1/72 - Supermarine Spitfire Mk.Vc by Airfix - released
6 hours ago, Rabbit Leader said:
Measure it?
Two numbers that stick in my head are Don Bradman‚Äôs 99.94 Batting average and 36‚Äô 10‚ÄĚ for the Spitfire‚Äôs (elliptical) wingspan. That‚Äôs pretty close to 156mm in 1/72 scale.¬†
Sorry for not being clear, I corrected my post you quoted from.
I meant the AZ has a shorter wingspan than the Airfix,, just from comparing the bottom wing parts.
But both bottom wings end where the end plates are attached so it's not the full span.
Thought I’d add a few more pics. Airfix’s Vc has some new (to me) refinements. The oil cooler, radiator, and air intake all have recesses in the lower wing, for example.
Boxed in wheel wells:
The previously-mentioned oil coolers & cockpit details.
Plus the non-tropical filter (circled):
And an aftermarket decal option that’s closer to (my) home:
  • Sad 1
But they've missed the gun heating tubes from behind the radiator (present on their recent MkI) and the corresponding vents on the wing underside outboard of the guns (missing on the earlier kit as well)
and the standard nose underside for use instead of the Vokes filter just to the right.
Edited by Dave Swindell
See post below ref strikeout.
It's a Vc, not a Vb. The Vc does not have lower wing gun-bay heating vents outboard of the gun bays
Then why do early Mk.Vc have a small bulge on the upper wing just inboard and forward of the aileron?  There may be some other reason, of course but I understood that this was for taking warm air out to the gun.  I also believe that PP.H  BR498 was a Mk.Vc with the obvious hole aft of the exhausts where the gun heating tube would fit.
No idea, but I have never seen a Vc or IX with lower outboard exhaust vents. AR501 doesn't have them, neither does EE583, nor does EE602 or JG891. Happy to be shown otherwise via photographic evidence
Edited by Work In Progress
Absolutely. Not called out by me as it’s a lot easier to see than the itty bitty intake bits.
I was under the impression they did, but a quick scan through a few books shows some definitely without, and others inconclusive, but I'm inclined to agree with you, no vents.
All current airworthy aircraft with no need for gun heating, recent photo's may not be representative of as built condition
Not saying there was no gun heating, just that there was no underwing extractor vent.
Just so we're clear, and I'm sure you know already, the C wing refers to the armament layout, not a single type of wing  - the Vc wing was different to the IXc wing and the two were not interchangeable, they differed in structure to some extent, oil and coolant plumbing were different, radiator fit was different and pertinent to this discussion, the gun heating arrangement was different.
The gun heating ducting in the Vc wing was essentially the same as that fitted to the Vb (as described and illustrated in the AP)
The AP also illustrates (drawing and photo) the underwing gun extractor vent on the Vb wing (but doesn't illustrate the underside of the Vc wing or mention the absence of the vent)
I'd therefore assumed the Vc was similarly fitted, and the vent disappeared with the introduction of the different gun heating layout with the twin radiator arrangement of the MkIX, so you don't see any IXc's with the vent.
I'm now inclined to think that the vents disappeared around the time of the introduction of the exhaust intensifier gun heating on the Vb - early Vb's without the intensifier tube definitely have the vents, but later Vb's with the intensifer tube don't appear to have the vent.
The vents acted as venturi to help draw warm air to the outer gun positions (which is why the port one is larger as it had further to pull the air over from the radiator under the stbd wing). On the A wing and early B's the radiator ducting heated all the guns. With the introduction of the exhaust intensifier heating the same radiator ducting only heated the cannon, the MG's being heated by the air supplied from the exhaust intensifiers.
It would be reasonable to assume therefore that  the exhaust intensifier gun heating could be designed in such a way that the vent was no longer needed - a lower volume of potentially higher temperature air would be sufficient to heat a much smaller space.
It's four-nil, it's literally every Spitfire Vc of which I can find clear photography of the affected area.  And in fact five-nil now as I've finally found the right angle on JK808,  which has not flown since 1952.
Plus here's BR202 clearly without in 1942
In the absence of any evidence that outboard underwing heat extractors WERE fitted to the Vc, I think it's a slam-dunk case that Airfix have done the right thing.
It is well established that the Vc had different heating arrangements from those of the V, partly because its armament layout was very different and partly because that of the Vb was getting complained about. The Vc arrangement was also highly criticised by the Australians for its own inadequacies, as well rehearsed somewhere in a long thread in these parts a few years ago, but which I can't currently put my finger on
2 hours ago, LN-KEH said:
Is it feasible for Airfix to release a Seafire F Mk IIc based on these mouldings by adding a sprue or two to cover the differences?
Yes but "a couple of sprues" is a lot on a kit that's not much more than a couple of sprues in the first place.  I would not hold your breath as one of those would have to be a new fuselage, as they would need to incorporate the pretty visible external strengthening straps as well as the hook, changing the prop etc
Im horribly disappointed in Airfix and hope they read this. The Vc and the Beaufort were the first two kits I’ve pre-ordered since 2004. I would expect to be one of the first people to be notified by the Manufacturer. At least before other Retailers would/should get there’s ? Im still waiting on an email notification thats probably not going to show up ? Extremely disappointed in Airfix’s bait and delay here and If I come across one or both before I receive the email will cancel my order with Airfix and not place any in the future.
Edited by Corsairfoxfouruncle
Patience @Corsairfoxfouruncle, patience. Good things come to those who wait.
The Beaufort isn't released yet, due in January next year.
The Vc has only just been released in the UK, and from what I've read on here, those in the UK who pre-ordered it from Airfix got shipping emails and received theirs before the likes of Hannants received their stock.
As I understand it, pre-orders from the US/Canada are fulfilled by the US importer Airfix/Humbrol/Hornby USA, so if they've not received stock yet they won't have shipped, hence no email.
Global freight is currently having a bit of a meltdown at the moment, with major problems shipping out of China in particular, so a significant part of the delays on delivery are out of Airfix's control. Just hope they weren't being shipped on ONE Apus, otherwise you could be in for a quite a wait...
  • Haha 2
  • Sad 1
Nah.
You might have a loooong wait for Tamiya white top glue though..
  • 3 weeks later...
interesting observation they have added a recycling information tab to the sprues , so you can now add them to your domestic plastic recycling (Previously they would just be separated and land filled as unidentifiable)
27 minutes ago, Andre B said:
Is it just me or do the wheels look blury?
/André
I have change mine with  Sword, Kp, or Tamiya ones
Alain
