Brandy 13,512 Posted January 11, 2020 Share Posted January 11, 2020 Coming along very nicely for a practice build. The bad join on the front of the wing could also be dealt with using sanding sticks and putty. For something like that Perfect Plastic Putty works well as it can be smoothed using a wet finger tip. There are a multitude of products and techniques which will help you improve your skills but don't try to pick them all up at once. Slow and steady, and as long as you keep trying to improve, you'll find more than enough tips and tricks offered here. You only need to ask! Ian 1 Link to post Share on other sites
dnl42 2,862 Posted January 12, 2020 Share Posted January 12, 2020 It's coming along nicely! I'd like to offer a suggestion on dry fitting. Before you commit glue to parts, dry fit the parts to get the best possible alignment. When you dry-fit parts, it may be they join perfectly, but that's usually not the case! More likely some amount of adjustment is needed. The wing-fuselage joint in the red box is offset to one side while the wing-fuselage joint in the blue box is offset to the opposite side (compare the fore-and-aft panel lines on the rear of the wing to the panel lines on the fuselage). How this could have been fixed depends on the parts. In this case, the topside wing-fuselage joints in post #19 look ok, so perhaps there's some misalignment between the upper and lower wing panels that allowed the topside joint to align while the bottom joints did not? It could also be the case that the upper and lower wing panels are perfectly aligned yet the bottom joint is misaligned. Regardless of the cause, needle files, sanding sticks, and putty can be used to adjust the fit. Ideally, you can get a near-perfect joint in the dry-fitting-and-adjusting process Here's a before and after shot of an Airfix 1/48 P-51D fuselage bottom I'm currently building--quite a bit of filing of the interior parts was needed to get the fuselage parts to mate well. Reconstruction of the panel lines was also needed to eliminate the collateral damage of that effort. The key here is to fit the parts together and figure out where the adjustments are needed. With careful work, you can fix nearly any problem. BTW, tweezers are notorious for launching parts into the great beyond. Quality tweezers can reduce the number of lost parts, but pressing too hard on a part in tweezers is almost a guar·an·tee for a launch. I try to hold small parts in my fingers when I file them. I prefer to file away some skin over launching a part, but to each his own. HTH -- dnl 3 Link to post Share on other sites
Retroeric 86 Posted January 12, 2020 Author Share Posted January 12, 2020 @limeypilot @dnl42 Thanks for the hints 'n tips, it's most appreciated. In this case, the mis-alignment was caused mainly by haste and naivety. I just glued it, put it together, all felt good, didn't even think to check the alignment. It's a lesson learnt. I'm building this one primarily to practice masking, painting and using micro set/sol more when applying decals, so I'm not going to lose too much sleep over the misalignment issue More pics of the build coming later. 5 Link to post Share on other sites
BIG X 12,157 Posted January 12, 2020 Share Posted January 12, 2020 Don't worry - it's just a bit of fun - not open heart surgery - when things get tough - just tell yourself... Chin up Buddy!!! 3 4 Link to post Share on other sites
The Spadgent 19,775 Posted January 12, 2020 Share Posted January 12, 2020 1 hour ago, BIG X said: Don't worry - it's just a bit of fun - not open heart surgery - when things get tough - just tell yourself... Chin up Buddy!!! Ha! Bloody love that. I need one for cooking too. My son (11) and myself had an argument earlier over how to make béchamel sauce. Oh how middle class. 1 4 Link to post Share on other sites
BIG X 12,157 Posted January 12, 2020 Share Posted January 12, 2020 57 minutes ago, The Spadgent said: Ha! Bloody love that. I need one for cooking too. My son (11) and myself had an argument earlier over how to make béchamel sauce. Oh how middle class. Jonny - I thought you knew about the Britmodeller T-Shirts... They come in all kinds of 'flavours'... PLANE / TANK / BOAT / ROCKET etc... Cheers - Steve 2 1 Link to post Share on other sites
Retroeric 86 Posted January 12, 2020 Author Share Posted January 12, 2020 1 hour ago, The Spadgent said: Ha! Bloody love that. I need one for cooking too. My son (11) and myself had an argument earlier over how to make béchamel sauce. Oh how middle class. Blimey! Ow posh am yow? 4 Link to post Share on other sites
Retroeric 86 Posted January 12, 2020 Author Share Posted January 12, 2020 Tiny masking job, my eyesight ain't up to this kind of scale! First coat of dark green. Wonky donkey! 8 Link to post Share on other sites
dnl42 2,862 Posted January 12, 2020 Share Posted January 12, 2020 2 hours ago, Retroeric said: It's a lesson learnt. I'm building this one primarily to practice masking, painting and using micro set/sol more when applying decals, so I'm not going to lose too much sleep over the misalignment issue That's the key. My goal is to learn something or improve skills with every build. I usually do, including learning "I'm not going to try that again!" I wish each build was always better than all previous, but that doesn't always work out. BTW, photographs for a WIP or RFI can sometimes illuminate blindingly obvious errors. 3 Link to post Share on other sites
The Spadgent 19,775 Posted January 12, 2020 Share Posted January 12, 2020 hey. She looks great. Are you going to cut the masking to have the vertical framing too? Cocktail stick and a brand new blade. 2 hours ago, Retroeric said: First coat of dark green. The camo looks stonking. Jont. 2 hours ago, BIG X said: Jonny - I thought you knew about the Britmodeller T-Shirts... They come in all kinds of 'flavours'... PLANE / TANK / BOAT / ROCKET etc... Cheers - Steve Wha???? Where who. Take my money. 1 2 Link to post Share on other sites
Greg Law 5,042 Posted January 13, 2020 Share Posted January 13, 2020 If you are having trouble with your eyesight. Get a magnifying visor. I use mine all the time now. Even with my reading glasses on. Quite a sight it be... 4 1 Link to post Share on other sites
dnl42 2,862 Posted January 13, 2020 Share Posted January 13, 2020 @Greg Law is right. I would be lost without my Optivisor and its #5 lens plate. Link to post Share on other sites
dogsbody 9,091 Posted January 13, 2020 Share Posted January 13, 2020 56 minutes ago, Greg Law said: If you are having trouble with your eyesight. Get a magnifying visor. I use mine all the time now. Even with my reading glasses on. Quite a sight it be... Me, too! Chris Link to post Share on other sites
Retroeric 86 Posted January 13, 2020 Author Share Posted January 13, 2020 9 hours ago, The Spadgent said: Are you going to cut the masking to have the vertical framing too? Cocktail stick and a brand new blade. Damn, I never thought about cutting the masking tape in situ. I've done the horizontal bits, as shown in the piccy, so I was going to do the verticals next, masking them separately and hoping it wouldn't pull the paint off. Hmmmm...... 6 hours ago, Greg Law said: If you are having trouble with your eyesight. Get a magnifying visor. I use mine all the time now. Even with my reading glasses on. Quite a sight it be... Yeh, been thinking about something like that. Any recommendations? 1 Link to post Share on other sites
Greg Law 5,042 Posted January 13, 2020 Share Posted January 13, 2020 A good ione s mentioned above. Optivisor. I use a cheaper one with two lens in it. I don't know the brand name. 1 Link to post Share on other sites
dogsbody 9,091 Posted January 13, 2020 Share Posted January 13, 2020 I use this. Years ago, a young workmate, who was also a part-time jeweler, recommended and bought these for me. Not expensive but work well. Chris 3 Link to post Share on other sites
wombat 257 Posted January 13, 2020 Share Posted January 13, 2020 When a build goes terminally wrong it just becomes a paint mule for practicing painting techniques on. or, occasionally, falls foul of ack-ack fire (hammer) in a most satisfying way...just remember to salvage any useful spares from the crash site. 2 Link to post Share on other sites
Retroeric 86 Posted January 13, 2020 Author Share Posted January 13, 2020 This was hard! Might need to gently scrape away some of the paint. 3 Link to post Share on other sites
The Spadgent 19,775 Posted January 16, 2020 Share Posted January 16, 2020 Not bad at all. . If you do scrape away the paint use a cocktail stick. 1 Link to post Share on other sites
Wince 437 Posted January 16, 2020 Share Posted January 16, 2020 Looking good! Just picked up my hurricane after a month away from the hobby and yours is looking rather nice! Keep at it! 2 Link to post Share on other sites
The Spadgent 19,775 Posted February 1, 2020 Share Posted February 1, 2020 Hey Rich. Any more Hurri action? Link to post Share on other sites
Retroeric 86 Posted February 3, 2020 Author Share Posted February 3, 2020 On 01/02/2020 at 11:53, The Spadgent said: Hey Rich. Any more Hurri action? Hi John, picked it up again last night as it happens! It's been sidelined whilst I do man work on the property. The front bedroom is finally being decorated and upgraded so that the lady of the manor has more room to stash her clutter! Anyway, coat of lacquer went on last night, so some decals next. Watch this space... 1 1 Link to post Share on other sites
The Spadgent 19,775 Posted February 3, 2020 Share Posted February 3, 2020 13 hours ago, Retroeric said: Hi John, picked it up again last night as it happens! It's been sidelined whilst I do man work on the property. The front bedroom is finally being decorated and upgraded so that the lady of the manor has more room to stash her clutter! Anyway, coat of lacquer went on last night, so some decals next. Watch this space... Ha! I know that pain. Similar happenings around here too. The cave looks like something exploded. looking forward to yer decals kid. 1 Link to post Share on other sites
Johnny Tip 411 Posted March 9, 2020 Share Posted March 9, 2020 I repeat TheSpadgent's question... any Hurri Action? (being late to the party, I do this while ducking away... I have been looking for places to build a 1/1 house on to have enough space to keep (and build) the big, big Hurri brother) 1 Link to post Share on other sites
PattheCat 552 Posted March 9, 2020 Share Posted March 9, 2020 (edited) On 1/12/2020 at 6:22 PM, Retroeric said: @limeypilot @dnl42 Thanks for the hints 'n tips, it's most appreciated. In this case, the mis-alignment was caused mainly by haste and naivety. I just glued it, put it together, all felt good, didn't even think to check the alignment. It's a lesson learnt. I'm building this one primarily to practice masking, painting and using micro set/sol more when applying decals, so I'm not going to lose too much sleep over the misalignment issue More pics of the build coming later. You don't beat me, I should appear in the Guiness book because ....... I misaligned the wings of a Tamiya 1/48 Mustang .... yes, THE one you only have to shake and bake, so it was and . Carry on. it certainly looks good and you'll transform a practice run into a home run. Edited March 9, 2020 by PattheCat 1 Link to post Share on other sites
