Bughunter
Phönix D.I K.u.K. Kriegsmarine, Special Hobby 1/48
Hello,
I build some time ago the D.I  Special Hobby: Phönix D.I K.u.K. Kriegsmarine again in 1/48.
The plastic parts are somehow of short run quality, but really not bad! The kit comes even with PE and resin parts. I added some further details like Gaspatch turnbuckles and airspeed indicator, and wooden parts like airscrew and struts.
And this was my first model with a "rubber" rigging, painting of the light effects on the wing ribs and a wooden plated fuselage! It was a experiment and with a fail it would only be visible from below :coolio:
Painting was done with Gunze and Alclad.
Happy modeling,
Frank
The real wooden bottom side:
And a nice view:
The curved front was the hardest part:
mFWHhtUSirwa58yCWI1nGhT9vDapWdQiVcjjvgMa
The resin cooler is really cool and was part of the kit, painted with Alclad:
dZ4RrN5XzceJbQETEcqWjn1-6OZrTkcWkd6uqoMD
The Gaspatch speed indicator ...
Yw8r53W0N9EIUWJmy8EgpMOxoxeZiVNzZw-ehfGJ
... was really in use:
MY2D7IHlUBoj4ahdbNWj2FOCeOEFhYAB7mQOqcS7
That is - very - nice, I must admit I find it turned out very fine as well (if we were in any kind of competition I'd give you the prize, to be honest - but lucky me, we aren't 😉 ),
I must admit the speed indicator looks very fine and the exhaust pipes look way better than on my variant, Maybe these are a bit different, I have to check with my Marineflieger. At least I hope! Also I have to reconsider my decision of not using the gaspatch turnbuckles - do you still know which type you used?
But, yes, again: I'm impressed!
Thank you!
I put brass pins into the exhaust pipes:
The pins hold them already without glue!
I always use a mix of Gaspatch turnbuckles, here Anchor points, Albatros and One end. But type A and C are also often in use, see my latest Albatros W.4 here:
Frank
Beautiful build and finish. And insane littel details…
The turnbuckles really dot the i:s
Sweet work!
Kind regards,
Joachim
Great work
I have this in the stash as well.
This build will be saved for future reference. 👍
Where did you get the prop and struts from?
Edited by flarpen
Once again a marvelous job! :thumbsup: Some years ago my father started this kit too but didn´t make it to finish..
Good to see some Austrian stuff 😀
Another miniature marvel! Stunning.
Very nicely done. The see-through linen effect is very cool. And the overall finish captures the almost other-worldliness of the Austro-Hungarian aircraft.
How were the struts on this kit? Did they require pins? Did things line up without too many problems?
Thank you very much for your nice feedback :worthy:
From my workbench:coolio: I like to work with wood and nearly every of my modelsdownscaled originals has one. Mostly 1/48, only the Eduard Stripdown models are 1/72. For the latest build in that small scale my Fokker D.VIII got also a real wooden AXIAL airscrew.
Yes, and the wooden underside was a test, because I want to build a Lloyd one day plated with real wood. :nuts:
Here the short-run nature is clearly visible:wall: I put always brass pins in my struts.
The N-struts do not fit to the holes! I hate to glue in something under pressure! I tried in a mounting frame, but it do not work.
So I made new ones from squezzed brass tubes with pins:
More scale compared to the kit part!
After black paint glued into fuselage. On this picture the paint needs to be repaired from the previous tries to use the kit struts.
My solution holds the upper wing without any support.
The outer wooden struts. The length according to model needs. No decals yet.
Frank
BRILLIANT strut work.
What diameter tube do you use for 1/48 scale? I'm fighting with an Eduard kit right now, and I think the struts were made from dehydrated sugar crystal. I already snapped one in two different locations. 😡😡. This squeezed tube method looks promising. I presume you squeeze with a padded vice?
Wow, that is going above & beyond. Stunning work with great attention to detail.
Pete
Hmm, can' really remember, what I used here. Beside my bench is a storage of the fine brass pipes (and some nickel silver) from Albion from 0.3mm up to 2.0mm in 0.1mm steps. So it depends on the aircraft - I use always the Windsock Datafiles as reference.
You can calculate it: circumference = π * 2 * r and if you half that (- thickness), you will get nearly the strut size. May be it is easier to take a short piece (0.8, 1.0, 1.1mm) and squezze it :D
In meantime a friend printed my some pads for the vice with a 3D printer.
But it is not that perfect as the tool, you can buy here, but only for 1/32: it converts 1.4mm tube into 1.6mm x 1.0mm brass struts
https://www.shapeways.com/product/N6N2WG6JA/1-32-fokker-d-vii-quot-strut-smasher-quot-tool
By the way, he sells also some nice louvre sets in different sizes:
https://www.shapeways.com/product/TG6GLJL6N/6mm-miniature-louvre-die-set
Frank
