Shar2 Posted December 5, 2019 Share Posted December 5, 2019 Fairmile D MGB 660 Atlantic Models 1/350 The Fairmile D has to be one of the most popular boat used in the narrow seas, certainly by this reviewer. Following on from the earlier Fairmile boats the D was designed purely as a gun boat to take on the German S boats, although it never matched the speed of the S boats the armament was such that if intercepted they could easily overwhelm the German vessels. When fitted with even heavier weapons and torpedo tubes, these boats were able to take on much larger craft with considerable success. Around 229 D’s were built between 1942 and 1945. The Model The kit arrives in a small cardboard box filled with polystyrene peanuts, and comes complete with single piece hull, a small resin block and a small etched brass fret. The main hull, which is around 2 inches, (50mm) long, and is a beautifully moulded item, although the review example has one very small remnant of a moulding stub on the stern, but this is well below the waterline so when using in a diorama it may well be ignored, unless the modeller is really picky, even then they will easily be removed with a sharp scalpel or a few swipes of a sanding stick. The rest of the hull and "superstructure" is very clean and nicely done. Another small bag contains the rest of the resin items, namely the dinghy, life rafts, 6pdr mounting, twin 20mm mounting and 2pdr mounting. The rest of the parts come on a smallish etched brass fret. As can be seen in the photo there is quite a bit of thin resin around each of these parts that will need to be carefully removed with a sanding stick or scalpel. Construction begins with the assembly of the twin Oerlikon mounting with the fitting of the two guns to the resin mounting along with the separate sighting and laying frame. Two single Oerlikons, each consisting of the barrel with sights attached and which have to be folded to shape, the two sides of the breech section and the gun shield. These are then attached to the moulded pintles on either side of the bridge The 6pdr mounting resin part is fitted with the sight and armoured top box before being glued into position. With the weaponry fitted to their respective positions, the bridge is fitted with the windscreen, the anchor is mounted on the foredeck and the mast glued into position and fitted with the small yardarm and upper mast section with gaff attached. The ships wheel is fitted as is the hatch aft of the bridge, along with its associated railings. The rest of the ships railings can then be fitted in their respective positions, and that is pretty much it, unless you are going to mount the model in a display case, in which case the four propeller shafts, propellers and two rudders can be fitted. Since there are a number of Fairmile D versions being re-released the etch sheet does have quite a lot of spare parts which can be used to modify this kit into the boat of your choice according to the references you are using. Conclusion This is another great re-release, and Peter Hall should be thanked for bringing this wonderful little kit back on the market. As usual the resin moulding is superb with absolutely no sign of defects such as pin holes etc, only the tiny bit of moulding stub needs to be cleaned up. It is also another great kit for those new to resin and etch which lends itself to a whole raft of different scenarios for a diorama or vignette. Review sample courtesy of Peter Hall of 1 Link to comment Share on other sites More sharing options...
