phat trev Posted December 19, 2019 Share Posted December 19, 2019 I am wanting to start my 1/72 esci M4A1 Sherman Calliope tank kit over Christmas but wanting to construct a British Army Sherman. Can this type be used as a basis for the build? Minus the rocket tubes! Link to comment Share on other sites More sharing options...
Orso Posted December 20, 2019 Share Posted December 20, 2019 Probably not. It seems that the old Esci M4A1 only can be used for a Duplex drive tank. https://www.onthewaymodels.com/articles/shermandebacle.htm Link to comment Share on other sites More sharing options...
sandsmodels Posted December 20, 2019 Share Posted December 20, 2019 the only late m4a1 75mm used by the british in nwe seems to be a dd, although most were earlier ones. there are pics of a few of them in normandy. no calliope were used by the british. Link to comment Share on other sites More sharing options...
phat trev Posted December 20, 2019 Author Share Posted December 20, 2019 (edited) Thanks both. The model is the Calliope version of the ESCI kit but not looking to make this type. So is this type (sans launchers) a late model m4a1 then? I am looking to see what conversion scratch building I would need to replicate a British Army Sherman of this type Edited December 21, 2019 by phat trev Link to comment Share on other sites More sharing options...
Orso Posted December 22, 2019 Share Posted December 22, 2019 No, the Esci kit has the wrong turret for its hull . That combination was apparently only used on a few DD-tanks so either a new hull or a new turret is needed to build the Esci kit if one can't find a DD conversion. Link to comment Share on other sites More sharing options...
phat trev Posted December 22, 2019 Author Share Posted December 22, 2019 Will have to look at changing the turret then or scratching it to create the versions I am after, a Sherman II or IIII (75mm gun) Link to comment Share on other sites More sharing options...
Orso Posted December 23, 2019 Share Posted December 23, 2019 I just added my early Sherman II conversion to my home page: https://www.baecklund.eu/scalemodels/72/sherman2.html Link to comment Share on other sites More sharing options...
phat trev Posted December 24, 2019 Author Share Posted December 24, 2019 That is a great looking model conversion Orso and a good indication of some of the changes needed, thanks for posting! Link to comment Share on other sites More sharing options...
sandsmodels Posted December 24, 2019 Share Posted December 24, 2019 great conversion Link to comment Share on other sites More sharing options...
Kingsman Posted January 1, 2020 Share Posted January 1, 2020 You essentially have 2 British choices for your Esci Calliope kit. Option 1 - replace the upper hull with a small hatch type in order to make a 75mm Sherman II. If the turret has a loader's hatch this will need to be filled in. Option 2 - replace the turret with a T23 type with 76mm gun to make a Sherman IIA as used in Italy (and by the Poles under British command in NWE). However, both of these suggest buying a more appropriate kit as the necessary after-market parts will cost more than the original kit. For a Sherman III you definitely need a new starting point as you need new upper and rear lower hull. I don't model in Braille scale so my knowledge of who kits what in that scale is very limited. I do like the fact that UM offer just about every service configuration of Sherman and many of their kits include optional parts including drivers' hoods eg DV and non-DV. Their Sherman III kit has cast, welded and DV hoods included, for example. Link to comment Share on other sites More sharing options...
