Neil.C Posted December 19, 2019 Share Posted December 19, 2019 (edited) I have been kindly bought a Revell Skyraider 1/48 for Christmas but looking through the instructions the overall colour of Sea Blue is FS 15042? I have no idea what that is and have a large amount of Humbrol tins so I'm hoping I have something that will do or will spring for something. Is it gloss? Any equivalents? It is for brush painting and I'm not particularly anal about accuracy as long as it looks good. Edited December 19, 2019 by Neil.C Link to comment Share on other sites More sharing options...
stever219 Posted December 19, 2019 Share Posted December 19, 2019 (edited) You've git an FS595B paint reference there with "1" as the first digit: that means it's a gloss finish, "2" is satin and "3" is matt. If your stash of Humbrol contains a tin if the now-discontinued 181 you're in business, if not 15 or 104 are the next closest IIRC. Hannants do Sea Blue Gloss in both Xtracolour "Nevadry" (takes ages to dry in my experience) or Xtracrylix as do Sovereign Hobbies in their Colourcoats range. Don't forget that paint fades and stains in use, particularly in maritime environments, and that no two batches are exactly the same colour. Edited December 19, 2019 by stever219 Typo/ memory leak. 1 Link to comment Share on other sites More sharing options...
Troy Smith Posted December 19, 2019 Share Posted December 19, 2019 (edited) 3 hours ago, Neil.C said: I have no idea what that is and have a large amount of Humbrol cans so I'm hoping I have something that will do or will spring for something. see US Navy Sea Blues cause a lot of confusion! according to @Mike Starmer Humbrol 181 is post war US Navy gloss sea blue, if you have that, problem solved. Quote Is it gloss? yes, but not high gloss unless polished. This should really in the cold war section, in this build @russ c used 15 midnight blue and added gloss black, though I's suggest some dark blue-green as well if you have any. (or Luftwaffe blackgreen) see also https://tailspintopics.blogspot.com/2012/06/sea-blue-vs-insignia-blue.html Correct link added. Edited December 19, 2019 by Troy Smith link corrected 1 Link to comment Share on other sites More sharing options...
Tailspin Turtle Posted December 19, 2019 Share Posted December 19, 2019 (edited) 12 minutes ago, Troy Smith said: US Navy Sea Blues cause a lot of confusion! according to @Mike Starmer Humbrol 181 is post war US Navy gloss sea blue, if you have that, problem solved. yes, but not high gloss unless polished. see also https://tailspintopics.blogspot.com/2012/06/sea-blue-vs-insignia-blue.htm That link works if you add the “l” to the end of it, i.e. html Edited December 19, 2019 by Tailspin Turtle Delete stuff from original 1 Link to comment Share on other sites More sharing options...
Neil.C Posted December 20, 2019 Author Share Posted December 20, 2019 Thanks for the help as usual Gents. Very enlightening. Sorted through my Humbrol tins and found a new Midnight blue 15 which I will use. Link to comment Share on other sites More sharing options...
