cema_ga
Finished! Fw-190F-8, twin build DML+Eduard 1ed, 1/48
Hi comrades!
My next build is twin! The old DML (I have it since 1992 😜) and 1st edition of Eduard will be built as last ground attackers of Luftwaffe, both from 1945 in Czechoslovakia airfields.
The variants will be with different ordnance:
Eduard - with Panzerschreck, DML with bombs
So far, interior was finished and main construction completed for both kits. The DML fuselage was widened in the bottom aft section to produce the wing-to-fuselage joint without gaps. Main issue with Eduard is closing the unwanted  openings on the wings - the only use of putty so far. Now we are almost ready for the primer! Eduard is in olive colored plastic.
Thanks for looking!
I wasn't expecting that Panzershrek.
Edited by Sturmovik
Hi comrades!
The first 190th, (Eduard) is painted, decals applied and panelwash done. "Shrecks" added.
Now some more weathering and to the scratch-building parts for the DML.
Thanks for looking!
Hi comrades!
The Eduard's Fw-190F-8 done (minus antenna, will add before final photo-session)! Better pictures will be in RFI section a little bit later.
Next stage - some scratch build on DML kit
Thanks for looking!
Hi comrades!
After some scrachbuilding and painting/weathering, the DML kit also finished. This twin build is my #7 and #8 completed builds for 2019.
Sure, better photos will be posted in RFI section.
Thanks for looking!
