roadrunner
Caudron C450 SBS 1/48....
Hello,
just received already started.
In the box:
Very clear resin canopy
I start with the cockpit, adding some details that will finally not be seen
modified left fuselage for opened canopy. The right unmodified to see the difference.
Scratchbuilded new instrument panel. The SBS is correct for a C460, not for the C450
soon, the painting...
Edited by roadrunner
Ahhhh, what a pleasure!
Looking forward to enjoy this build.
Such a graceful subject and great modeler!
What Moa says.
Lovely work already in the cockpit.
Pity you can't get those i/p bezels in 1/72, would save a lot of hassle. Then again, once you close the fuselage, you can't see very much anyway.
Question about the sliding canopy: When it slides back, does it drop down to become flush with the fuselage?
Stuart
no drop down.
C450 I/P and canopy sliding system. (the same sliding canopy system for all racing Caudron, I/P could be different)
9 hours ago, roadrunner said:
no drop down.
I think that what Stuart is pointing out (I may be wrong) is at the step created by the thickness of the canopy mold, easily solvable sanding carefully just a bit to get a thinner lip, since the sanding won't affect any "clear" areas:
Link to photo of open canopy on Getty Images:
https://media.gettyimages.com/photos/picture-taken-in-the-30s-of-french-woman-aviator-helene-boucher-her-picture-id461227930?s=2048x2048
@Moa, the image shows what I'm referring to. That front edge of the sliding canopy shows clearance between the canopy and fuselage. When that canopy slides back, what happens to that clearance? Does it drop down to become flush or is their a lip to make it flush?
Stuart
That's a very meticulous and clean build, it's looking great.
8 hours ago, Courageous said:
Did you make the vac canopy using the kit canopy as the master?
Stuart
I make a plaster copy with Oyumaru mold.
On 1/21/2020 at 7:05 AM, roadrunner said:
Just a 1st coat of TS44
An interesting choice of paint.
Stuart
Stuart
Not for the C714R, more darker, if painted as she is preserved at MAE.
No, not for 714R. It was my future builds of Caudron racers as I hate mixing paints. I would like a 'go to' paint to keep things simple and your choice of TS44 is interesting, it's not too far off what @Bengalensis c.450 & C.561 build?
Stuart
I don't have any can of TS-44 here, but I think it's a bit lighter than the blue I used, but it's only what I think, it's difficult to compare colors on different pictures on a screen. Then again, I really have no idea if my blue is even close to correct. If it looks good to your inner picture than go for it, it's looking nice on this build.
A beauty!
