Sign in to follow this
tonyot
1/48th Airfix Spitfire FR.Mk.XIV, 443 Sqn RCAF, Uetersen, Germany Jan. 1946
Hiya Folks,
                After seeing photos of ex 451 Sqn RAAF Spitfire XIV`s in service with 443 Sqn RCAF in Germany I have wanted to build one,...... as the Canadian`s retained the Kangeroo marking of the Aussies and then added their own Wasp marking and codes with many having nose art too. Thankfully Exito Decals came to the rescue with an excellent decal sheet and I`ve used it here with the fairly recent Airfix Spitfire XIV kit.  My only gripe with the decals was that the spiral for the spinner is back to front and therefore I had to turn it around, add the yellow part facing downwards and then brush paint yellow onto the white underside of the decal after it had been applied..... apart from that the decals are superb and the instructions include artwork which can be framed and also photos of the real aircraft,..... all in all a quality item,..... as is the Airfix Spit!
Here is a 451 Sqn RAAF Spit in Germany, complete with Kangeroo marking;
And here are some after transfer to 443 Sqn, including the subject aircraft;
Spitfire-XIV-RCAF-443-Sqn-2-I-M-TZ198-Ge
Here are the Exito Decals;
Here is the model;
And here it is with a little brother which was built alongside it,.....using a Sword kit,... told you I liked this scheme!;
1/72nd Sword;
As usual both models were brush painted,
            Tony
           Tony
Edited by tonyot
Wow, that came out well! What a brilliant scheme. I like it too, very much 👍
Alan
Super work as always Tony. I've  looked at those decals as well s I fancy doing another. I got sidetracked by Blenheims though.
Another fantastic spitfire. One of my favourite marks. What a lovely finish you manage with the hairy stick! Brilliant work on both models 👍👍
Superb
Late/post war RAF wing roundels. You can't beat 'em!
Another fine addition to the portfolio Tony,great finish
Tony,
That looks awesome. as usual. Was not sure how many different markings were available but this sheet is very promising indeed.
Thanks for sharing!
All the Best!
Don
Very nice wok.
I've got those decals and a pair of Airfix FR. XIV's to do the two RCAF schemes. Just waiting in the wings for their turn on bench.
Rich
That is an awesome scheme and markings that I had never seen before! Ho, hum- another outstanding model, Tony! Nice pair- wonder if they  make a Mk XIV in 1/144  or 1/32 so you can have a trifecta?
Mike
Thank you everybody for your very kind comments,...... got to admit, being a model that I have wanted to build for some time (and I was in the process of converting the old Academy kit with a resin nose to make it,...... and by bodging up some decals from the spares box to do so!) I was so pleased that Airfix released their kit and Exicto released their sheet,.... it sort of felt like the gods were aligned on this one so I had to make a special effort and it has taken pride of place as a result!
Cheers again everybody
                                       Tony
51 minutes ago, Adam Poultney said:
Very nice! How was the build?
Thanks Adam,...... yeah the build was OK,.....the only problem I had was with the fuel tank section in front of the windscreen,.... it is a tad too small and I added plastic spacers to raise it up and make it flush with the surrounding fuselage,..... although I think that it should actually stand proud of the fuselage slightly due to a sheet of armour plating?
         Tony
         Tony
Lovely as always Tony :)
I think you're right re: the fuel tank cover (and the forward cowl) standing proud, see this post
Please, do let me know your secret to getting such a smooth brush painted finish - as a fellow brush painter I've always admired the quality of the finish you achieve!
What paints did you use and what did you weather with?
Cheers!
Ben
Cheers!
Ben
It is just practice mate,..... don`t load your brush too much,..... build up layers rather than slapping too much on,....spread the paint around evenly and scrub any brush marks flat,..... for large areas use a flat wide brush,........ don`t be scared of using a smaller brush for demarcations and then filling in using a larger, flat brush. I use acrylics and enamels,..... whichever colour is best for the job. I did like Aeromaster and Polly Scale but I`m running out of those now so have tended to fall back onto Humbrol enamels,...... but I`m still experimenting with thinners etc for Tamiya and Xtracrylics.
Hope that helps,....cheers,
                                        Tony
Wow Tony another cracking model fella, very nice indeed.  Great work.
All the best
Chris
All the best
Chris
Cheers Chris,.... glad you like it mate.
Another stunner mate, always impressed how you get such a fine finish with them hairy things (paintbrushes just to clarify things 😂)
LOL!!!
Have you not noticed that you've used the wrong exhaust stubs? They should be the tubular ones as are all the subject aircraft on that Excito sheet. Maybe you could exchange them for the correct ones?
Also looking at both the images and profiles of your aircraft it looks like the sliding part of the canopy should be nmf and not in camouflage colours as you've done.
You're correct about the decals being excellent though, i'm just in the closing stages of building
DN-Y "Yvonne"
I'm going to build your aircraft next so thanks for the heads up about the spiral decal being the wrong way round. 👍
Tim.
DN-Y "Yvonne"
Tim.
Tim,.....
.... Looking at the pics of the real thing I couldn`t actually decide between the wartime or tubular exhausts,......so opted for with the earlier ones as they are ex wartime machines,...... the exhausts can easily be switched. I`ve looked again and agree that they do look like the latter. I did choose tubular exhausts for the smaller version to hedge my bets.
I`m aware that the canopy `looks' a plain light colour which could be silver or grey green primer,......not being sure which,...... I opted for the camo colours in which it was no doubt eventually painted,....or the previous canopy frame was painted.
Glad I came in handy for something with the spiral,
          Tony
Tony,
I'm still undecided whether to do the  sliding part for Yvonne in white or nmf? Or would the canopy be painted silver?
So tubular exhausts were a post war fit then?
Tim.
