Frah2o
Lancia Delta HF Integrale 16v WRC 1991 San Remo 1/8
I started the work on trunk section.....as like for engine compartment, also the trunk is poor detailed and with some mistakes
- I covered the fuel tank with insulating tape to simulate the fireproof cover
- I coated the first section of fuel filler with shrink ana added an alu tie
- forI holed the florr to add the bracket for future new tanks stripes
- I remadde with medical tape all the stripes and suddendly I wellow painted them
- I changed the water hose  with a clear one
- I added a round flange on water tank with a M2 washer
- I changed the water level tank hose with a clear one
- I remade the fuel pump as references using lego bricks
- I light detial on every upper tank flanges (bolts anc rivets)
- I changed the joint kit with a new top studio
344343d1575098972-lancia-delta-martini-w
344344d1575098972-lancia-delta-martini-w
344345d1575098972-lancia-delta-martini-w
344346d1575098972-lancia-delta-martini-w
344347d1575098972-lancia-delta-martini-w
344348d1575098972-lancia-delta-martini-w
344349d1575098972-lancia-delta-martini-w
344350d1575098972-lancia-delta-martini-w
344351d1575098972-lancia-delta-martini-w
344352d1575098972-lancia-delta-martini-w
344353d1575099011-lancia-delta-martini-w
344354d1575099011-lancia-delta-martini-w
344355d1575099011-lancia-delta-martini-w
344356d1575099011-lancia-delta-martini-w
344357d1575099011-lancia-delta-martini-w
344358d1575099011-lancia-delta-martini-w
344359d1575099011-lancia-delta-martini-w
344360d1575099011-lancia-delta-martini-w
344361d1575099011-lancia-delta-martini-w
344362d1575099011-lancia-delta-martini-w
344363d1575099023-lancia-delta-martini-w
344364d1575099023-lancia-delta-martini-w
An overall view of the building point reached
344426d1575103213-lancia-delta-martini-w
344427d1575103213-lancia-delta-martini-w
344428d1575103213-lancia-delta-martini-w
344429d1575103213-lancia-delta-martini-w
344430d1575103213-lancia-delta-martini-w
344431d1575103213-lancia-delta-martini-w
344432d1575103213-lancia-delta-martini-w
344433d1575103213-lancia-delta-martini-w
344434d1575103213-lancia-delta-martini-w
344435d1575103213-lancia-delta-martini-w
344436d1575103236-lancia-delta-martini-w
344437d1575103236-lancia-delta-martini-w
Incredible detailing , painting and assembly.  It's like looking at a real Integrale in build . Amazing .
 Gary .
 Gary .
Thanks to much Windy, veary to give you a "real response" watching this Delta
Trunk and tanks are quite completed......just missing for some finale details the rear struts bar and rear absorber top end
- I selfemade and right painted the new fuel pump
- I modify the non-return valve for water circuit
- I linked the fuel braided hoses (in and out)
- I linked the varius hrness for fuel pump and fuel level
- modificato e collegato sfiato vapori benzina
- I repainted, modify, added red shrink to fuel filler on pillar
- I added the electric wire for fuel puemp
- I added the side fireproof
344723d1575361963-lancia-delta-martini-w
344724d1575361963-lancia-delta-martini-w
344725d1575361963-lancia-delta-martini-w
344726d1575361963-lancia-delta-martini-w
344727d1575361963-lancia-delta-martini-w
344728d1575361963-lancia-delta-martini-w
344729d1575361963-lancia-delta-martini-w
344730d1575361963-lancia-delta-martini-w
344731d1575361963-lancia-delta-martini-w
344732d1575361963-lancia-delta-martini-w
344733d1575362012-lancia-delta-martini-w
344734d1575362012-lancia-delta-martini-w
344735d1575362012-lancia-delta-martini-w
344736d1575362012-lancia-delta-martini-w
344737d1575362012-lancia-delta-martini-w
344738d1575362012-lancia-delta-martini-w
344739d1575362012-lancia-delta-martini-w
344740d1575362012-lancia-delta-martini-w
344741d1575362012-lancia-delta-martini-w
344742d1575362012-lancia-delta-martini-w
I started the work on interior and i finished the rear strut bar
- i selfmade the the rear missing bag for onboard tool and for pilot jackets
- I started the work on seat belts. The kit give a fitting wrong sistem, so i replicated the correct fitting system of the first part of seat belts. directly fitted on rear struts bar.
344931d1575530747-lancia-delta-martini-w
344932d1575530747-lancia-delta-martini-w
344933d1575530747-lancia-delta-martini-w
344934d1575530747-lancia-delta-martini-w
344935d1575530747-lancia-delta-martini-w
344936d1575530747-lancia-delta-martini-w
344937d1575530747-lancia-delta-martini-w
344938d1575530747-lancia-delta-martini-w
344939d1575530747-lancia-delta-martini-w
344940d1575530747-lancia-delta-martini-w
344941d1575530762-lancia-delta-martini-w
344942d1575530762-lancia-delta-martini-w
Interior:
- I worked on estinguisher: i putty them, sanded, a first black coat and finally a 3 coat of silver leaf
- I apply a the alu stripes and selfmade buckle to imitate the real fixing system and I applied the base for manometer
- I applied the "Siries" decal (the producer of exstinguisher system)
- I modified the handbrake support, i painted the master cilinder and modified the joints
- I repainted with real combo color the handbrake lever
- i repianted the gearstick, i eresed the kit cable for reverse gear switch and i added a new one
- I applied some details nut on gearshift structure
- I added all missiung tube for rear brake and handbrake system
345137d1575703557-lancia-delta-martini-w
345138d1575703557-lancia-delta-martini-w
345139d1575703557-lancia-delta-martini-w
345140d1575703557-lancia-delta-martini-w
345141d1575703557-lancia-delta-martini-w
345142d1575703557-lancia-delta-martini-w
345143d1575703557-lancia-delta-martini-w
345144d1575703557-lancia-delta-martini-w
345145d1575703557-lancia-delta-martini-w
345146d1575703557-lancia-delta-martini-w
345147d1575703601-lancia-delta-martini-w
345148d1575703601-lancia-delta-martini-w
345149d1575703601-lancia-delta-martini-w
345150d1575703601-lancia-delta-martini-w
345151d1575703601-lancia-delta-martini-w
345152d1575703601-lancia-delta-martini-w
345153d1575703601-lancia-delta-martini-w
345154d1575703601-lancia-delta-martini-w
345155d1575703601-lancia-delta-martini-w
345156d1575703601-lancia-delta-martini-w
345157d1575703638-lancia-delta-martini-w
345158d1575703638-lancia-delta-martini-w
345159d1575703638-lancia-delta-martini-w
345160d1575703638-lancia-delta-martini-w
Continuing with interior:
- I finished the work with brake braided hose : i fitted the last part of hoses in fornt of gear stick
- I fitted all hose and wire for exsthinguisher system
- I fixxed the bootles and finally i linked all hoses and cables
- I fitted the in and out fuel lines on the lower righ side of roll cage
- I fitted the battery wires on the lower righ side of roll cage
- I fitted the vacuum fuel hose on the upper right side of roll cage (this hose will be linked to air roof intake)
- I linked the water hose on lower left side of roll cage
- I fitted the wire for exstinguisher control test and i also fitted the wire for cb antenna
- I modified the retention spare wheel system
- Some little wheatering on tarmac transkit spare wheel produced by a friend
- I placed the manometer decals
345316d1575875452-lancia-delta-martini-w
345317d1575875452-lancia-delta-martini-w
345318d1575875452-lancia-delta-martini-w
345319d1575875452-lancia-delta-martini-w
345320d1575875452-lancia-delta-martini-w
345321d1575875452-lancia-delta-martini-w
345322d1575875452-lancia-delta-martini-w
345323d1575875452-lancia-delta-martini-w
345324d1575875452-lancia-delta-martini-w
345325d1575875452-lancia-delta-martini-w
345326d1575875503-lancia-delta-martini-w
345327d1575875503-lancia-delta-martini-w
345328d1575875503-lancia-delta-martini-w
345329d1575875503-lancia-delta-martini-w
345330d1575875503-lancia-delta-martini-w
345331d1575875503-lancia-delta-martini-w
345332d1575875503-lancia-delta-martini-w
345333d1575875503-lancia-delta-martini-w
345334d1575875503-lancia-delta-martini-w
345335d1575875503-lancia-delta-martini-w
345336d1575875590-lancia-delta-martini-w
345337d1575875590-lancia-delta-martini-w
345340d1575875590-lancia-delta-martini-w
345339d1575875590-lancia-delta-martini-w
345341d1575875590-lancia-delta-martini-w
345342d1575875590-lancia-delta-martini-w
345343d1575875590-lancia-delta-martini-w
345344d1575875590-lancia-delta-martini-w
345345d1575875590-lancia-delta-martini-w
Cockpit first part
- I started to painting the Halda computer with right brown color (i would piant it all, but the client had placed the button sticker that are dangerous to remove)
- I masked the trip master area that in real car is a matt  palck panel, i painted the rest of dash trying to made the texture look
- I masked the CB radio area zone to texture the rest of lower dash
- I opened the vent for windscreen and also painted in texture look
- I replaced the fuel level under the clear glass to give some deep effect look
- I remade the right coloured cable for trip master ecu, and i also white painted the plug
- I added some PE bolts tu trip master ecu
- I remade the light on dash board and i selfe remade the turbo pressure with clear orange
- Some details to nut and rivet of instrument
- I carbon decal the upper lid of instrument
- I added the metal wire for battery switch
- I added the wiring for exstinghuisher system
- I added a alu plate behinfd the dah and visible through some holes ( i think the chassis structure of dash)
- Some details on button over the climate control
- I added the flat wirig to trip maste ecu to Halda computer
345664d1576134621-lancia-delta-martini-w
345665d1576134621-lancia-delta-martini-w
345666d1576134621-lancia-delta-martini-w
345667d1576134621-lancia-delta-martini-w
345668d1576134621-lancia-delta-martini-w
345669d1576134621-lancia-delta-martini-w
345670d1576134621-lancia-delta-martini-w
345671d1576134621-lancia-delta-martini-w
345672d1576134621-lancia-delta-martini-w
345673d1576134621-lancia-delta-martini-w
345674d1576134675-lancia-delta-martini-w
345675d1576134675-lancia-delta-martini-w
345676d1576134675-lancia-delta-martini-w
345677d1576134675-lancia-delta-martini-w
345678d1576134675-lancia-delta-martini-w
345679d1576134675-lancia-delta-martini-w
345680d1576134675-lancia-delta-martini-w
345681d1576134675-lancia-delta-martini-w
345682d1576134675-lancia-delta-martini-w
345683d1576134675-lancia-delta-martini-w
345684d1576134719-lancia-delta-martini-w
345685d1576134719-lancia-delta-martini-w
345686d1576134719-lancia-delta-martini-w
345687d1576134719-lancia-delta-martini-w
345688d1576134719-lancia-delta-martini-w
345689d1576134719-lancia-delta-martini-w
345690d1576134719-lancia-delta-martini-w
345691d1576134719-lancia-delta-martini-w
345692d1576134719-lancia-delta-martini-w
345693d1576134719-lancia-delta-martini-w
345694d1576134793-lancia-delta-martini-w
345695d1576134793-lancia-delta-martini-w
345696d1576134793-lancia-delta-martini-w
345697d1576134793-lancia-delta-martini-w
345698d1576134793-lancia-delta-martini-w
345699d1576134793-lancia-delta-martini-w
345700d1576134793-lancia-delta-martini-w
345701d1576134793-lancia-delta-martini-w
345702d1576134793-lancia-delta-martini-w
Cocckipt second para
- I modified the shelf on to fit the extra cb radio transkit,  I selfamde the radio box, painted, a litlle button detail and finally the decals
- I selfmade the absent kevlat footboard
- I coated in kevlar decal the battery cover
- I fitted a metal wire to create the CB speaker standing
- A little modify to steering column cover with a little texture work
- I added the missing cable on steering column
- I remade the cable for cb radio
- FInal fitting of dash
345918d1576309922-lancia-delta-martini-w
345919d1576309922-lancia-delta-martini-w
345920d1576309922-lancia-delta-martini-w
345921d1576309922-lancia-delta-martini-w
345922d1576309922-lancia-delta-martini-w
345923d1576309922-lancia-delta-martini-w
345924d1576309922-lancia-delta-martini-w
345925d1576309922-lancia-delta-martini-w
345926d1576309922-lancia-delta-martini-w
345927d1576309922-lancia-delta-martini-w
345928d1576310081-lancia-delta-martini-w
345929d1576310081-lancia-delta-martini-w
345930d1576310081-lancia-delta-martini-w
345931d1576310081-lancia-delta-martini-w
345932d1576310081-lancia-delta-martini-w
345933d1576310081-lancia-delta-martini-w
345934d1576310081-lancia-delta-martini-w
345935d1576310081-lancia-delta-martini-w
345936d1576310081-lancia-delta-martini-w
345937d1576310081-lancia-delta-martini-w
345938d1576310521-lancia-delta-martini-w
345939d1576310521-lancia-delta-martini-w
345940d1576310521-lancia-delta-martini-w
345941d1576310521-lancia-delta-martini-w
345942d1576310521-lancia-delta-martini-w
345943d1576310521-lancia-delta-martini-w
345944d1576310521-lancia-delta-martini-w
345945d1576310521-lancia-delta-martini-w
345946d1576310521-lancia-delta-martini-w
345947d1576310521-lancia-delta-martini-w
Excellent detail work! The combinations of materials and textures are very effective.
I was surprised to see that you made parts from Lego, normally those stand out as looking just like Lego but I think they're really effective here.
Will
Will
Thanks Vale, i discovered that some Lego bricks (especially for 1/8) are the a easy way to reproduce some shape without go crazy to selfmade.
Thanks for all, and I'm very glad to know that you're watching my build 😀
Very much enjoy the posts!  What colors/brand are you using the the high pressure fittings.  I can't get the anodized look for the red or blue.
JCH
P.S. Again, great work and keep posting!
JCH
Thanks JCH i use the mr hobby metallic red H87 and metallic blu H76. Thea re very light and metallic......on my engine bay I decrease the metallic effect after some wheatering and panel line
Copy that!!!
Where they separated at birth?
20191218_085913SM
Edited by JCH
Interior third part:
- I painted the whole steering wheel in semigloss black, i fitted the yellow center stripe, I masked the spoke and I coated the crown with clear matt to recreate the texture effect.
- I also added the momo decal on spoke and a light details to hex nut that fix steering on hub
- I finished the intercom ecu adding last detial (decal and headphone connection)
- I finally fixed the kevlar foot board
- I raised the seats using 1x1 brick (in the kit the seats was flat on inside floor.....very huge look)
- I added the Martini decal on "Siviero" sunvisor
- I fixxed the kevlar battery cover
- I selfmade and added the bracket for headphone on roll cage (some Delta has 2 bracket, some Delta only 1, some delta haven'y any barcket)
- I remade the seat belts using the Sabelt logo  and PE parts from the kit
A final pics of overall point reached
346189d1576567100-lancia-delta-martini-w
346190d1576567100-lancia-delta-martini-w
346191d1576567100-lancia-delta-martini-w
346192d1576567100-lancia-delta-martini-w
346193d1576567100-lancia-delta-martini-w
346194d1576567100-lancia-delta-martini-w
346195d1576567100-lancia-delta-martini-w
346196d1576567100-lancia-delta-martini-w
346197d1576567100-lancia-delta-martini-w
346198d1576567100-lancia-delta-martini-w
346199d1576567144-lancia-delta-martini-w
346200d1576567144-lancia-delta-martini-w
346202d1576567144-lancia-delta-martini-w
346203d1576567144-lancia-delta-martini-w
346204d1576567144-lancia-delta-martini-w
346205d1576567144-lancia-delta-martini-w
346206d1576567144-lancia-delta-martini-w
346207d1576567144-lancia-delta-martini-w
346208d1576567144-lancia-delta-martini-w
346209d1576567186-lancia-delta-martini-w
346210d1576567186-lancia-delta-martini-w
346211d1576567186-lancia-delta-martini-w
346212d1576567186-lancia-delta-martini-w
346213d1576567186-lancia-delta-martini-w
346214d1576567186-lancia-delta-martini-w
346215d1576567186-lancia-delta-martini-w
346216d1576567186-lancia-delta-martini-w
346217d1576567186-lancia-delta-martini-w
346218d1576567355-lancia-delta-martini-w
This is really good stuff and shows how busy and detailed a factory built rally car interior is . Excellent work  !!
Chassis (engine - interior - trunk) completed, I stated the work on body
- final work and some detailind to headphones
- I added the cable and decal to headphones
- I little modify and detailing to rear top end absorber
- I coated the inside face of trunk cover with fireproof tape
- I corrected the mistake of Martini livery on doors
- I corrected another mistake on card doors: ther's a white area that i painted because is "metal part" of door. The remaining black area is the trim door
- I painted the inside area of license plate holder. The inside is part of trunk
- I painted the inside of the window frame to give a better watch
- I painted the rubber trim fitted on the doors.
346474d1576824875-lancia-delta-martini-w
346475d1576824875-lancia-delta-martini-w
346476d1576824875-lancia-delta-martini-w
346477d1576824875-lancia-delta-martini-w
346478d1576824875-lancia-delta-martini-w
346479d1576824875-lancia-delta-martini-w
346480d1576824875-lancia-delta-martini-w
346481d1576824875-lancia-delta-martini-w
346482d1576824875-lancia-delta-martini-w
346483d1576824875-lancia-delta-martini-w
346484d1576824951-lancia-delta-martini-w
346485d1576824951-lancia-delta-martini-w
346486d1576824951-lancia-delta-martini-w
346487d1576824951-lancia-delta-martini-w
346488d1576824951-lancia-delta-martini-w
346489d1576824951-lancia-delta-martini-w
346490d1576824951-lancia-delta-martini-w
346491d1576824951-lancia-delta-martini-w
346492d1576824951-lancia-delta-martini-w
346493d1576824951-lancia-delta-martini-w
346494d1576825012-lancia-delta-martini-w
346495d1576825012-lancia-delta-martini-w
346496d1576825012-lancia-delta-martini-w
346497d1576825012-lancia-delta-martini-w
346498d1576825012-lancia-delta-martini-w
346499d1576825012-lancia-delta-martini-w
346500d1576825012-lancia-delta-martini-w
346501d1576825012-lancia-delta-martini-w
346502d1576825012-lancia-delta-martini-w
346503d1576825012-lancia-delta-martini-w
346504d1576825169-lancia-delta-martini-w
346505d1576825169-lancia-delta-martini-w
346506d1576825169-lancia-delta-martini-w
346507d1576825169-lancia-delta-martini-w
346508d1576825169-lancia-delta-martini-w
346509d1576825169-lancia-delta-martini-w
346510d1576825169-lancia-delta-martini-w
346511d1576825169-lancia-delta-martini-w
346512d1576825169-lancia-delta-martini-w
346513d1576825169-lancia-delta-martini-w
346514d1576825193-lancia-delta-martini-w
346515d1576825193-lancia-delta-martini-w
346516d1576825193-lancia-delta-martini-w
346517d1576825193-lancia-delta-martini-w
346518d1576825193-lancia-delta-martini-w
I've started the work on bodyshell
- I masked outside all bodyshell leaving only the center pillars to ccorest another color mistake
- I fixxed the inside roof bars dirtectly on roof and not on roll cage as proposedby the kit
- I masked the roof vent to piant the fornt roof bar (hachette has made one piece roof vent and front roof bar)
- I full painted the inside of bodyshell with alu ral 9006 like on real WRC car
- I applied all totally missed rubber trim for doors and trunk
- Some final pics vs original kit
346885d1577180234-lancia-delta-martini-w
346886d1577180247-lancia-delta-martini-w
346887d1577180258-lancia-delta-martini-w
346888d1577180271-lancia-delta-martini-w
346889d1577180282-lancia-delta-martini-w
346890d1577180311-lancia-delta-martini-w
346891d1577180318-lancia-delta-martini-w
346892d1577180337-lancia-delta-martini-w
346893d1577180348-lancia-delta-martini-w
346894d1577180355-lancia-delta-martini-w
346895d1577180366-lancia-delta-martini-w
346896d1577180373-lancia-delta-martini-w
346897d1577180381-lancia-delta-martini-w
346898d1577180393-lancia-delta-martini-w
346899d1577180400-lancia-delta-martini-w
346900d1577180408-lancia-delta-martini-w
346901d1577180420-lancia-delta-martini-w
346902d1577180432-lancia-delta-martini-w
346903d1577180440-lancia-delta-martini-w
346904d1577180446-lancia-delta-martini-w
346905d1577180452-lancia-delta-martini-w
346906d1577180458-lancia-delta-martini-w
346907d1577180463-lancia-delta-martini-w
346908d1577180481-lancia-delta-martini-w
346909d1577180493-lancia-delta-martini-w
346910d1577180500-lancia-delta-martini-w
Awesome stuff! A dream project of mine is to find a 1/8 scale kit of a subject I like and really go all out on detailing it. This thread really puts in perspective how much effort goes into putting all those extra details in. Looking forward to seeing this one finished!
Incredibly superlative work in this build that only a true Integrale fanatic could contemplate!  And I mean this in only the most admiring and envious way!  Keep up this incredible work for all the world to see!
Darin
Darin
Thanks to much Gt6mkIII (do you own Mk6 and Mk3 Vw Golf?) and Dr. Fiat (I think watching you nick, yo're a fan of italian cars) for your words, I think that this poor Delta Hachette now is lightly better than out of box. Thanks very much again
Before to start the final boyshell assembly, I started with some little but essential work to reach a final better look
- I erased the key lock form rear handle door (on real delta the rear handles are blanked)
- I opened the hole for fitting the rear latch trunk on inside trunk structure. On real delta the latch is missing because the trunk is closed by two extrenal fast releases.
- I removed the rear kit badge because "DELTA HF Integrale" is wrong for the 1991, the correct badge is "DELTA HF Integrale 16V". And I also removed Delta because both kit badges are with a dull red. After I placed the new decals, I gave some final clear gloss to recah the gloss and 3D llok like on real badges.
- I erased the wrong license plate number (Hachette use a wrong number. This number was used by Kankunnen in 1000 lakes rallye and Portugal if i well rember. I placed new correct number plate used by Biasion/Siviero for 1991 SanRemo rallye
- I opened the blank fuel vapour valve on ext side of rear pillars cover. After opening it I made some little painting detail
- I finished a little painting detail on door latch positioned on bodyshell
- The taillights kit are huge and unwatchable. I completed rework the rear lenses: i removed the led holder, i stripped out the chrome and i start to remade the base of lenses, in the future post i'll show the lens divisors for stop, position light and turn signal.
- I dampened the gloss effect of tail lights that is wrong. I sprayed the clear matt in "fog mod" to crecrate the opaque and little wrinkle effect of the 90's taillight. I also gave some clear red and orange to gave more deep.
347364d1577715155-lancia-delta-martini-w
347365d1577715155-lancia-delta-martini-w
347366d1577715155-lancia-delta-martini-w
347367d1577715155-lancia-delta-martini-w
347368d1577715155-lancia-delta-martini-w
347369d1577715155-lancia-delta-martini-w
347370d1577715155-lancia-delta-martini-w
347371d1577715155-lancia-delta-martini-w
347372d1577715155-lancia-delta-martini-w
347373d1577715155-lancia-delta-martini-w
347374d1577715220-lancia-delta-martini-w
347375d1577715220-lancia-delta-martini-w
347376d1577715220-lancia-delta-martini-w
347377d1577715220-lancia-delta-martini-w
347378d1577715220-lancia-delta-martini-w
347379d1577715220-lancia-delta-martini-w
347380d1577715220-lancia-delta-martini-w
347381d1577715220-lancia-delta-martini-w
347382d1577715220-lancia-delta-martini-w
347383d1577715220-lancia-delta-martini-w
347384d1577715261-lancia-delta-martini-w
347385d1577715261-lancia-delta-martini-w
347386d1577715261-lancia-delta-martini-w
347387d1577715261-lancia-delta-martini-w
347388d1577715261-lancia-delta-martini-w
347389d1577715261-lancia-delta-martini-w
347390d1577715261-lancia-delta-martini-w
347391d1577715261-lancia-delta-martini-w
347392d1577715261-lancia-delta-martini-w
347393d1577715261-lancia-delta-martini-w
The Christmas holiday was so good to reach the final stage of this project and now I’m quite near to the finish of this third delta ( I’m just now on final decal work and final details check)
I will divide the post into several.
1/3
- I  repainted radiator crossbar in flat aluminum as on on 1:1  delta
- I added reflector inside the lens in the Stop portion
- I filled with cyano and bicarbonate the holes of front mudflaps fitted for gravel and safari rally and finally 3 coats of X2. These plugged holes will then be covered by the round decals for inserting the jack
- I applied Decal Selenia inside the hood.
- I closed the holes for the spoiler evo (incorrect) and applied the two caps welded with cyano and bicarbonate and then the usual 3 coats of X2
- I painted in silver leaf the housing of the reverse lights to give a correct look
- I apply the fireporoff  on the trunk box
- I applied neoprene anti-vibration strip on the front crossbar of the engine like on real delta
348179d1578381290-lancia-delta-martini-w
348180d1578381290-lancia-delta-martini-w
348181d1578381290-lancia-delta-martini-w
348182d1578381290-lancia-delta-martini-w
348183d1578381290-lancia-delta-martini-w
348184d1578381290-lancia-delta-martini-w
348185d1578381290-lancia-delta-martini-w
348186d1578381290-lancia-delta-martini-w
348187d1578381290-lancia-delta-martini-w
348188d1578381290-lancia-delta-martini-w
348189d1578381327-lancia-delta-martini-w
348190d1578381327-lancia-delta-martini-w
348191d1578381327-lancia-delta-martini-w
348192d1578381327-lancia-delta-martini-w
348193d1578381327-lancia-delta-martini-w
348194d1578381327-lancia-delta-martini-w
348195d1578381327-lancia-delta-martini-w
348196d1578381327-lancia-delta-martini-w
348197d1578381327-lancia-delta-martini-w
348198d1578381327-lancia-delta-martini-w
348199d1578381367-lancia-delta-martini-w
348200d1578381367-lancia-delta-martini-w
348201d1578381367-lancia-delta-martini-w
348202d1578381367-lancia-delta-martini-w
348203d1578381367-lancia-delta-martini-w
348204d1578381367-lancia-delta-martini-w
348205d1578381367-lancia-delta-martini-w
348206d1578381367-lancia-delta-martini-w
348207d1578381367-lancia-delta-martini-w
348208d1578381367-lancia-delta-martini-w
