1/72 Fulmar
3 hours ago, Chuck1945 said:
Can the SH 1/72 Fulmar MkII/NF II be built as a Mk I?
Yes, based on this: the intake parts and prop for the I are blanked out as "do not use" on the sprue diagram, and additional parts supplied for the II.
SS500LICENCE_GO_20170619_09181054_001_14
The "Prototype Story" kit by definition includes parts for the I and II, given that the prototype Fulmar was also the prototype Fulmar II (and is today the only surviving Fulmar). You can see that explained in the instructions here
https://www.super-hobby.com/products/Fairey-Fulmar-N1854-Fulmar-Prototype-Story.html#gallery_start
The Fulmar I shouldn't entail any parts not found on the Fulmar II afaik - just leave off the extra intakes on the cowling sides. Or did the II feature a different prop arrangement too?
Sorry, peering at this on my phone. Looks like there is a different prop and maybe a different arrangement inside the radiator housing. You learn something new every day!
I have posted a link to an excellent walkaround of the only surviving Fulmar, now on display at the FAA Museum. As has been stated, it was the prototype for the Mk 1 and the Mk II, and is in Mk II fit currently. The Mk 1 had a Merlin VIII in production  and the Mk II had a Merlin XXX, with a Rotol prop with broader blades, as well as tropical filters mounted on each side of the coolant/oil cooler housing. IIRC, the Mk 1 prop is included on the sprues, and you can simply not attach the two tropical filters to make a Mk 1. I'm not sure that the oil cooler and radiator matrices would be different between the two variants, but possibly the ducting from them to the side-mounted  tropical air filters might be different between the two variants-please  understand I'm no Fulmar authority.
Mike
https://www.net-maquettes.com/pictures/fairey-fulmar-mk-i-walkaround/
Edited by 72modeler
added text
