dcrfan 341 Posted December 20, 2019 Share Posted December 20, 2019 I recently purchased the 1/48 Airfix WMIK and Snatch Rover set. I've been looking online at various Snatch pictures and have a query, is the Snatch as offered by Airfix correct for a Northern Ireland paint scheme? I'm looking at using the WMIK as the basis for a Shortland Armoured Car (with chassis back dated to Series 3 and Bedford MWD wheels). Link to post Share on other sites
viper-30 458 Posted December 21, 2019 Share Posted December 21, 2019 Pretty much mate leave off the desert antenna boxes.. Link to post Share on other sites
dcrfan 341 Posted December 21, 2019 Author Share Posted December 21, 2019 Yeah thanks. An excuse to stay out of the sun over the Christmas break Link to post Share on other sites
ivan-o 1,197 Posted December 24, 2019 Share Posted December 24, 2019 You might want to consider these for the sides of your snatch.NI confidential No’s etc. http://www.kingfisherminiatures.co.uk/ Link to post Share on other sites
RAFP8911 20 Posted April 20, 2020 Share Posted April 20, 2020 https://www.joint-forces.com/features/military-land-rovers/17751-military-land-rovers-pt-8-cav-100-snatch There’s some good photos here on this website, to me, the most obvious difference is the roof mounting for the various antenna & ECM gubbins. Link to post Share on other sites
Black Knight 6,341 Posted April 20, 2020 Share Posted April 20, 2020 Some of the BA Afghan Landies just got white paint slapped on them and some PSNI markings and were used during the G8 conference a few years ago. On some the white paint was put on so thin the desert colour showed through. Link to post Share on other sites
dcrfan 341 Posted November 30, 2020 Author Share Posted November 30, 2020 (edited) On 12/25/2019 at 1:05 AM, ivan-o said: You might want to consider these for the sides of your snatch.NI confidential No’s etc. http://www.kingfisherminiatures.co.uk/ I finally applied one of the yellow Kingfisher phone numbers but a total failure. Can't see a darned thing as the yellow is completely translucent. IMG_4278 by tankienz, on Flickr Edited November 30, 2020 by dcrfan Link to post Share on other sites
John Tapsell 136 Posted November 30, 2020 Share Posted November 30, 2020 (edited) Yep - the Kingfisher decals are laser-printed printed onto clear decal film. Most small home/office printers can't print white so although the decals look good on the white backing paper, there is nothing solid under the lettering to make it stand out once you apply them to the model. You would have exactly the same issue with the red version of this decal sheet. If you were applying the decals to a white vehicle, they would stand out fine. Some of the Kingfisher sheets are printed on white decal film but that creates the opposite problem - you have to remove any film from around the decals to avoid the white showing up where it shouldn't. One solution might be to commission a custom set of decals from a company that can print with white ink. Typically these small-scale produceers use ALPS printers (a specialist printer that can use white ink). Such companies are generally not expensive to deal with - I recently had an A5-sized sheet of decals (for several projects) printed for less than £20 (but I did supply the finished high resolution artwork so they didn't need to create it themselves). The big decal printing companies use a silkscreen process that allows them to print white ink but these commercial printers are much more expensive so it only makes sense because they are printing larger quantities of each sheet. Edited November 30, 2020 by John Tapsell Link to post Share on other sites
Das Abteilung 2,152 Posted December 1, 2020 Share Posted December 1, 2020 Archer make yellow dry lettering which might work. Not sure what the sizes are. But get it while you can as Archer have ceased production of their entire dry decal range. Link to post Share on other sites
