1/350 DD-445 Fletcher Tamiya + Eduard
Nimitz
Hello all,
I am working on Tamiya's 1/350 Fletcher with Eduard's PE set. Tamiya's kit is best Fletcher in its scale but still has inaccuracies and fitting issues, also Eduard's set suffers from same problems. You have to check your references before installing nearly every piece. I am not a ship expert and sometimes my models suffer from inaccuracy and mistakes but I am trying my best to build them close to the real one as much as possible. So, let the photostream begin
TDAqQvIqnlXNL1eAthI-ytKstUuy7tdIeFHfKlEY4lQ
Update 29 November:
20190821_150259
Beside these books, Internet is always your friend
20191129_163500
Let's start then!
Ugly seam lines are sanded down. I really liked that plating on the hull, nice job Tamiya!
20190925_143804 20190925_143755
Guess what is modeled accurate in anchor deck?
20191112_111812
Nothing.
DD445Windlass-13Aug43_zpse6e37859
So I had to scrape them all
20191112_214718
Next on the line: Propeller shafts
20191124_194552
Rudder is movable, cool
20191127_193634
I also filled the gaps for propeller guards which will be replaced with PE ones.
20191129_173422
And this is my organizer for ongoing builds. Helps me a lot to not lose their pieces. Fletcher is currently using nine rooms.
2019-11-29_05-55-29
And we need to get rid of that mast
20191124_210752
First step. Choose the correct diameter for mast (1.5mm) and then angle it correctly accoring to the ref pics.
20191124_210808
Ref pic
2019-11-25 00.13.50
With her little sister, USS Cushing from Tamiya again. It was an old, brush painted model that I will convert her to FRAM Fletcher, hopefully soon
20191129_173349
Update 16 December :
Main mast nearly finished. It is made of brass rods, sheet brass and plastic rod plus Eduard's set
20191214_001129
20191214_000959
Looks better now, huh?
And now for stacks, they need love too.
Exhaust drilled
20191129_205051
The pipes that carry smoke to the funnels are made of plastic rods.
2019-12-16_09-33-41
Grills from Ed
20191129_212750
A little comparison with standard stack. The main pieces are not glued but it still needed lots of CA and glue...
20191129_212825
Little bit more PE
20191216_191916
20191216_192009
The only remaining thing for fore-stack is pipes going straight above through the roof near ladder you can see in the photo above
Before removing doors and ladders we had to check references to be sure...
20191202_232226
Then, attack!
20191214_234458
20191214_234412
As you can see, there is a ugly gap between guard railing with fore-deckhouse, it will be filled with CA...
Update 30 December:
Also everything on the bridge is sanded down.
20191214_213913
And...
20191225_190529
Also these ugly stairs are removed and replaced too...
20191214_214902
20191225_205044
It was the hardest part of this build so far... The torpedo tubes...
20191230_143547
Mid-deckhouse, %90 completed
20191230_145746
20191230_145413
20191230_145814
20191230_145449
That's all for now. As you have noticed, this has been split in three update sections because I had posted them in Hobimaket before signing up here. But from now on, the updates will be launched simultaneously. This is my first ship build with a large set of PE, so I had done lots of mistakes and still doing but hey, it is for fun and i am enjoying the process.  Hope you like my works and all comments are valuable and welcomed.
All hands on deck!
-Eren
Edited by Nimitz
Gidday Eren, a person who has never made a mistake is a person who has never tried anything. As long as you are enjoying the build that is all that matters. I have a couple of these but haven't started them yet. I usually work in 1/600 scale but I got these two for a price I couldn't refuse. I recall a critique a while back over this kit that states the turrets are a little undersize. I don't know but you might like to check them before installing them. Hopefully they will be OK. If not then I guess we have some scratch-building to do.
     Keep up the good work. Regards, Jeff.
Thanks Jeff, I am still waiting for metal barrels to arrive, so I could start the turrets. I didn't noticed that they were undersized but I knew they weren't correct. The real gun house of Fletcher's 5 in guns were not on center. So, I was thinking how could I correct this without major surgery, scratch building new ones or getting aftermarket turrets seemed the only way. Considering I am spending money for detail sets for my 1/350 Hancock, it is not very possible for me to buy new turrets for Fletcher. And about scratch building new ones, I am not sure is it worth the effort and time...
Regards,
Eren
Edited by Nimitz
