Sign in to follow this
Julien
Caudron C.450 - 1:72 SBS Model
Caudron C.450
1:72 SBS Model
The C.450 was a racing aircraft designed and built to take part in the 1934 Coupe Deutsch de la Meurthe race. It was developed from the C.362 flown in the race the year before. 1 C.450 with spatted undercarriage and 3 C.460s with retractable undercarriage were built for this race. The aircraft were mainly spruce and birch plywood with metal engine bearers, cowling and fuel tanks. The aircraft would be further developed into the C.461 for the following years race. As a racer the C.450 set a world speed record of 268.21 mph and did win the 1934 Coupe Deutsch de la Meurthe race.
The Kit
The kit from SBS is a full resin kit, with resin clear parts, photo-etch, pre-cut masks (not shown) and decals.  The resin parts are exceptionally well cast and look to be easy to remove from their pour blocks. The reviewer is building the SBS Caudron C.600 and the parts in that kit came away easily and cleanly. Construction starts with the cockpit and placing in the front and rear bulkheads along with the floor, seat, controls, and instrument panel. A tip is to put the internal in and check the fuselage alignments before doing any sanding of the fuselage halves.
Next up the wings can be added to the fuselage. A tip from SBS here is to join the wings and then add them to the fuselage as there are slots for them. Once the wings are on the spats and wheels can be added. At the rear of the plane the fin, rudder and tail surfaces are added, along with the tail wheel. At the front the engine is added, along with the front, props & spinner and the exhausts.
Decals
Only one scheme is included which is the winner from the 1934 Coupe Deutsch de la Meurthe race.
Conclusion
This is a fairly simple little kit, much like the real aircraft. If should pose no problems to a competent modeller and maybe a good starter into resin models. Highly recommended.
Review sample courtesy of
Insert other media
I have SBS's 1/72 Comet kit and can only echo Julien's comments on the quality of the castings and kit in general.
