Jim Bates
Anouther Victory Build
Thanks for your insight you must have had a great time showing visitors around this great ship.
Hellers colour scheme for the lower decks and bulkhead  is very questionable!
I soon realised that at the start of my build but by the time the cannons have been fitted there is
not much to see through the port holes.
 I started work on the bowsprit as I was keen to see how it looked on the hull.
 I inserted brass rod on the 1st part to stiffen it up then was not happy as the rest of the bowsprit was still not stiff enough in plastic for my liking.
So I made the rest out of brass rod as well.
After painting you wouldn’t know the difference
Have to find out how to fit the heart blocks next
P1040710
Done some prep work on the upper deck and found  the front of he deck on first fit was bowing looking like a humpback bridge.
So I shaved off a bit off the edges  to get it to slip inside the hull easily. The hull slants up at the rear so having to wedge the deck on one side and  then pull the side of the hull out to force it in.
Hopping it goes well when I fit it!
Built up the skylight walls to make them more prominent as you can see from the photos I think that makes a subtle difference.
_MG_3191
_MG_3192
Thanks Murdo
Started on the bow section while I wait for the postman pictures to follow.
_MG_3637
_MG_3650
So here we go on to the bow section.  As I had previously painted Forecastle end part 344 it was a quick job to get it in place.
Curve of the top arm port side was to shallow to reach the forecastle so with a bit of persuading in the end managed to get it where I wanted it.
On fitting the lower curved arm found it was to short? Then had to insert a small section to make good. Starboard side went ok.
So what I thought was a hours work turned into a evenings entertainment.
Looks well worth the "evenings entertainment" though!    :D
Made two poop extractors for the head. These things you learn while building and researching I had no idea that’s where they sat contemplating there lot.
 Good view on a nice day though.
While I was on the bows painted up the two curved bits that sit on top of the spars parts 252/253 done a nice paint job as well. But on fitting the plastic glue started to melt the parts undoing all my good work so have them stuck down now but will have to do a clean up and repaint.
_MG_3655
_MG_3667
_MG_3665
Postman delivered the parts for the stair well.
So got on with making up the balustrades and railings.
Two of the balustrades in each set had to be carefully cross drilled with a .075 drill then assembled.
As they were brass they could be either soldered or super glued I chose the latter
Then prime etch and painted black.
Job Done
_MG_3670
_MG_3673
Over Picture of the deck with ring bolts added nearly ready to add top deck
_MG_3691
Browsing through Anatomy of Nelson's Ships the other day I realised I would need to make a d block for the cross jack lifts as the one on the hull is way to small to drive a hole in
so off thay come.
Then I made a .16mm hole in .100in thick evergreen and a .065mm hole just in front and down a bit of the first hole. Shaped around with a file glued in place.
Quite pleased with the outcome.
 As it was
_MG_3709
_MG_3696 _MG_3703
_MG_3715
Just need to tidy up as this high mag shows everything up.
 Nearly ready for the quarter deck.
Them faces look like they's in horrible pain.         :o
Looking good to me though.          :thumbsup:
Now ready for installing the quarter deck only done one pre fit for this deck as I didn't  want to stress the hull or me to much.
The rear of the hull slopes up and in at first look it don't look like the deck fits so.
Prepared the hull and slid the front of the deck in all well and good I knew that would be ok.
Then jammed the rear of the deck against one side pulling the other side over as much as I dared,
Pushing the deck down I got it passed the windows pulled over the hull a bit more and holding my breath
pushed down again to click it in place.
_MG_3725
_MG_3724
Very enjoyable build! Well done,
XXXDAN
Thanks Daniel Steve and Grant
Ran into a small problem when I fitted the stairs the balustrade on the lower deck fouled the stairs I was trying to fit
so I removed the balustrade to fit the stairs, I should have just made the balustrade sides hindsight's a great thing.
Now have plenty of jobs to do fitting out this deck.
On trying the Mizzen mast fit there was big gap at the front of the mast at deck level made up a hex top for the raised portion and drilled a hole for the mast good fit now.
Made a start on the cabins decided to go for two contrasting colours as didn't fancy dark brown.
_MG_4169
Loads to do on this deck next job galley stove chimney.
Decided to work with this on the spruce.  Glued the sides together and attached Dafis etch handles and arms with CU was a bit careful attaching the front disk as the chimney wasn't very thick in this area wasn’t going to destroy it with the glue.
 In the end it didn’t stick.So I filled the chimney up with Araldite and re glued it.
_MG_4186
Looks so nice shame to paint it
_MG_4184
Doing it on the sprue is brave, I hope you manage to get it off and sanded okay!
:thumbsup:
Murdo  Better on the spruce less chance of escape when attaching smaller parts. so got it painted here it is.
_MG_4193
You are doing a grand job on a grand lady Jim :like:
Regards
Richard
