Julien Posted December 29, 2019 Share Posted December 29, 2019 Avro Cierva C.30A Civilian Service (41006) 1:35 MiniArt via Creative Models Ltd There was a time when the Autogyro was looked at with great promise but the never materialised, The Avro licence built the Cierva C.30 designed by Juan de la Cieva. This was built from the fuselage of the Avro Cadet biplane and used an Armstrong Siddeley Genet Major engine. Lift was provided by an 11.3m diameter 3 bladed rotor. It was also used by the RAF, as well as civilian examples requisitioned, they purchased 12 of these under to equip the school of Army Co-operation. It was to be used for observation and light duties but was not taken any further in this role. It was the invention or Radar which was to find a wartime use for the 671. In order to calibrate the Chain Home stations the RAF needed an aircraft which could fly very slowly on a pre-defined heading and altitude. The RAF formed Flight 1448 at RAF Duxford to preform these duties. This later become 529 Sqn at RAF Halton. Post war 592 Sqn was disbanded and the gyro copters sold off. One of these was sold to Sweden and purchased back by the RAF Museum. The Kit Until now I don't think there has been a kit of this in 1.35 scale. The kit is upto Minart's modern standards; there are 4 main sprues, 4 smaller sprues, a small clear spure and a sheet of photoetch in the box. Even in 1.35 scale this is not a large kit. Construction starts with the front mounted radial engine. The cylinder banks are made up with the exhaust and collector ring being added. Ancillary parts are then attached to the engine and it is put aside for later. Construction then moves to the interior/cockpit. The two seats are made up complete with PE seatbelts. These then attach to their mounting frames. Onto the cockpit floor are mounted the rudder pedals and control column. Additional controls are added to the side frames and then these frames can be attached to the cockpit floor. Front and rear control panels are then added. The seats are added in and then the side frames added. The cockpit can then be closed up inside the main fuselage, Next up the mount for the rotor blades is made up and attached to the fuselage. The tail wheel assembly is added as are the tailplanes. At the front the engine cowl are is made up. The engine and its propeller are then added. The landing gear struts are made up and the wheels are added. Lastly the rotor blades are made up and added, these can either be in the flying or stowed positions. Markings There are four decal options provided on the sheet From the box you can build one of the following: LN-BAD Used to advertise Norwegian Tobacco Company Tiedemanns 1934 (mainly blue) VH-USQ private machine based in Marylands, Western Australia 1935. (mainly white) G-ACUT Cierva Flying School, UK 1930's (Mainly blue with Aluminium Engine covers) OK-ATD Used to advertise Bat'a Zlin, Czechoslovakia 1930s. (Green with white cheat line - as box art) Decals are printed by DecoGraph and have good registration, sharpness and colour density, with a thin matt carrier film cut close to the printed areas. Conclusion This is a really nice rendition of this unusual but important civil aircraft from the 1930s. Very highly recommended. Review sample courtesy of Link to comment Share on other sites More sharing options...
