Airfix Tomahawk IIB - Finished 15.5 hours
AdrianMF
Do you even know how to build a regular injection moulded kit?
Are you going to do some fantastic mods to it?
My chair is pulled up and snacks and liquid refreshments are near at hand.
Chris
I hope building the mince pie component doesn’t count towards the 25% rule:
5-C88-A966-9-EAE-4-D43-9615-77-AC19-D582
you can see that I don’t work as a food photographer!*
Interesting to note that the kit has a bit of three part slide moulding because the upper cowling piece is moulded top and bottom and then has an additional mould that adds the air intake opening and overhanging machine guns. Is that a first for Airfix?
Regards,
Adrian
(*) or a pastry chef!
  • Haha 3
1 hour ago, JOCKNEY said:
what area are the markings for ?
Squadron Leader Peter Wykeham-Barnes, 73 Squadron RAF, El Gamil, Egypt 1941.
I already have the old Airfix Kittyhawk with a shark mouth and desert camouflage so I wanted a change.
Regards,
Adrian
Two and three quarter hours in and the airframe is together:
BA60-CDDC-9-EA0-471-B-92-BB-4-AD86-E4819
I did seat belts and drilled the fuselage guns out, otherwise OOB. Propeller blows round and the airframe is aligned after judicious trimming here and there, and will only need a sweep of PPP.
I am being taken out for a walk with the family now so it’s a good time to let it all set...
Got back on this at half-past four after a walk and some lunch.
All the seams cleaned up with a couple of swipes of a sanding stick and so I’ve added the undercarriage doors and radiator gills:
359-B5-AA9-9-B48-4-C94-92-BC-D2359-C4714
668-D1425-1-CCE-4-B89-9-BEE-99-D77-FDDD2
PPP next and then we can do some Sky!
The kit is great! I dare say Tamiwagaboss would have done it so I didn’t need a couple of scrapes of PPP at the roots, but the joins are mostly along panel lines, seams seem (sorry) to have disappeared under the Sky coat and the panel lines look suitably petite.
And the mince pies were indeed dusted with icing sugar, carefully matched to Humbrol Matt 34.
  • Haha 3
Thanks Steve!
Well, my chances of making this in 12 hours have quietly left the building and gone to the pub.
However, I’ve got the brown on (five coats??!) and done all the fiddly bits apart from the cockpit. So it’s green, stickers, cockpit, weathering and details for me:
B7511729-4364-4279-B9-E1-BBA7-B5-F3-EB97
Should be done in 14 hours or so.
Adrian,
This is looking great. I have one where I've sawed open the cockpit and filled the gap between cockpit floor and walls. Seeing your result, I'm not very sure why I've bothered. I must try one OOTB too,
Alan
OK, stop the clock at fifteen and a half hours:
275-E5501-1-C08-4-B39-BC56-65190-F1-A6-A
7-A0-D8885-2-F8-D-4-A36-9153-2-A73-E5-DD
Probably about eleven hours modelling time in that, so I’m pretty happy.
I added seatbelts and hollowed out the exhausts and fuselage guns. Otherwise OOB! I skipped the stencils because they were all really small and I couldn’t even see them against the camouflage to position them.
Overall a smashing kit. The only real downside for me is that the undercarriage is quite loose and feels very fragile with the soft plastic.
I will take some pictures for the gallery tomorrow morning and if I’m up well before 1100 I might even varnish it first.
Thanks for looking,
Adrian
  • Like 11
