AltcarBoB Posted December 5, 2019 Posted December 5, 2019 Can anyone tell me what colours for RAF Red Tops. A Google search brings up several schemes. All over white, white with grey fins lined in red, grey with pale green fins, grey with olive green fins, grey with red fins. Was it up to individual sqds what colours were used.
stever219 Posted December 5, 2019 Posted December 5, 2019 Typically the weapons would have a natural metal or grey body with white fins in service. I’ve just done a quick n dirty web-trawl and found a few images showing out-of-Service weapons in a variety of colours. Red outlines on the fins are actually protective covers which would be removed before flight. I think some weapons were painted overall Dark Green when the RAF went lo-vis in the mid ‘seventies and to either Dark Sea Grey, Medium Sea Grey or Barley/Camouflage Grey when the air defence greys camouflage was introduced in the early ‘eighties. It’s possible that some squadrons might have applied unit colours to their Red Tops but, if it happened, it was probably only to inert or training rounds for air display purposes. Someone is now going to prove me wrong..............
Jure Miljevic Posted December 5, 2019 Posted December 5, 2019 Perhaps this thread may help: Cheers Jure 1
Selwyn Posted December 5, 2019 Posted December 5, 2019 2 hours ago, stever219 said: Typically the weapons would have a natural metal or grey body with white fins in service. I’ve just done a quick n dirty web-trawl and found a few images showing out-of-Service weapons in a variety of colours. Red outlines on the fins are actually protective covers which would be removed before flight. I think some weapons were painted overall Dark Green when the RAF went lo-vis in the mid ‘seventies and to either Dark Sea Grey, Medium Sea Grey or Barley/Camouflage Grey when the air defence greys camouflage was introduced in the early ‘eighties. It’s possible that some squadrons might have applied unit colours to their Red Tops but, if it happened, it was probably only to inert or training rounds for air display purposes. Someone is now going to prove me wrong.............. Operational red tops were High speed silver with either white or green fins with a yellow band around the warhead and a brown band around the rocket motor. There would be no squadron markings as they were centrally held by the Missile site until required for use. Other colours seen would be either drill or ballast rounds or aquisition rounds which could be seen occasionally with no wings fitted. Red markings were as stated before protective strps removed before flight. Inert missiles were painted in similar colours but clearly marked INERT Selwyn 1 1
Skip Posted December 5, 2019 Posted December 5, 2019 26 minutes ago, Selwyn said: which could be seen occasionally with no wings If memory serves me well, the fins were removed because they suffered from fatigue. On the Lightning, removal spoiled the aircraft handling quite a bit because the wings, even on the missile, generated a fair amount of lift & so noticeably more aft stck was required for manoeuvring - even at take off speeds. Skip 1
sloegin57 Posted December 5, 2019 Posted December 5, 2019 Most Red Top bodies were described in the Tech Training Notes at Warton as "Silvery Grey" or Anodic Grey. They were mostly unpainted except for Drill (Dummy) Rounds :- Drill missiles, i.e. "Dummy" in RAF and Saudi service usually did not have wings or fins fitted. Operational missile on a diverted Southern Q aircraft, Leuchars, August '80 :- HTH Dennis 3 2
tweeky Posted December 7, 2019 Posted December 7, 2019 Never flew with wings fitted to the Acquisition rounds whilst I was at Binbrook. As for QRA the STBD missile had no protective covers fitted at all, The port missile had only the soft plastic/rubbery "Noddy Cap" covering the seeker head this was removed after the engines had started and the cockpit access ladder had been removed. 1
