Bryan71 Posted December 29, 2019 Share Posted December 29, 2019 (edited) After having a break from modelling.I’m only doing figures 1/35 and 1/16 and 1/10 Busts I have an Eclipse 0.35 which I use for Mr Surfacer 1500 But I have ordered some Stynylrez.I have an Infinity with a 0.4 set up will the 0.4 be a big enough needle size for spraying Stynylrez. Or do I need a bigger.I know I can change the Eclipse to a 0.5 but keeping that brush for Lacquer paint.I had looked at the Iwata HP-TH Edited December 29, 2019 by Bryan71 Missed some off Link to comment Share on other sites More sharing options...
Jinxman Posted December 29, 2019 Share Posted December 29, 2019 I have an 0.5mm HP-TH and would say it is probably too much for your target builds. I use it on stuff like 1/72 bombers, 1/48 fighters, 1/35 AFVs and so on. It will spray Stynylrez, Mr Surfacer, and anything else I have with ease, and with both types of cap. Coverage is great, but probably too great for your builds. Your 0.4mm setup sounds as if it would perform fine, but I don't have an Infinity, so I'm guessing. 😀 Link to comment Share on other sites More sharing options...
Bryan71 Posted December 30, 2019 Author Share Posted December 30, 2019 Thanks for your reply I have been in 2 minds about the TH and not being able to try one.Your probably right about being a bit to much. Link to comment Share on other sites More sharing options...
Earnest Posted January 13, 2020 Share Posted January 13, 2020 I spray Stynylrez with a 0.3 side feed Olympos and a 0.4 gravity feed HS. Working fine on both. I don't thin it and I never had problems. Link to comment Share on other sites More sharing options...
