weather it too. thak You 1 Link to comment Share on other sites More sharing options...
Cookenbacher Posted January 9, 2020 Share Posted January 9, 2020 Wonderful job matching your reference photo, and thank you for sharing your techniques. And you made the Revell Corsair look like the real thing, not an easy kit to do that with. 1 Link to comment Share on other sites More sharing options...
ArmouredSprue Posted January 9, 2020 Share Posted January 9, 2020 The weathering looks very well executed. One thing that put me off though were the main wheels. They look awkwardly clean compared to the rest of the aircraft. Maybe it's missing some weathering. Cheers 1 Link to comment Share on other sites More sharing options...
