72modeler Posted January 2, 2020 Share Posted January 2, 2020 (edited) Just got a pair of the deluxe boxings, kit 72035 today....wow, wow, wow! Until I can figure out how to post photos, (One of my New Year's resolutions!) here's a brief summary, based on first look- will compare to drawings when I get a chance: Put your AZ and Hasegawa kits up for auction- this is THE Mk II Hurricane in 1/72 scale, in my humble opinion (What say you, @Troy Smith?) *two hoods- one for closed, one for open; landing lights nicely done and in correct location compared to fabric wing *prop and spinner look very good- Rotol prop *scribing is very fine and precise; fabric effect on fuselage, control surfaces, and fin/stabs extremely well done (two very slight sink marks on either side of upper surface of the horizontal stabilizer, which is done in one piece with separate elevators.) *Vokes tropical filter and both styles of 20mm cannon provided *wheel bays nicely detailed and correct shape- undercart nicely done and four-spoke wheels slightly flattened * fairly nice cockpit detailing with the cockpit floor/heelboards molded with the upper wing, sidewall detailing as part of each fuselage half, but the tubular framework is not really provided *no external tanks included, nor is there any visible sign of flashed over holes for them- need to source these from the aftermarket or from other kits * There are two pairs of very closely spaced holes flashed over on the lower wings that appears to indicate a Mk IID will be a future release *no provision visible for a hooked version- maybe a new fuselage at some later date? *decals are very nicely printed but very glossy- four markings choices, with two being for Smallwood's LK-A in two different schemes If you are crazy about the Mk V like I am, with the fineness of the panel line scribing, it will be very easy to fill in and rescribe the correct panels and add the relevant Mk V bits Hope they sell a bazillion of them and continue turning out kits of this quality! Thank you, Arma Hobby! Mike Edited January 2, 2020 by 72modeler corrected spelling 2 Link to comment Share on other sites More sharing options...
Zack Posted January 3, 2020 Share Posted January 3, 2020 (edited) Hello Mike I have no experience about the brand but the test shoots sure look interesting enough so I placed an order. http://www.armahobby.com/70035-hawker-hurricane-mk-iic-expert-set.html http://www.armahobby.com/70027-yakovlev-yak-1b-expert-set.html Happy modelling 2020! Edited January 3, 2020 by Zack spelling Link to comment Share on other sites More sharing options...
Graham Boak Posted January 3, 2020 Share Posted January 3, 2020 Yes, a superb little kit, even better than their Mk.1. There have been a number of threads discussing Arma kits, perhaps the talk of the Mk.II was lost to sight on the end of an earlier thread? Worth a search, I'd have thought. Link to comment Share on other sites More sharing options...
Work In Progress Posted January 3, 2020 Share Posted January 3, 2020 From what I've seen - photos only at this point - the Mk.II seems to have corrected the slight but weird cockpit area width bulge that was visible on at least some of the built-up Mk.I kits I've seen. 1 Link to comment Share on other sites More sharing options...
Zack Posted January 3, 2020 Share Posted January 3, 2020 Thank you for your advice Graham, I need to learn using this function. Did a Google search on "arma hobby britmodeller" and have no regrets 1 Link to comment Share on other sites More sharing options...
