Adam Poultney
Best 109 kits of each variant
In 1/48 scale Eduard Bf 109F/G are actually not as accurate as many think. The Zvezda Bf 109F/G-6 and the Tamiya Bf 109G-6 are much better in that regards whereby the Zvezda kits aren't the easiest builds. Here is a comparison.
The Tamiya Bf 109G-6 in 1/48 and 1/72 scale are easy builds and accurate.
Cheers, Peter
3 hours ago, NorthBayKid said:
I can’t think of many serious modelers (serious enough to be reading this discussion forum) who would even think of using Tamiya kit decals.   There must have been about a million and six different Bf 109 decals produced in 1/48 just in the past 30 years or so, so it’s not as if anyone is going to go lacking for decals for the gem-like Tamiya kit.  Their choice of subject matter is pretty pedantic in any event.
I was just trying to be objective, and I certainly have a slew of aftermarket decals from which to choose when I build my Tamiya G-6. However, I must say I used at least some of the kit decals on more than one Tamiya build (Meteor Mk. I, Do 335, F-16C) and found them to behave quite decently.
Besides the eduard kits I find the Zvezda 109 G-6 a very good build. Not easy, but with full engine and good cockpit interior. Underestimated and very good value for money, I did not count the rivets, but it very much looks like a 109.
Volker
On 12/23/2019 at 6:30 AM, Adam Poultney said:
Sorry for another 109 thread, but I don't believe this information is all collected together in once place (it may be scattered throughout a thread somewhere but not in an easy format to find anything easily that I know of). What are the best Bf109 kits of each variant in each major scale? I would like to make a list on this thread for ease of access to the information. Personally, I am particularly interested in 1/72 the most, but I'd like to do this for all the major scales.
For each variant I would like to record the most accurate and the best value kits, and which subvariants are available for each
*This list is far from exhaustive and I still likely miss some information, I recommend you read the discussion on this if you want extra information. Some variants will have multiple kits listed, this will be because there are multiple very good kits and not one distinct best.
I have asked a similar question before, but a lot of variants are missing, I have taken some of the information from that thread for this. If you disagree, or if I've missed anything please do say so. I am far from the world's leading expert on Bf109 kits.
Llyn Ritger (Mr 109) and his website "The 109 Lair" would likely have a lot of extra info. He has published a set of volumes on the 109s . I'm not sure if the webby is still up but Mr Google will know. HTH JH
if you are interested in 1/32...
E
DML / Cyberhobby are superior to Eduard in almost every respect
DML only make E-3, E-4 and E-7 Trop (only Eduard make an E-1)
F
Hasegawa (and reboxed by Revell) have good overall shape and excellent fit
Trumpeter's F-4 is really closer to a G-2 (I'm not sure about their G-2)
both are decent kits in my view
G
Trumpeter do play here but not as good as Hasegawa across the board
G-6
Revell could have been so much more but some really shitty design decisions as well as actual shape errors
For me Hassy easier to build, but there is now lots of aftermarket for Revell, so depending upon what you want, it's a toss up between them
if the G-6 is your thing, take a look on Large Scale Modeller where there was a super extensive review done by Matt Low and Mikester I believe - both 109 experten
G-10
Only Revell have done a proper Erla in injection mould
K
again, I don't think trumpeter match Hassy or Revell, where these two have pros and cons; Hassy does go together nicely
if you are really into accuracy, look out for resin cowling / entire nose replacements from AMUR Reaver (they are Russian, available on ebay)
hth
Having built both AZ's G and F's, I have to say that despite looking nearly identical in the box, the Fs are MUCH better in terms of fit although the smaller parts are still a bit fiddly and have a short-run feel to them.
Seeing as 1/24 features in the OP's list, I will offer a very brief verdict on what's out there. The Airfix 109E is (to this amateur at least) a lovely kit - very basic by modern standards, but a decent shape and fit, and ripe for detailing. Having both types of canopy certainly helps. The Trumpeter 109Gs and K-4 are as detailed as you would expect from a modern release. There are plenty of reviews which give the full account of all the pros and cons, which I won't attempt to improve on, but suffice to say that they turn into very impressive models!
Great post Adam. Admin should have such info pinned. I think this should include kits to avoid, like the G6 by Italeri that I'm working on,  it's horiible!
The 1/72 Kovozavody Avia S-199 fuselage looks as if it has been corrected around the front wing/fuselage compared to the old AZ 109G kits, which had the awkward nose due to this.
Interesting that you should mention this.  Some time back on a 1/72nd forum, I saw this pointed out and AZ's resident know it all, Jane Pulke, would not even address that.  This was when they were still trying to convince everyone that their 109 kits were "accurate" using the justification they had won an award from some model show.  Jane would chose to attack and threaten anyone who pointed out that their kit is flawed rather than to man up and admit they erred.
It's funny that KP (which is the sister company to AZ) got the nose/fuselage of their S-199 right, why hasn't AZ been able to?
AZ has changed the nose of their later G kits, although have not produced revised versions of their earlier releases.  I must admit being amused at the reference to the AZ kits as "old", which does rather restrict the vocabulary when referring to (for example) the original Airfix 1/72 F, G, and previous G-6.  Medieval?  Prehistoric? Antediluvian?
12 hours ago, Adam Poultney said:
Time to update the post I think
not a lot has changed in the 1/32 109 landscape since my post, or have I missed something?
Just hadn't added some of the info posted in a while lol
No mention of a Bf-109K-4 in 1/48. Hasegawa kit can fit this slot if you want to have a representative.
Having built all three brands in the last 2 years I disagree with some of the opinions expressed so far.
Zvezda kit seems accurate in proportions but has some soft details including an odd upper side vs lower side of the elevators...the detail is good when you look at the upper view and non existent in the lower. But the real weak point is that the dihedral angle of the wings is too  shallow, and this is visible in a photo posted on a previous comment in this thread.
IMG_3184
Eduard looks equally accurate to me, and has the best details OOB. I prefer them above others
SAM_4409
Tamiya offers the easiest to build kit, with accurate proportions and good detail. It’s also the most expensive of the lot.
basically all 3 are splendid kits and only personal preference (or wallet size) can make one choose which is better
Ok, I'll list all three with their respective advantages and disadvantages
Edited by Adam Poultney
