Jon Bryon
Hasegawa 1/48 A-4E/H/L and TA-4J Skyhawks - update 27/01/20
This is my first WiP thread. I am not sure how it will develop. It will definitely end up with four finished aircraft, but how well I chart my progress to that final goal remains to be seen; I'm yet to see how much work is involved in keeping one of these updated...
The aim is to make Hasegawa's 1/48 A-4E as this (stock from the kit with Fight's On decals):
and their 1/48 A-4L as this (kit markings):
and their A-4H as this (kit markings):
and finally their TA-4J as this (kit markings):
158094-745-1.jpg?w=1000
At this stage the plan is to make them all OOTB.
Thus far I have made some progress with the cockpits. For the first time I've tried painting with magnification, in this case using a x10 hand lens from my distant geologist past. Not ideal, but it was a revelation. The grey is Mr Color 317 and the black is Lifecolor. I've done the painting with an old paintbrush; with a decent brush and slower drying paint, this could definitely be a lot better. However, since all the canopies will be closed and the view into the cockpits is very restricted (at least in the single seaters), this will be adequate for now. The cockpits are very small - even the most zoomed-out image here is larger than real life.
cockpit1.jpg?w=1000
cockpit2.jpg?w=1000
cockpit3.jpg?w=1000
cockpit4.jpg?w=1000
cockpit5.jpg?w=1000
cockpit6.jpg?w=1000
cockpit8.jpg?w=1000
That's it for today. Next goal is to get the cockpits finished, the interior intakes done and the fuselages all together. Progress may be a little slow...
Thanks for looking.
Jon
Glad to see you here, Jon!  Those cockpit panels look fantastic!
If this is the level of quality you're going to keep up then take as long as you need - we'll be watching :D
Very nice! I’ll be keeping an eye on this thread for certain.
- Bill
Nice start on an equally nice project!!
A fair amount of work today without much to show for it. The closing of the fuselage halves is close...just mustn't forget the nose weight!
I haven't got time to spend on detail that won't be seen, so the cockpits are pretty basic (the canopies will all be closed) and the exhausts, whilst painted, are really there just to fill the hole. The intake trunkings have been done but the photos don't show how white the trunking is and how aluminium the fan blades are.
cockpit9.jpg?w=1000
cockpit10.jpg?w=1000
A couple of hours' work before I head to bed.
The weight has been added to the noses, using a combination of steel bearings and small lead balls. I think the latter is sold as ballast for model train rolling stock to weight it down; somewhat cheaper than buying Liquid Gravity. It's all superglued in there: (A-4H and TA-4J)
img_0999.jpg?w=1000
The fuselage halves are glued together with thick superglue on all visible joints. Invisible joints, like the bottom of the fuselage which will be covered by the wing, and the rudder trailing edge, are glued with Extra Thin liquid cement. I use superglue because it's the only reliable way I have found to eliminate ghost seams and get invisible seams. It's certainly pretty brutal to start with and you have no working time for alignment: (A-4L)
img_1000.jpg?w=1000
Work then starts on sanding down the joints. With kicker, this can happen minutes after the fuselages have been joined. I use Infini sanding sponges and sticks as my main weapons of choice, with plenty of other sanders on hand as required (especially those made by Wave). This part is now actually my favourite part of the whole modelling process: eliminating the seams. Here's a start on the upper nose of the A-4E:
img_1001.jpg?w=1000
This is all then polished through the various grits to end up with a reflective surface. I go from 400 or 600 up through 800, 1000, 1500, 2500 and then the 4000 buffer. The joint can then be held up to a light for inspection. It looks like there is still a gap, because the super glue is acting as a filler and a darker colour than the plastic. However, there is no seam at all and this can be visually seen when held to an acute angle with a bright light. I then check the seam, as I have done here, by dragging a needle under its own weight back and forth across the seam. If it catches or moves, you know you still have work to do. If the needle moves smoothly across the joint along its length, then it will be invisible. What I love about this process is that it takes minutes and is 99% accurate at determining the quality of the seam work; I almost never have to readdress any seams after the primer is down because the inspection work is all done at this stage: (A-4E; the hole is meant to be there)
img_1003.jpg?w=1000
img_1005.jpg?w=1000
That's it for tonight. Now there will be many happy hours of sanding down seams, to be followed by rescribing all the lost detail in.
Jon
Great start, I love the crispness of the paint job in the cockpits. I have never had the guts to use superglue for filling seams but it sounds like you have it nailed.
This may not have been the best choice for an inaugural WIP! Progress worth sharing will be slow as everything has to be done four times.
I've already built 5 Hasegawa A-4s in the past, and so I am well aware of many of the issues. The kits are nice, but depend heavily on inserts to cater for variations between all the different versions. In my experience, nearly all these inserts do not fit nearly as well as they should.
The nose for the A-4E is pretty much done. That lump in front of the windscreen took a while to get into shape; we'll see later how it looks against the windscreen. The joints don't look great in the bare plastic because the super glue leaves a black line, but the joint is invisible and soon rescribing in the lost detail will commence.
img_1006.jpg?w=1000
Here's the fuselage spine for the A-4E. Again, the joints look a mess but it's all smooth. You will have to see the photos of this area when the thing is finished to believe me! The insert at the base of the front of the tail fin is too narrow and I have not finished the joints here yet. The navigation light mount is difficult to sand around and again there will be a lot of detail to rescribe in this area.
img_1009.jpg?w=1000
This is the tail of the A-4E. That large semi-circular insert is always a difficult fit, being a bit too narrow. There is a lot of detail to try and preserve and some to replace. The joints are not perfect here by any stretch of the imagination and I will try and get away with rescribing some of the lost panel lines to hide the worst of it. The airbrakes are a tight fit and I intend to leave these undressed as they often stand out in photos of the real thing.
img_1010.jpg?w=1000
img_1012.jpg?w=1000
More inserts are visible here. I am not too worried about the centreline seam as this will largely be covered by the tailhook.
img_1011.jpg?w=1000
The tip of the tail is a separate part that's also too narrow:
img_1013.jpg?w=1000
So the E model is coming along. I've started on the L as well, beginning to deal with the joints around the hump and nose. I'm remaining positive that what looks a mess now will all come good in the end:
img_1014.jpg?w=1000
That's all for now. It will be more of the same for a while!
Jon
Interesting to read your thoughts and findings on the various fit issues with this kit Jon. Nice progress so far as well.
This is why it's a good idea to keep all the spare parts.
Here are all my spare rear fuselage inserts from the nine Hasegawa A-4s I've made/am making:
img_1015.jpg?w=1000
The reason this is useful is that all those little 'nubs' (each part has two of them) are easily lost from the insert and from the fuselage parts during sanding. With all these spares I can remove those nubs on the kit I'm building, attend to all the seams, and then replace the nubs with spares sliced from parts first. Obviously I try and slice them from the kit first, but I need a good source of spares to make up for those that get lost, or get damaged when slicing them off, etc. Here's one of the replacements in place:
img_1016.jpg?w=1000
The fuselage of the A-4H is now together and my focus is repairing the seams on the L and H. The brown areas circled are for removal for the Israeli H:
img_1017.jpg?w=1000
So here's where I stand at the moment. The E has been rescribed and has some thin white plastic card glued in place behind where the exhaust will sit to cover the seam in this area.
img_1018.jpg?w=1000
Thanks for looking
Jon
I've spent a good few hours on these kits today, and progress is good, although not that exciting to look at! I think I'll divide this post up into the individual models. Apologies for the poor image quality; one of my LED bulbs failed and I'm going to have to start to use a tripod for the in-progress shots so I can get a longer exposure and a decent depth of field.
1. A-4E:
The fuselage is basically now done and the intakes have been added, but not smoothed in.
Rear fuselage insert on its way to being blended in to the fuselage, and the white plasticard 'cover' behind the exhaust has been faired in:
img_1022.jpg?w=1000
When painting the intake interiors with Mr Finishing Surfacer 1500 White I took the opportunity to spot prime the upper fuselage seam, which is looking pretty good:
img_1024.jpg?w=1000
With the wing temporarily fitted in place and the intakes added. Next steps will be fairing in the intakes:
img_1027.jpg?w=1000
2. A-4L
Superglue added as a filler around the rear fuselage insert. I hate this piece.
img_1021.jpg?w=1000
Spot priming the upper fuselage seam with Mr Finishing Surfacer 1500 White:
img_1028.jpg?w=1000
Intakes added:
img_1029.jpg?w=1000
Spot priming the rear fuselage insert. Marks indicate some more work is required. You can also see the plasticard cover behind the exhaust fitted and sanded down for this airframe.
img_1030.jpg?w=1000
img_1031.jpg?w=1000
3. A-4H
Areas marked out that need removing/filling for the H model:
img_1023.jpg?w=1000
Nose now sorted:
img_1033.jpg?w=1000
Superglue in place as a filler ready for sanding out tomorrow (hopefully!):
img_1034.jpg?w=1000
img_1035.jpg?w=1000
4. TA-4J:
Fuselage has been glued together with super glue and awaits the joints being sanded down next week:
img_1036.jpg?w=1000
And finally:
Intakes for the H and J still need to be fitted once their fuselages have been cleaned up:
img_1039.jpg?w=1000
Wings are now all glued together with Mr Cement S and will be cleaned up in due course:
img_1037.jpg?w=1000
That's it for now. It's all looking very grey, and will do for some time as construction continues.
Thanks for looking
Jon
It is 3 Scooters!!
Progress looks indeed grey, but goood!
35 minutes ago, exdraken said:
It is 3 Scooters!!
Thanks. But actually it's 4 :)
Jon
Jon
Oh sorry!
How could I miss the 2-seater! The 3 others need to train of course ;)
Great production line :)
All four look to be coming together smoothly :)
Building in quadruplicate means many hours of work without much apparent progress!
Here is where we stand:
Fuselages:
These are mainly finished with the fuselage halves all together, the inserts faired in and the main intakes added (the fronts will go on later). Detail has been rescribed and all the seams eliminated.
This will be a bit repetitive, but here is the A-4E:
A-4L:
A-4H - note the reinforcement plates present on the E around the intakes have been removed:
And here's the underneath of the TA-4J:
Wings:
The leading edge lights, which are a terrible fit, have been faired in with superglue and polished:
One major fault with the Hasegawa A-4 is that the leading edge slat 'bay' is recessed into the wing. It should be a smooth transition to the rest of the wing without a lip. Having already built five Hasegawa Skyhawks without caring about this inaccuracy, I was prepared to do the same with these four. However, curiosity got the better of me and I decided to see if I could fix the issue.
The first step is to use some 0.4 x 1.6mm Evergreen plastic strip superglued against the lip:
This looks a mess. After sanding it down with progressive sanding sticks (400, 600, 800, 1000, 1500, 2500 and 4000) it looks like this:
You can see I've used some washi tape to minimise damage to the surrounding area. The brown circles are where there are some imperfections that need a drop or two of superglue. Once these are added and sanded down, the finished wing looks like this:
Some of the recessed detail needs to be rescribed in, which has been done and highlighted here: (Note that this photo is of the first wing I did where I snapped off the slat actuator during the sanding process. This was prevented on the later wings by using the washi tape.)
Bits and Pieces.
Many other happy (!?) hours have been spent cleaning up a ton of pieces: landing gear, gear doors, slats, flaps...
And when not in the modelling room, I've been doodling away at adapting the decal instructions into a masking stencil for the A-4E:
Well, that's enough on the internet. I'm off to finish the last wing...
Thanks for looking
Jon
That looks like impressive progress to me Jon :thumbsup:
