Walter Posted January 1, 2020 Share Posted January 1, 2020 I'm after your help, what is the solution to fixing this blemish? I want to airbrush it but am concerned I will make it worse with over spray even when masked. I feel the easiest option will be to use a brush but the finish will be glocier compared to airbrush. I'm really stuck on what to do I'm hoping the master painters among you can help. Thanks Walter Link to comment Share on other sites More sharing options...
dogsbody Posted January 1, 2020 Share Posted January 1, 2020 I'm no expert on painting, especially airbrushing, but I'd try a bit of a rub with some fine paper/sanding stick, then a re-spray of the blue. Chris 1 Link to comment Share on other sites More sharing options...
Cheshiretaurus Posted January 1, 2020 Share Posted January 1, 2020 Seconded. Very light sanding 1200 grade or higher. Take your time. Mask with white tac. Then very lightly air brush and build up the layers. Might take a few hours. But will worth it and as always it will add to the skill bank . Its all a learning process. 2 1 Link to comment Share on other sites More sharing options...
Grey Beema Posted January 1, 2020 Share Posted January 1, 2020 As above but when you come to start airbrushing, stick a ‘Post It note’ just out of the area to be painted. When you start spraying, start it on the Post It then spray down onto the area. It just eases any problem with the start of your spray run.. 1 1 Link to comment Share on other sites More sharing options...
Walter Posted January 1, 2020 Author Share Posted January 1, 2020 (edited) 3 hours ago, Grey Beema said: As above but when you come to start airbrushing, stick a ‘Post It note’ just out of the area to be painted. When you start spraying, start it on the Post It then spray down onto the area. It just eases any problem with the start of your spray run.. Thanks good tip Edited January 1, 2020 by Walter Link to comment Share on other sites More sharing options...
Max Headroom Posted January 1, 2020 Share Posted January 1, 2020 Cut out a decal to the shape of the panel, airbrush it and then apply? Trevor Link to comment Share on other sites More sharing options...
nheather Posted January 1, 2020 Share Posted January 1, 2020 Just a thought, no expert, but if you mask out and spray whole panels, even if the colour is slightly different you won’t notice it because the dark demarcation of the panel line will break up the transition. Cheers, Nigel 1 Link to comment Share on other sites More sharing options...
Steve Noble Posted January 1, 2020 Share Posted January 1, 2020 (edited) Rub out the damaged area with fine wet and dry. Mask around the damage up to a panel line, repaint the damaged area, remove the masking and job done.. Edited January 1, 2020 by Steve Noble 1 Link to comment Share on other sites More sharing options...
